[Kinetis]
AN2295 bootloader文档解析(三)
8308|108
       上周笔者已经向大家介绍了FRDM-KE02例程包中的boot loader例程的相关代码组成和程序流程关系,而这次的内容则紧跟上一次,介绍KE02通过boot loader例程实现User code升级的步骤。 闲话少叙,立即开整!
1. Bootloader例程烧录
运行平台
Ø FRDM-KE02
Ø IARARM IDE
    运行例程(IAR)
1)    使用USB cable连接FRDM-KE02开发板Min-B USB连接器(J6);
2)    加载GPIO工程后,选择【FLASH_128KB】,点击 进行编译;
3)    编译成功后,点击 进入调试界面;
4)    进入调试界面后,点击 运行例程。
1.  Bootloader上位机使用手册
1)    解压AN2295代码包后,在<install_dir>\an2295sw\masters\debug路径下,打开“win_hc08sprg.exe”
                          图 1
2)    生成User code的S19文件
Ø  修改User code工程的linker file文件(以IAR ICF file为例)
/*###ICF### Section handled by ICF editor, don't touch! ****/
/*-Editor annotation file-*/
/* IcfEditorFile="$TOOLKIT_DIR$\config\ide\IcfEditor\cortex_v1_0.xml" */
/*-Memory Regions-*/
//define symbol __ICFEDIT_region_ROM_start__ = 0;                                                           //修改前
define symbol __ICFEDIT_region_ROM_start__ = 0x00001000;                                           //修改后
define symbol __ICFEDIT_region_ROM_end__   = (64*1024) -1;//********
define symbol __ICFEDIT_region_RAM_end__   = 0x20000000;
define symbol __ICFEDIT_region_RAM_start__ =__ICFEDIT_region_RAM_end__ - (4*1024)/4 + 0x410;//********
define symbol __region_EEPROM_start__      = 0x10003100;
define symbol __region_EEPROM_end__        = __region_EEPROM_start__ -1 + 256; // 256 bytes
/*-Specials-*/
define symbol __ICFEDIT_intvec_start__     = __ICFEDIT_region_ROM_start__;
/*-Sizes-*/
define symbol __ICFEDIT_size_cstack__ = (1*1024);//********
define symbol __ICFEDIT_size_heap__   = (1*1024);//********
/**** End of ICF editor section. ###ICF###*/
define symbol __region_RAM2_start__        = 0x20000000;
define symbol __region_RAM2_end__          = __region_RAM2_start__ + ((4*1024)*3)/4;//********
//define exported symbol __VECTOR_TABLE      = 0x00000000;                           //修改前
define exported symbol __VECTOR_TABLE      = 0x00001000;                             //修改后
define exported symbol __VECTOR_RAM        = __ICFEDIT_region_RAM_start__ - 0x410;
define exported symbol __BOOT_STACK_ADDRESS = __region_RAM2_end__ - 8;
define symbol __code_start__ = __ICFEDIT_region_ROM_start__ + 0x410;//********
define memory mem with size = 4G;
define region ROM_region   = mem:[from __ICFEDIT_region_ROM_start__   to __ICFEDIT_region_ROM_end__] | mem:[from __region_EEPROM_start__ to __region_EEPROM_end__];//********
define region RAM_region   = mem:[from __ICFEDIT_region_RAM_start__   to __region_RAM2_end__] | mem:[from __region_RAM2_start__ to __region_RAM2_end__];
define block CSTACK    with alignment = 8, size = __ICFEDIT_size_cstack__   { };
define block HEAP      with alignment = 8, size = __ICFEDIT_size_heap__     { };
initialize manually { readwrite };
initialize manually { section .data};
initialize manually { section .textrw };
do not initialize  { section .noinit };
define block CodeRelocate { section .textrw_init };
define block CodeRelocateRam { section .textrw };
place at address mem:__ICFEDIT_intvec_start__ { readonly section .intvec };
place at address mem:__code_start__ { readonly section .noinit };
place in ROM_region   { readonly, block CodeRelocate};
place in RAM_region   { readwrite, block CodeRelocateRam,
                        block CSTACK, block HEAP };
Ø     生成S19文件设置
选中工程后,右击后并单击【Options】,图2所示;
                                            图2
勾选【Generate additional output】,并选择【Motorola】作为Output format,如图3所示;
                                         图 3
勾选【Override default】,可修改生成文件的文件名,最后单击【OK】,如图4所示;
                                  图4
3)    上位机与FRDM-KE02建立连接
                                    图5
【1】:选择合适的COM;
【2】 :  选择协定好的波特率;
【3】:选择User code工程生成的S19文件;
【4】:点击Connect,接着复位Target,使得Boot loader例程重新运行。
4)   User code更新       经上述3步骤后,上位机的Identification框中会显示Bootloader的相关属性信息(如图6所示),同时主窗口还显示了MCU的封装形式、Flash特性、中断向量表重定向地址、User code所占Flash空间等信息,表明了上位机与Target连接建立成功,接着点击【Program】,即可实现User code更新,如图7所示。
                             图6
                                图7
AN2295 bootloader文档解析(三)下载:
游客,如果您要查看本帖隐藏内容请回复
FSL_TICS_A|  楼主 | 2014-7-28 11:35 | 只看该作者
AN2295 bootloader文档解析系列已完结,如有什么不足,或者不充分,疑问的地方,请在后面跟帖,谢谢!
FSL_TICS_ZJJ| | 2014-7-28 11:44 | 只看该作者
感谢楼主的手把手应用笔记讲解。
dongshan| | 2014-7-28 13:32 | 只看该作者
谢谢版主,版主们辛苦了。
FSL_TICS_ZJJ| | 2014-7-28 13:54 | 只看该作者
dongshan 发表于 2014-7-28 13:32
谢谢版主,版主们辛苦了。
不客气,还请多多关注我们的经验分享总贴:http://bbs.21ic.com/icview-722190-1-1.html
FSL_TICS_Jeremy| | 2014-8-5 14:01 | 只看该作者
谢谢版主,版主们辛苦了。
欢迎下载学习,如果有什么疑问的话,可在帖子下跟帖提出!
蓝水天下| | 2014-8-11 13:35 | 只看该作者
谢谢,辛苦了
FSL_TICS_A|  楼主 | 2014-8-11 13:53 | 只看该作者
蓝水天下 发表于 2014-8-11 13:35
谢谢,辛苦了
电子好学者| | 2014-8-18 22:43 | 只看该作者
正在使用KE02
FSL_TICS_Jeremy| | 2014-8-19 14:31 | 只看该作者
电子好学者 发表于 2014-8-18 22:43
正在使用KE02
电子好学者| | 2014-8-24 21:15 | 只看该作者
你好 如果 我用其他1号单片机 给2号单片机升级程序如何做比较好呢?我2号单片机是KE02,一号单片机是富士通的 ,1号和2号是串口通信
FSL_TICS_Jeremy| | 2014-8-25 10:07 | 只看该作者
电子好学者 发表于 2014-8-24 21:15
你好 如果 我用其他1号单片机 给2号单片机升级程序如何做比较好呢?我2号单片机是KE02,一号单片机是富士 ...
你好,
那你的项目的关键点是,1号机如何得到S19或其他类似的文件,然后通过解析通过串口串口2号机
yanbin560| | 2014-9-19 15:57 | 只看该作者
准备使用bootloader,先进行知识储备
shiyi902| | 2014-10-3 09:46 | 只看该作者
谢谢版主,辛苦了。
cmheia| | 2014-10-4 14:18 | 只看该作者
要知道有什么不足,需要先下载,要下载,需要回复……
光速| | 2014-10-30 11:06 | 只看该作者
支持
nongfuxu| | 2014-11-7 19:50 | 只看该作者
应该是好**吧。
来学习。
iwowlifei| | 2014-11-29 08:35 | 只看该作者
Thanks for sharing~~~
fisher8285| | 2014-12-1 23:34 | 只看该作者
楼主辛苦,都写到第3篇了。
zhangjinxi| | 2014-12-31 10:54 | 只看该作者
啊九分裤解放军空军萨拉凯撒离开教室里发生
