[STM32F1]
每日开讲---学习STM32不得不看的剖析(详细分析stm32f10x.h)
28255|68
/**这里是STM32比较重要的头文件    我愛你的吻123原創講解    QQ:1746430162
  * @file    stm32f10x.h                  ST 标准的头文件
  * @author  MCD Application Team     微控制器开发小组。
  * @version V3.5.0                               版本
  * @date    11-March-2011                    2011年3月11
  * @brief   CMSIS Cortex-M3 Device Peripheral Access Layer Header File.(CMSIS:Cortex Microcontroller Software Interface Standard) 是 Cortex-M 处理器系列的与供应商无关的硬件抽象层。
  *          This file contains all the peripheral register's definitions, bits
  *          definitions and memory mapping for STM32F10x Connectivity line,
  *          High density, High density value line, Medium density,
  *          Medium density Value line, Low density, Low density Value line
  *          and XL-density devices.
  * 这个文件包含了芯片STM32F10X(接口增强型)内部的寄存器定义,位定义,内存地址变换定义,还有一些相应的高密度,低密度产品线的设备。
*          The file is the unique include file that the application programmer
  *          is using in the C source code, usually in main.c. This file contains:
  *           - Configuration section that allows to select:
  *              - The device used in the target application
  *              - To use or not the peripherals drivers in application code(i.e.
  *                code will be based on direct access to peripherals registers
  *                rather than drivers API), this option is controlled by
  *                "#define USE_STDPERIPH_DRIVER"
  *              - To change few application-specific parameters such as the HSE
  *                crystal frequency
  *           - Data structures and the address mapping for all peripherals
  *           - Peripheral's registers declarations and bits definition
  *           - Macros to access peripheral registers hardware
  *这个文件在应用程序中是至关重要的头文件,它是用C代码编写而成。通常包括在MAIN主程序中。它包括:1 设备中使用的目标应用程序。
2 决定是否使用外部设备的代码(例如使用基于寄存器的代码,而不是我们所熟悉的API应用程序接口代码)。这一设备可以通过设置 "#define USE_STDPERIPH_DRIVER" 来实现。
3  通过这一文件可以改变诸如外部设备的频率参数。
4 可以了解程序的数据结构以及外设的地址映射。
5  外设的寄存器声明和位定义可以在这个文件里面了解到。
  * @attention
  * THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
  * WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE
  * TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY
  * DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING
  * FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE
  * CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
  *注意:这一文件代码供应给用户,旨在帮助用户提升效率节约时间。ST将不会提供任何对于用户自己代码的解释和帮助。也不会解决其在代码中的任何BUG。
  * <h2><center>© COPYRIGHT 2011 STMicroelectronics</center></h2>
/** @addtogroup CMSIS
  */这个不需要关心,只是说明这个文件的作者,公司产品等等,你贴出来的估计是小小的广而告之,这也是程序员的一点小小的特权嘛
/** @addtogroup stm32f10x
#ifndef __STM32F10x_H//如果没有定义__STM32F10x_H ,则定义__STM32F10x_H
#define __STM32F10x_H
#ifdef __cplusplus//
extern "C" {
#endif
   这里是一种条件编译。extern "C"指令非常有用,因为C和C++的近亲关系。注意:extern "C"指令中的C,表示的一种编译和连接规约,而不是一种语言。C表示符合C语言的编译和连接规约的任何语言,如Fortran、assembler等。
还有要说明的是,extern "C"指令仅指定编译和连接规约,但不影响语义。例如在函数声明中,指定了extern "C",仍然要遵守C++的类型检测、参数转换规则。
/** @addtogroup Library_configuration_section
/* Uncomment the line below according to the target STM32 device used in your
   application
#if !defined (STM32F10X_LD) && !defined (STM32F10X_LD_VL) && !defined (STM32F10X_MD) && !defined (STM32F10X_MD_VL) && !defined (STM32F10X_HD) && !defined (STM32F10X_HD_VL) && !defined (STM32F10X_XL) && !defined (STM32F10X_CL)
  /* #define STM32F10X_LD */     /*!< STM32F10X_LD: STM32 Low density devices */
  /* #define STM32F10X_LD_VL */  /*!< STM32F10X_LD_VL: STM32 Low density Value Line devices */
  /* #define STM32F10X_MD */     /*!< STM32F10X_MD: STM32 Medium density devices */
  /* #define STM32F10X_MD_VL */  /*!< STM32F10X_MD_VL: STM32 Medium density Value Line devices */
  /* #define STM32F10X_HD */     /*!< STM32F10X_HD: STM32 High density devices */
  /* #define STM32F10X_HD_VL */  /*!< STM32F10X_HD_VL: STM32 High density value line devices */
  /* #define STM32F10X_XL */     /*!< STM32F10X_XL: STM32 XL-density devices */
  /* #define STM32F10X_CL */     /*!< STM32F10X_CL: STM32 Connectivity line devices */
#endif
STM32启动文件选择:
- startup_stm32f10x_ld_vl.s: for STM32 Low density Value line devices - startup_stm32f10x_ld.s: for STM32 Low density devices  - startup_stm32f10x_md_vl.s: for STM32 Medium density Value line devices - startup_stm32f10x_md.s: for STM32 Medium density devices - startup_stm32f10x_hd.s: for STM32 High density devices - startup_stm32f10x_xl.s: for STM32 XL density devices  - startup_stm32f10x_cl.s: for STM32 Connectivity line devices
  cl:互联型产品,stm32f105/107系列
vl:超值型产品,stm32f100系列
xl:超高密度产品,stm32f101/103系列
ld:低密度产品,FLASH小于64K
md:中等密度产品,FLASH=64 or 128
hd:高密度产品,FLASH大于128
/*  Tip: To avoid modifying this file each time you need to switch between these
        devices, you can define the device in your toolchain compiler preprocessor.
提示:为了避免每次编译都要修改这些文件,意思是可以使用编译器的preprocessor选项来定义芯片型号等,免得反复更新这个文件。...
- Low-density devices are STM32F101xx, STM32F102xx and STM32F103xx microcontrollers
   where the Flash memory density ranges between 16 and 32 Kbytes.
- Low-density value line devices are STM32F100xx microcontrollers where the Flash
- Medium-density devices are STM32F101xx, STM32F102xx and STM32F103xx microcontrollers这里定义的是各种产品线的FLASH的大小。
   where the Flash memory density ranges between 64 and 128 Kbytes.
- Medium-density value line devices are STM32F100xx microcontrollers where the
- High-density devices are STM32F101xx and STM32F103xx microcontrollers where
   the Flash memory density ranges between 256 and 512 Kbytes.
- High-density value line devices are STM32F100xx microcontrollers where the
- XL-density devices are STM32F101xx and STM32F103xx microcontrollers where
   the Flash memory density ranges between 512 and 1024 Kbytes.
- Connectivity line devices are STM32F105xx and STM32F107xx microcontrollers.
#error "Please select first the target STM32F10x device used in your application (in stm32f10x.h file)"
#endif   如果设备类型选择不正确,这里会报错的。
#if !defined  USE_STDPERIPH_DRIVER
* @brief Comment the line below if you will not use the peripherals drivers.
   In this case, these drivers will not be included and the application code will
  /*#define USE_STDPERIPH_DRIVER*/
#endif
* @brief In the following line adjust the value of External High Speed oscillator (HSE)
   Tip: To avoid modifying this file each time you need to use different HSE, you
        can define the HSE value in your toolchain compiler preprocessor.
#if !defined  HSE_VALUE
#ifdef STM32F10X_CL
  #define HSE_VALUE    ((uint32_t)25000000) /*!< Value of the External oscillator in Hz */
#else
  #define HSE_VALUE    ((uint32_t)8000000) /*!< Value of the External oscillator in Hz */
#endif /* STM32F10X_CL */
#endif /* HSE_VALUE */
* @brief In the following line adjust the External High Speed oscillator (HSE) Startup
   Timeout value
   */①、HSI是高速内部时钟,RC振荡器,频率为8MHz。  ②、HSE是高速外部时钟,可接石英/陶瓷谐振器,或者接外部时钟源,频率范围为4MHz~16MHz。
  ③、LSI是低速内部时钟,RC振荡器,频率为40kHz。
  ④、LSE是低速外部时钟,接频率为32.768kHz的石英晶体。
  ⑤、PLL为锁相环倍频输出,其时钟输入源可选择为HSI/2、HSE或者HSE/2。倍频可选择为2~16倍,但是其输出频率最大不得超过72MHz
#define HSE_STARTUP_TIMEOUT   ((uint16_t)0x0500) /*!< Time out for HSE start up */
高速外部时钟启动时间
#define HSI_VALUE    ((uint32_t)8000000) /*!< Value of the Internal oscillator in Hz*/
外部时钟设置的值
* @brief STM32F10x Standard Peripheral Library version number
#define __STM32F10X_STDPERIPH_VERSION_MAIN   (0x03) /*!< [31:24] main version */
#define __STM32F10X_STDPERIPH_VERSION_SUB1   (0x05) /*!< [23:16] sub1 version */
#define __STM32F10X_STDPERIPH_VERSION_SUB2   (0x00) /*!< [15:8]  sub2 version */
#define __STM32F10X_STDPERIPH_VERSION_RC     (0x00) /*!< [7:0]  release candidate */
#define __STM32F10X_STDPERIPH_VERSION       ( (__STM32F10X_STDPERIPH_VERSION_MAIN << 24)\
                                             |(__STM32F10X_STDPERIPH_VERSION_SUB1 << 16)\
                                             |(__STM32F10X_STDPERIPH_VERSION_SUB2 << 8)\
                                             |(__STM32F10X_STDPERIPH_VERSION_RC))
/** @addtogroup Configuration_section_for_CMSIS
* @brief Configuration of the Cortex-M3 Processor and Core Peripherals
#ifdef STM32F10X_XL
#define __MPU_PRESENT             1 /*!< STM32 XL-density devices provide an MPU */
#else
#define __MPU_PRESENT             0 /*!< Other STM32 devices does not provide an MPU */
#endif /* STM32F10X_XL */
#define __NVIC_PRIO_BITS          4 /*!< STM32 uses 4 Bits for the Priority Levels    */
#define __Vendor_SysTickConfig    0 /*!< Set to 1 if different SysTick Config is used */
* @brief STM32F10x Interrupt Number Definition, according to the selected device
*        in @ref Library_configuration_section
typedef enum IRQn
/******  Cortex-M3 Processor Exceptions Numbers ***************************************************/
  NonMaskableInt_IRQn         = -14,    /*!< 2 Non Maskable Interrupt                             */
  MemoryManagement_IRQn       = -12,    /*!< 4 Cortex-M3 Memory Management Interrupt              */
  BusFault_IRQn               = -11,    /*!< 5 Cortex-M3 Bus Fault Interrupt                      */
  UsageFault_IRQn             = -10,    /*!< 6 Cortex-M3 Usage Fault Interrupt                    */
  SVCall_IRQn                 = -5,     /*!< 11 Cortex-M3 SV Call Interrupt                       */
  DebugMonitor_IRQn           = -4,     /*!< 12 Cortex-M3 Debug Monitor Interrupt                 */
  PendSV_IRQn                 = -2,     /*!< 14 Cortex-M3 Pend SV Interrupt                       */
  SysTick_IRQn                = -1,     /*!< 15 Cortex-M3 System Tick Interrupt                   */
我爱你的吻123|  楼主 | 2014-6-11 17:09 | 只看该作者
ST版本库的 stm32f10x.h 文件,包含整个头文件代码。综合以上,可以看出 stm32f10x.h 用于定义了器件、中断线、数据类型、结构体封装的寄存器、寄存器地址映射、寄存器位操作以及防C++编译的条件编译。  * @file    stm32f10x.h                  ST 标准的头文件
  *                crystal frequency
  * @attention
  * <h2><center>? COPYRIGHT 2011 STMicroelectronics</center></h2>
extern "C" {
#endif
一开始我不解   extern "C" {   这个语句的意思,原来是用来说明后面的定义都是使用C语言写的。这个 __cplusplus 是指C++来的,4、5句的意思就是说如果用C++编译器的话,它里面是定义有__cplusplus 这个的,而通过 extern "C" { 告知编译器,这段代码是用C编写的,要按照C语言编译。这是因为C++里面有函数重载,编译的时候把参数也编译了,而C的话,编译只编译函数名。
   application
#endif
STM32启动文件选择:
ld:低密度产品,FLASH小于64K
hd:高密度产品,FLASH大于128
#endif
这些提示:为了避免每次编译都要修改文件,意思是可以使用编译器的preprocessor选项来定义芯片型号等,免得反复更新这个文件。...
#ifdef STM32F10X_CL
#else
   Timeout value
  ⑤、PLL为锁相环倍频输出,其时钟输入源可选择为HSI/2、HSE或者HSE/2。倍频可选择为2~16倍,但是其输出频率最大不得超过72MHz。
高速外部时钟启动时间
外部时钟设置的值
* @brief STM32F10x Standard Peripheral Library version number标准外设库版本号的定义
* @brief Configuration of the Cortex-M3 Processor and Core Peripherals 配置Cortex-M3处理器和核内外设
#ifdef STM32F10X_XL
#else
*        in @ref Library_configuration_section  中断线定义,前部分对于所有STM32F10x都有相同定义,后部分根据不同器件容量采用条件编译定义不同中断线。
我爱你的吻123|  楼主 | 2014-6-11 17:33 | 只看该作者
typedef enum IRQn                typedef enum表示定义了一个枚举型的数据结构,你可以用题目中的 IRQn 去定义变量
{系统异常ID:
标号
中断ID
描述
NonMaskableInt_IRQn
-14
不可屏蔽中断
-12
Cortex-M3内存管理中断
BusFault_IRQn
-11
Cortex-M3 总线Fault中断
UsageFault_IRQn
-10
Cortex-M3 用法Fault 中断
SVCall_IRQn
-5
Cortex-M3 SV Call中断
DebugMonitor_IRQn
-4
Cortex-M3 调试监视中断
PendSV_IRQn
-2
Cortex-M3 Pend SV中断
SysTick_IRQn
-1
Cortex-M3 系统Tick中断
外设中断ID:
标号中断ID描述标号 中断ID描述
WDT_IRQn0看门狗EINT3_IRQn21外中断3
TIMER0_IRQn1定时器0ADC_IRQn22AD转换
TIMER1_IRQn2定时器1BOD_IRQn23欠压检测
TIMER2_IRQn3定时器2USB_IRQn24USB
TIMER3_IRQn4定时器3CAN_IRQn25CAN
UART0_IRQn5UART0DMA_IRQn26通用DMA
UART1_IRQn6UART1I2S_IRQn27I2S
UART2_IRQn7UART2ENET_IRQn28以太网
UART3_IRQn8UART3MCI_IRQn29SD/MMC卡I/F
PWM1_IRQn9PWM1MCPWM_IRQn30电机控制PWM
I2C0_IRQn10I2C0QEI_IRQn31正交编码接口
I2C1_IRQn11I2C1PLL1_IRQn32PLL1锁存
I2C2_IRQn12I2C2USBActivity_IRQn33USB活动
Reserved0_IRQn13保留CANActivity_IRQn34CAN活动
SSP0_IRQn14SSP0UART4_IRQn35UART4
SSP1_IRQn15SSP1SSP2_IRQn36SSP2
PLL0_IRQn16PLL0锁存LCD_IRQn37LCD
RTC_IRQn17RTCGPIO_IRQn38GPIO
EINT0_IRQn18外中断0PWM0_IRQn39PWM0
EINT1_IRQn19外中断1EEPROM_IRQn40EEPROM
EINT2_IRQn20外中断2
/******  Cortex-M3 Processor Exceptions Numbers ***************************************************/CMSIS中的中断定义
  NonMaskableInt_IRQn         = -14,    /*!< 2 Non Maskable Interrupt      非屏蔽中断                       */
  MemoryManagement_IRQn       = -12,    /*!< 4 Cortex-M3 Memory Management Interrupt  Cortex-M3内存管理中断            */
/******  STM32 specific Interrupt Numbers *********************************************************/
  WWDG_IRQn                   = 0,      /*!< Window WatchDog Interrupt                            */
  PVD_IRQn                    = 1,      /*!< PVD through EXTI Line detection Interrupt            */
  TAMPER_IRQn                 = 2,      /*!< Tamper Interrupt                                     */
  RTC_IRQn                    = 3,      /*!< RTC global Interrupt                                 */
  FLASH_IRQn                  = 4,      /*!< FLASH global Interrupt                               */
  RCC_IRQn                    = 5,      /*!< RCC global Interrupt                                 */
  EXTI0_IRQn                  = 6,      /*!< EXTI Line0 Interrupt                                 */
  EXTI1_IRQn                  = 7,      /*!< EXTI Line1 Interrupt                                 */
  EXTI2_IRQn                  = 8,      /*!< EXTI Line2 Interrupt                                 */
  EXTI3_IRQn                  = 9,      /*!< EXTI Line3 Interrupt                                 */
  EXTI4_IRQn                  = 10,     /*!< EXTI Line4 Interrupt                                 */
  DMA1_Channel1_IRQn          = 11,     /*!< DMA1 Channel 1 global Interrupt                      */
  DMA1_Channel2_IRQn          = 12,     /*!< DMA1 Channel 2 global Interrupt                      */
  DMA1_Channel3_IRQn          = 13,     /*!< DMA1 Channel 3 global Interrupt                      */
  DMA1_Channel4_IRQn          = 14,     /*!< DMA1 Channel 4 global Interrupt                      */
  DMA1_Channel5_IRQn          = 15,     /*!< DMA1 Channel 5 global Interrupt                      */
  DMA1_Channel6_IRQn          = 16,     /*!< DMA1 Channel 6 global Interrupt                      */
  DMA1_Channel7_IRQn          = 17,     /*!< DMA1 Channel 7 global Interrupt                      */
#ifdef STM32F10X_LD
  ADC1_2_IRQn                 = 18,     /*!< ADC1 and ADC2 global Interrupt                       */
  USB_HP_CAN1_TX_IRQn         = 19,     /*!< USB Device High Priority or CAN1 TX Interrupts       */
  USB_LP_CAN1_RX0_IRQn        = 20,     /*!< USB Device Low Priority or CAN1 RX0 Interrupts       */
  CAN1_RX1_IRQn               = 21,     /*!< CAN1 RX1 Interrupt                                   */
  CAN1_SCE_IRQn               = 22,     /*!< CAN1 SCE Interrupt                                   */
  EXTI9_5_IRQn                = 23,     /*!< External Line[9:5] Interrupts                        */
  TIM1_BRK_IRQn               = 24,     /*!< TIM1 Break Interrupt                                 */
  TIM1_UP_IRQn                = 25,     /*!< TIM1 Update Interrupt                                */
  TIM1_TRG_COM_IRQn           = 26,     /*!< TIM1 Trigger and Commutation Interrupt               */
  TIM1_CC_IRQn                = 27,     /*!< TIM1 Capture Compare Interrupt                       */
  TIM2_IRQn                   = 28,     /*!< TIM2 global Interrupt                                */
  TIM3_IRQn                   = 29,     /*!< TIM3 global Interrupt                                */
  I2C1_EV_IRQn                = 31,     /*!< I2C1 Event Interrupt                                 */
  I2C1_ER_IRQn                = 32,     /*!< I2C1 Error Interrupt                                 */
  SPI1_IRQn                   = 35,     /*!< SPI1 global Interrupt                                */
  USART1_IRQn                 = 37,     /*!< USART1 global Interrupt                              */
  USART2_IRQn                 = 38,     /*!< USART2 global Interrupt                              */
  EXTI15_10_IRQn              = 40,     /*!< External Line[15:10] Interrupts                      */
  RTCAlarm_IRQn               = 41,     /*!< RTC Alarm through EXTI Line Interrupt                */
  USBWakeUp_IRQn              = 42      /*!< USB Device WakeUp from suspend through EXTI Line Interrupt */
#endif /* STM32F10X_LD */
#ifdef STM32F10X_LD_VL
  ADC1_IRQn                   = 18,     /*!< ADC1 global Interrupt                                */
  TIM1_BRK_TIM15_IRQn         = 24,     /*!< TIM1 Break and TIM15 Interrupts                      */
  TIM1_UP_TIM16_IRQn          = 25,     /*!< TIM1 Update and TIM16 Interrupts                     */
  TIM1_TRG_COM_TIM17_IRQn     = 26,     /*!< TIM1 Trigger and Commutation and TIM17 Interrupt     */
  CEC_IRQn                    = 42,     /*!< HDMI-CEC Interrupt                                   */
  TIM6_DAC_IRQn               = 54,     /*!< TIM6 and DAC underrun Interrupt                      */
  TIM7_IRQn                   = 55      /*!< TIM7 Interrupt                                       */
#endif /* STM32F10X_LD_VL */
icecut| | 2014-6-11 17:36 | 只看该作者
不错.
我爱你的吻123|  楼主 | 2014-6-11 17:36 | 只看该作者
系统异常ID:
标号
中断ID
描述
NonMaskableInt_IRQn
-14
不可屏蔽中断
-12
Cortex-M3内存管理中断
BusFault_IRQn
-11
Cortex-M3 总线Fault中断
UsageFault_IRQn
-10
SVCall_IRQn
-5
Cortex-M3 SV Call中断
DebugMonitor_IRQn
-4
Cortex-M3 调试监视中断
PendSV_IRQn
-2
Cortex-M3 Pend SV中断
SysTick_IRQn
-1
Cortex-M3 系统Tick中断
外设中断ID:
标号中断ID描述标号 中断ID描述
EINT2_IRQn20外中断2
#ifdef STM32F10X_MD這是我們前面講過的不同的芯片型號,對應 著不同的中斷級別。請大家自行研究!
  TIM4_IRQn                   = 30,     /*!< TIM4 global Interrupt                                */
  I2C2_EV_IRQn                = 33,     /*!< I2C2 Event Interrupt                                 */
  I2C2_ER_IRQn                = 34,     /*!< I2C2 Error Interrupt                                 */
  SPI2_IRQn                   = 36,     /*!< SPI2 global Interrupt                                */
  USART3_IRQn                 = 39,     /*!< USART3 global Interrupt                              */
#endif /* STM32F10X_MD */
#ifdef STM32F10X_MD_VL這是我們前面講過的不同的芯片型號,對應 著不同的中斷級別。請大家自行研究!
#endif /* STM32F10X_MD_VL */
我們通過這個枚舉類型,可以知道系統所有的中斷都在里面,而且可以了解它們的ID,這就代表了它們的中斷級別。請大家仔細研究!有什么問題可以聯系QQ:1746430162 或者加入我建的群 365027537
我爱你的吻123|  楼主 | 2014-6-11 17:39 | 只看该作者
系统异常ID:
标号
中断ID
描述
NonMaskableInt_IRQn
-14
不可屏蔽中断
-12
Cortex-M3内存管理中断
BusFault_IRQn
-11
Cortex-M3 总线Fault中断
UsageFault_IRQn
-10
SVCall_IRQn
-5
Cortex-M3 SV Call中断
DebugMonitor_IRQn
-4
Cortex-M3 调试监视中断
PendSV_IRQn
-2
Cortex-M3 Pend SV中断
SysTick_IRQn
-1
Cortex-M3 系统Tick中断
外设中断ID:
标号中断ID描述标号 中断ID描述
EINT2_IRQn20外中断2
#ifdef STM32F10X_HD       這是我們前面講過的不同的芯片型號,對應 著不同的中斷級別。請大家自行研究!
  USBWakeUp_IRQn              = 42,     /*!< USB Device WakeUp from suspend through EXTI Line Interrupt */
  TIM8_BRK_IRQn               = 43,     /*!< TIM8 Break Interrupt                                 */
  TIM8_UP_IRQn                = 44,     /*!< TIM8 Update Interrupt                                */
  TIM8_TRG_COM_IRQn           = 45,     /*!< TIM8 Trigger and Commutation Interrupt               */
  TIM8_CC_IRQn                = 46,     /*!< TIM8 Capture Compare Interrupt                       */
  ADC3_IRQn                   = 47,     /*!< ADC3 global Interrupt                                */
  FSMC_IRQn                   = 48,     /*!< FSMC global Interrupt                                */
  SDIO_IRQn                   = 49,     /*!< SDIO global Interrupt                                */
  TIM5_IRQn                   = 50,     /*!< TIM5 global Interrupt                                */
  SPI3_IRQn                   = 51,     /*!< SPI3 global Interrupt                                */
  UART4_IRQn                  = 52,     /*!< UART4 global Interrupt                               */
  UART5_IRQn                  = 53,     /*!< UART5 global Interrupt                               */
  TIM6_IRQn                   = 54,     /*!< TIM6 global Interrupt                                */
  TIM7_IRQn                   = 55,     /*!< TIM7 global Interrupt                                */
  DMA2_Channel1_IRQn          = 56,     /*!< DMA2 Channel 1 global Interrupt                      */
  DMA2_Channel2_IRQn          = 57,     /*!< DMA2 Channel 2 global Interrupt                      */
  DMA2_Channel3_IRQn          = 58,     /*!< DMA2 Channel 3 global Interrupt                      */
  DMA2_Channel4_5_IRQn        = 59      /*!< DMA2 Channel 4 and Channel 5 global Interrupt        */
#endif /* STM32F10X_HD */
评分
参与人数 1威望 +1 收起 理由
通宵敲代码 + 1 赞一个!
一清如水| | 2014-6-11 19:21 | 只看该作者
尽管大部分是翻译,还是值得鼓励的
fjjjnk1234| | 2014-6-11 19:45 | 只看该作者
谢谢分享!!!顶!!!:lol
限量_个性。| | 2014-6-11 23:23 | 只看该作者
很好啊  支持一个。
限量_个性。| | 2014-6-11 23:24 | 只看该作者
LZ港澳地区的吗  用繁体字?
bobde163| | 2014-6-11 23:28 | 只看该作者
很详细的说明,顶楼主
abcdotaabc| | 2014-6-11 23:50 | 只看该作者
系统异常ID:
现在出来了 图形化工具后 你说解析的这些是否还需要考虑去接触呢?或者直接把图形化初始化工具当做高级语音 直接调用呢?
searover79| | 2014-6-12 08:13 | 只看该作者
占位
frlop| | 2014-6-12 08:45 | 只看该作者
mark
liuruoshui1987| | 2014-6-12 08:48 | 只看该作者
好东西!支持!
我爱你的吻123|  楼主 | 2014-6-12 08:52 | 只看该作者
abcdotaabc 发表于 2014-6-11 23:50
现在出来了 图形化工具后 你说解析的这些是否还需要考虑去接触呢?或者直接把图形化初始化工具当做高级语 ...
我觉得出现图形化工具是为了缓解人的编程压力提高劳动效率,但是底层代码我们还是要去了解的。其实我解析 的这些代码已经是比较成熟的库了,如果按照我的想法应该了解一些最底层的东西。知其然、知其所以然。这才是学习的最好办法。图形化初始化工具当做高级语是可以的,但是前提这是你了解了一底层后的做法。
我爱你的吻123|  楼主 | 2014-6-12 08:55 | 只看该作者
icecut 发表于 2014-6-11 17:36
不错.
谢谢版主的鼓励,我会努力的:)
我爱你的吻123|  楼主 | 2014-6-12 08:56 | 只看该作者
liuruoshui1987 发表于 2014-6-12 08:48
好东西!支持!
谢谢支持!:)
我爱你的吻123|  楼主 | 2014-6-12 08:57 | 只看该作者
bobde163 发表于 2014-6-11 23:28
很详细的说明,顶楼主
只是为大家尽一点力而已,谢谢支持!
我爱你的吻123|  楼主 | 2014-6-12 08:58 | 只看该作者
限量_个性。 发表于 2014-6-11 23:23
很好啊  支持一个。
谢谢版主的支持!:P
个人签名:本工作室是专业电子类设计开发团队,团队成员全为从事51\DSP\ ARM\fpga类嵌入式开发和图像处理、机器学习等相关算法研究多年的软、硬件开发工程师,已与全国几十家客户成功合作,可以长期提供技术支持,承接各类相关项目开发与咨询服务。 QQ:1746430162
37
