屠龙LPC1788开发板 NAND FLASH + YAFFS2源码
6223|16
xi_liang|  楼主 | 2014-5-21 12:46 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
YAFFS2是比较适合NAND FLASH的文件系统,在linux系统上用得比较多。
但如果要做USB MASS STORAGE,还是要FAT文件系统的,并且要是以512字节为读写单位的。
这是一个台湾客户弄的,感谢客户的分享。当然这个程序没有中文注释。程序内容还是比较多的。有兴趣的可以研究下。
运行程序,串口的打印信息:
Hello NXP Semiconductors
Yaffs Porting
         - MCU: LPC177x_8x
         - Core: Cortex-M3
         - UART Comunication: 115200 bps
Startup Yaffs
Mount to p0 ...OK!
Create files...OK!
Write files...OK!
Close file...OK!
Read files...
Content of file[000]:
0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
Content of file[001]:
1111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111
OK!
Close file...OK!
完整MDK工程源码:
屠龙LPC1788_Emc_Yaffs2.rar (1.55 MB)
直接打开这个工程编译就可以了:
lpc1788_Emc_Yaffs2\Emc_Yaffs\Keil\Emc_Yaffs.uvproj
评分
参与人数 1威望 +10 收起 理由
xyz549040622 + 10
xi_liang|  楼主 | 2014-5-24 10:53 | 只看该作者
顶起:victory::victory::victory:
gxliu08| | 2014-6-22 20:23 | 只看该作者
感谢分享!
dong_abc| | 2014-6-24 00:24 | 只看该作者
感谢分享,这个貌视NXP弄的吧!
* $Id$      yaffs_demo.c                    2012-12-06
* @file     yaffs_demo.c
* @brief    This example describes how to port yffs library on LPC177x_8x
* @version  1.0
* @date     06. December. 2012
* @author   NXP MCU SW Application Team
* Copyright(C) 2011, NXP Semiconductor
* All rights reserved.
xyz549040622| | 2014-6-24 09:09 | 只看该作者
顶起!
LoveSC1| | 2014-6-24 21:54 | 只看该作者
谢谢分享,先存下
xi_liang|  楼主 | 2014-6-28 11:15 | 只看该作者
dong_abc 发表于 2014-6-24 00:24
感谢分享,这个貌视NXP弄的吧!
对,其实就是NXP弄的拿过来建个工程。
简单爱琴海| | 2014-7-15 17:32 | 只看该作者
大神,有没有LPC1788 Flash读写的程序,求赠送,邮箱963429304@qq.com
xi_liang|  楼主 | 2014-7-15 19:11 | 只看该作者
我们LPC1788开发板什么程序都有的,你可以到我们店铺里看下
http://item.taobao.com/item.htm? ... &_u=f1j86lg8f32
pao_huawell| | 2015-3-23 13:05 | 只看该作者
感謝分享,也求STM32的!!!
ajason509| | 2015-6-27 12:41 | 只看该作者
有没有转手屠龙lpc1788板子的
duan050790| | 2015-8-27 10:22 | 只看该作者
谢谢分享
firstfox| | 2016-9-25 12:36 | 只看该作者
不是说好的NANDFLASH的吗?为什么打开是SDRAM的
mini92| | 2017-5-27 14:31 | 只看该作者
感谢分享,谢谢,,,,,,,,,,,,,,,,,,,,,谢谢
mini92| | 2017-5-27 14:44 | 只看该作者
感谢分享,楼主好人,,,,,,,,,,,,
jianfeiiii| | 2019-6-14 14:55 | 只看该作者
这个就是lpc官网的EMC代码,不好移植啊
个人签名:http://baiweijishu.taobao.com/ 百为STM32开发板 兼容官方STM3210E-EVAL开发板 WM-G-MR-09 WIFI开发板
41
