1708|6
aashee|  楼主 | 2013-8-31 18:15 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include <pic.h>
#include"HT1621.h"
#define uchar unsigned char
void ioInit()
        //---------------端口方向定义
        TRISA=0X1f;
        TRISB=0X00;
        TRISC=0xC0;
        //---------------状态
        PORTA=0X00;
        PORTB=0x00;
        PORTC=0x00;
        //---------------用户端口初始化
void main()
    unsigned char ucKey = 0;
    ioInit();
    lcdInit();
        RB3=1;                                                       /* 启动定时器ID检测使用         */
    while(1) {
#ifndef        _HT1621_H_
#define _HT1621_H_
#include<pic.h>
#define                SDA_LCD1621                RC1                //数据线
#define                SCL_LCD1621                RC0                //时钟线
#define                CS1_LCD1621                RC5
#define                CS2_LCD1621                RC4
#define                T_SDA_LCD1621         TRISC1
#define                T_SCL_LCD1621         TRISC0
#define                T_CS1_LCD1621         TRISC5
#define                T_CS2_LCD1621         TRISC4
#define BIAS 0x52
#define SYSEN 0x02
#define LCDON 0x06
#define LCDOFF 0x04
extern void lcdInit();
extern void Write_1621(uchar addr,uchar data);
extern void WriteAll_1621(uchar addr,uchar *p,uchar cnt);
#endif
#include"HT1621.h"
void __ht1621Sendbit(unsigned char a,unsigned char i)
    if (i == 0) {
        return;
        while(i--)
                if(a&0x01)
                        SDA_LCD1621=1;        //?í "1"
                else
                        SDA_LCD1621=0;        //?í"0"
                SCL_LCD1621=0;        //ê±??
                _nop();
                SCL_LCD1621=1;
                _nop();
                _nop();
                a=a>>1;
void SendBit_1621(uchar data,uchar cnt) //data 的高cnt 位元寫入HT1621,高位在前
        uchar i;
        for(i =0; i <cnt; i ++)
                if((data&0x80)==0) SDA_LCD1621=0;
                else SDA_LCD1621=1;
                SCL_LCD1621=0;
                _nop();
                SCL_LCD1621=1;
                data<<=1;
void SendDataBit_1621(uchar data,uchar cnt) //data 的低cnt 位寫入HT1621,低位在前
        uchar i;
                if((data&0x01)==0) SDA_LCD1621=0;
                else SDA_LCD1621=1;
                SCL_LCD1621=0;
                _nop();
                SCL_LCD1621=1;
                data>>=1;
void lcdClear(unsigned char ucColor)
    unsigned char i=3;
    CS1_LCD1621=0;
        CS2_LCD1621=0;
    //__ht1621Sendbit(0x5,9);
    for(i=0;i<16;++i) {
       // __ht1621Sendbit(ucColor,8);
        CS1_LCD1621=1;                        //ê1?ü
        CS2_LCD1621=1;
void SendCmd(uchar command)
        CS1_LCD1621=0;                        //ê1?ü
        CS2_LCD1621=0;
        SendBit_1621(0x80,4); //寫入旗標碼”100”和9 位command 命令,由於
        SendBit_1621(command,8); //沒有使有到更改時鐘輸出等命令,為了編程方便
        CS2_LCD1621=1; //直接將command 的最高位寫”0”
        CS2_LCD1621=0;
        SendBit_1621(0xa0,3); //寫入旗標碼”101”
        SendBit_1621(addr,6); //寫入addr 的高6 位元
        SendDataBit_1621(data,4); //寫入data 的低4 位元
        uchar i;
        CS1_LCD1621=0;
        CS2_LCD1621=0;
        for(i =0; i <cnt; i ++,p++) //連續寫入資料
                SendDataBit_1621(*p,8);
        CS1_LCD1621=1;
void lcdInit()
   unsigned char i=3;
    TRISC &= ~(1 << 0);
                                                     /* CLK                          */
    TRISC &= ~(1 << 1);                                                        /* DATA                         */
        TRISC &= ~(1 << 4);
                                                /* CS2                          */
    TRISC &= ~(1 << 5);
        CS2_LCD1621=0;
        __ht1621Sendbit(0x01,8);
    __ht1621Sendbit(0x4,4);
        CS2_LCD1621=1;
        CS2_LCD1621=0;
        __ht1621Sendbit(0x1,8);
    __ht1621Sendbit(0x6,4);
        CS2_LCD1621=1;
        CS2_LCD1621=0;
        __ht1621Sendbit(0xa1,8);
        CS2_LCD1621=1;
    CS1_LCD1621=0;
        CS2_LCD1621=0;
    for(i=0;i<16;++i) {
        __ht1621Sendbit(0x0,8);
        CS2_LCD1621=1;
各位帮忙看一下,怎么就是点不亮HT1621呢?
lianxiyi.zip
1.75 KB
谈的元| | 2013-8-31 22:40 | 只看该作者
示波器调试测量波形看,看哪点波形不对
NE5532| | 2013-9-2 16:17 | 只看该作者
测是否有阶梯波产生。
小鱼儿1045| | 2013-9-3 09:05 | 只看该作者
首先看看可能全显
mzb2012| | 2016-6-22 08:13 | 只看该作者
这个芯片我们用了很多系列;很方便的
xushuo888| | 2018-8-6 12:11 | 只看该作者
之前用过VK1621 的驱动芯片,可完全替代HT1621的,价格更优,发份资料给你参考
VK1621B-LCD液晶显示驱动IC.pdf
1.41 MB
