[Atmel]
用ASF跑SAMD21程序(7)USART重映射
2714|3
ddllxxrr|  楼主 | 2014-12-24 19:47 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
上一篇是USART利用板载的DEBG来输出的,这里我想用我从淘宝搞的中九下载线来完成串口输出的功能。
Atmel ASF,是靠MUX就是复用器来重新选则管脚功能的。
打开上个例子的程序可以得到:
 config_usart.mux_setting = EDBG_CDC_SERCOM_MUX_SETTING;
42.         config_usart.pinmux_pad0 = EDBG_CDC_SERCOM_PINMUX_PAD0;
43.         config_usart.pinmux_pad1 = EDBG_CDC_SERCOM_PINMUX_PAD1;
44.         config_usart.pinmux_pad2 = EDBG_CDC_SERCOM_PINMUX_PAD2;
45.         config_usart.pinmux_pad3 = EDBG_CDC_SERCOM_PINMUX_PAD3;
46.         while (usart_init(&usart_instance, EDBG_CDC_MODULE, &config_usart) != STATUS_OK)
47.          {    }
48.          usart_enable(&usart_instance);
config_usart.mux_setting = EXT3_UART_SERCOM_MUX_SETTING;
这一句就是选择USART的复用功能到哪个UART口。
而后边的
这些都在samd21_xplained_pro.h中定义好了。
所以我只要换,这几个命令行就可以了。我就可以把我的串口线用上了,呵呵!!!!
程序清单:
* \file
* \brief Empty user application template
* \mainpage User Application template doxygen documentation
* \par Empty user application template
* This is a bare minimum user application template.
* For documentation of the board, go \ref group_common_boards "here" for a link
* to the board-specific documentation.
* \par Content
* -# Include the ASF header files (through asf.h)
* -# Minimal main function that starts with a call to system_init()
* -# Basic usage of on-board LED and button
* -# "Insert application code here" comment
* Include header files for all drivers that have been imported from
* Atmel Software Framework (ASF).
#include <asf.h>
void configure_usart(void);
struct usart_module usart_instance;
         struct usart_config config_usart;
         usart_get_config_defaults(&config_usart);
         config_usart.baudrate    = 9600;
         config_usart.pinmux_pad0 = EXT3_UART_SERCOM_PINMUX_PAD0;
         config_usart.pinmux_pad1 = EXT3_UART_SERCOM_PINMUX_PAD1;
         config_usart.pinmux_pad2 = EXT3_UART_SERCOM_PINMUX_PAD2;
         config_usart.pinmux_pad3 = EXT3_UART_SERCOM_PINMUX_PAD3;
         while (usart_init(&usart_instance, EXT3_UART_MODULE, &config_usart) != STATUS_OK)
int main (void)
        system_init();
        configure_usart();
        uint8_t string[] = "Hello World!\r\n";
        usart_write_buffer_wait(&usart_instance, string, sizeof(string));
        uint16_t temp;
        while (true)
                if (usart_read_wait(&usart_instance, &temp) == STATUS_OK)
                {            while (usart_write_wait(&usart_instance, temp) != STATUS_OK)
为何这般累| | 2017-11-15 16:28 | 只看该作者
如果选择USART的复用功能PB08 PB09上呢,PB08发,PB09收
ddllxxrr|  楼主 | 2017-11-15 20:41 | 只看该作者
重新配置一下
为何这般累| | 2017-11-16 10:16 | 只看该作者
解决了,谢谢
个人签名:http://shop34182318.taobao.com/ http://shop562064536.taobao.com
2394
