DSPCAN总线发送程序,为什么发送数据后TA没有被置位?
2528|5
心店言己|  楼主 | 2013-12-10 21:37 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
心店言己|  楼主 | 2013-12-10 21:38 | 只看该作者
这是程序:
#define          LED1        GpioDataRegs.GPADAT.bit.GPIO0
void main(void)
   Uint16  j;
   Uint32  k;
   struct ECAN_REGS ECanbShadow;
   InitSysCtrl(); //³õʼ»¯ÏµÍ³
   InitECanGpio();//ÅäÖÃGPIOÒý½Å
   DINT;
   InitPieCtrl();//³õʼ»¯PIEÖжÏ
   IER = 0x0000;//¹ØÖжÏ
   IFR = 0x0000;
   InitPieVectTable();//³õʼ»¯PIEÖжÏʸÁ¿±í
    MessageReceivedCount = 0;
    ErrorCount = 0;
    PassCount = 0;
    EALLOW;//ÅäÖÃeCANµÄRXºÍTX·Ö±ðΪeCANµÄ½ÓÊպͷ¢ËÍÒý½Å
    ECanbShadow.CANTIOC.all = ECanbRegs.CANTIOC.all;
    ECanbShadow.CANTIOC.bit.TXFUNC = 1;
    ECanbRegs.CANTIOC.all = ECanbShadow.CANTIOC.all;
    ECanbShadow.CANRIOC.all = ECanbRegs.CANRIOC.all;
    ECanbShadow.CANRIOC.bit.RXFUNC = 1;
    ECanbRegs.CANRIOC.all = ECanbShadow.CANRIOC.all;
    EDIS;
    // Configure the eCAN for self test mode
      // Enable the enhanced features of the eCAN.
    EALLOW;
    ECanbShadow.CANMC.all = ECanbRegs.CANMC.all;
    ECanbShadow.CANMC.bit.STM = 0;    // Configure CAN for self-test mode
    ECanbShadow.CANMC.bit.SCB = 1;    // eCAN mode (reqd to access 32 mailboxes)
    ECanbRegs.CANMC.all = ECanbShadow.CANMC.all;
    EDIS;
                         EALLOW;
                     GpioCtrlRegs.GPAMUX1.bit.GPIO0 = 0; // GPIO0 = GPIO0
                     GpioCtrlRegs.GPADIR.bit.GPIO0 = 1;
                     EDIS;
                     ECanaRegs.CANTRR.all= 0xFFFFFFFF;
                     ECanaRegs.CANTA.all= 0xFFFFFFFF;
    // Disable all Mailboxes
    ECanbRegs.CANME.all = 0;
                          EALLOW;
                          ECanbShadow.CANMC.bit.CDR=1;
                          EDIS;
   //ÉèÖ÷¢ËÍÓÊÏäID  À©Õ¹Ö¡
    ECanbMboxes.MBOX0.MSGID.all = 0x00000000;
    // Write to the MSGID field of RECEIVE mailboxes MBOX16
    ECanbMboxes.MBOX16.MSGID.all = 0x9555AAA0;
/*    // Configure Mailboxes 0-15 as Tx, 16-31 as Rx
    // Since this write is to the entire register (instead of a bit
    // field) a shadow register is not required.
    ECanbRegs.CANMD.all = 0xFFFF0000;
   //ÓÊÏä0ΪTX
        ECanbShadow.CANMD.all = ECanbRegs.CANMD.all;
        ECanbShadow.CANMD.bit.MD0 =0;
        ECanbShadow.CANMD.bit.MD16 =1;
        ECanbRegs.CANMD.all = ECanbShadow.CANMD.all;
/*  // Enable all Mailboxes
    ECanbRegs.CANME.all = 0xFFFFFFFF;
    // Specify that 8 bits will be sent/received
    ECanbMboxes.MBOX0.MSGCTRL.bit.DLC = 8;
    // No remote frame is requested   Ã»ÓÐÔ¶·½Ó¦´ðÖ¡
    // Since RTR bit is undefined upon reset,
    // it must be initialized to the proper value
    ECanbMboxes.MBOX0.MSGCTRL.bit.RTR = 0;
    // Write to the mailbox RAM field of MBOX0
    ECanbMboxes.MBOX0.MDL.all = 0x01010101;
    ECanbMboxes.MBOX0.MDH.all = 0x01010101;
                                        EALLOW;
                                        ECanbShadow.CANMC.bit.CDR = 0;
                                        EDIS;
                                  //ÓÊÏäʹÄÜMailbox0 16
                                           ECanbShadow.CANME.all = ECanbRegs.CANME.all;
                                           ECanbShadow.CANME.bit.ME0 =1;
                                           ECanbShadow.CANME.bit.ME16 =1;
                                           ECanbRegs.CANME.all = ECanbShadow.CANME.all;
    EALLOW;
    ECanbRegs.CANMIM.all = 0xFFFFFFFF;//ʹÄÜÓÊÏäÖжÏ
    // Request permission to change the configuration registers
    ECanbShadow.CANMC.bit.CCR = 1;
    EDIS;
    // Wait until the CPU has been granted permission to change the
    // configuration registers
    // Wait for CCE bit to be set..
    do
      ECanbShadow.CANES.all = ECanbRegs.CANES.all;
    } while(ECanbShadow.CANES.bit.CCE != 1 );
    // Configure the eCAN timing
    EALLOW;
    ECanbShadow.CANBTC.all = ECanbRegs.CANBTC.all;
    ECanbShadow.CANBTC.bit.BRPREG = 9;    // (BRPREG + 1) = 10 feeds a 15 MHz CAN clock
    ECanbShadow.CANBTC.bit.TSEG2REG = 5 ; // to the CAN module. (150 / 10 = 15)  5   7
    ECanbShadow.CANBTC.bit.TSEG1REG = 7;  // Bit time = 15                      7    15
    ECanbRegs.CANBTC.all = ECanbShadow.CANBTC.all;//1Mbps  600
    ECanbShadow.CANMC.bit.CCR = 0;
    EDIS;
    // Wait until the CPU no longer has permission to change the
    do
    } while(ECanbShadow.CANES.bit.CCE != 0 );
    // Begin transmitting
    for(;;)
                LED1 = 1;
                for(j=0;j<1000;j++)
                   for(k=0;k<1000;k++);
                LED1 = 0;
                for(j=0;j<1000;j++)
//                DELAY_US(500);
       ECanbRegs.CANTRS.all = 0x00000001;  // Set TRS for all transmit mailboxes
//       while(ECanbRegs.CANTA.all == 0x0000FFFF ) {}  // Wait for all TAn bits to be set..
       while(ECanbRegs.CANTA.all == 0){}
       ECanbRegs.CANTA.all = 0x00000001;   // Clear Mailbox0 TAn
       MessageSendCount++;
//       MessageReceivedCount++;
心店言己|  楼主 | 2013-12-10 21:40 | 只看该作者
现象为,灯闪一下后,不再亮了,用示波器连CAN高和CAN低,有矩形波····
dirtwillfly| | 2013-12-10 22:10 | 只看该作者
没看明白楼主用的什么单片机
心店言己|  楼主 | 2013-12-13 20:15 | 只看该作者
dirtwillfly 发表于 2013-12-10 22:10
没看明白楼主用的什么单片机
额···不好意思,用的是DSP。不过找到原因了,是因为没有外接接收的CAN节点,所以没有应答,故认为没有发送成功,因此没有置位TA。
不过又有新问题了,DSP28335的eCAN收发器用的是VP230,CAN_L和CAN_H对GND为什么都是负电平?这是正常的吗?
而且,为隐形电平的时候,CAN_L=CAN_H=-1.5V,为显性电平时,CAN_H-CAN_L差值为1.3左右,不是应该差值大于2V吗?
jaysen1988| | 2016-8-23 14:32 | 只看该作者
楼主,问题解决了吗
