发新帖我要提问
返回列表
5509A的板子,其中一块运行简单MCBSP收发程序的问题
nbn| | 2018-10-30 10:28 | 显示全部楼层
感觉楼主是厉害,我现在跟着楼主编了一下MIC回放的程序,发现声音无法回放。不过line in的回放可以。
/*数字音频接口格式设置
AIC23为主模式,数据为DSP模式,数据长度16位*/
Uint16 digital_audio_inteface_format[2]={0x0e,0x53};
//Uint16 digital_audio_inteface_format[2]={0x0e,0x43};
/*AIC23的波特率设置,采样率为44.1K*/
//Uint16 sample_rate_control[2] = {0x10,0x20};//采样频率注意这个数据
//Uint16 sample_rate_control[2] = {0x10,0x23};
/*AIC23的波特率设置,采样率为8K*/
Uint16 sample_rate_control[2] = {0x10,0x2F};
/*AIC23寄存器复位*/
Uint16 reset[2] ={0x1e,0x00};
/*AIC23节电方式设置,所有部分均所与工作状态*/
//Uint16 power_down_control[2] ={0x0c,0x01};//工作状态可修改
Uint16 power_down_control[2] ={0x0c,0x00};//工作状态可修改
/*AIC23模拟音频的控制
DAC使能,ADC输入选择为Line*/
//Uint16 analog_aduio_path_control[2] ={0x08,0x10};
/*AIC23模拟音频的控制
DAC使能,ADC输入选择为MIC*/
//Uint16 analog_aduio_path_control[2] ={0x08,0x14};
Uint16 analog_aduio_path_control[2] ={0x08,0x17};
/*AIC23数字音频通路的控制*/
Uint16 digital_audio_path_control[2] ={0x0a,0x05};
/*AIC23数字接口的使能*/
Uint16 digital_interface_activation[2] ={0x12,0x01};
/*AIC23左通路音频调节*/
//Uint16 left_line_input_volume_control[2] ={0x00,0x17};
/*AIC23右通路音频调节*/
//Uint16 right_line_input_volume_control[2] ={0x02,0x17};
//*AIC23左通路音频调节*/
Uint16 left_mic_input_volume_control[2] ={0x04,0x79};
//*AIC23右通路音频调节*/
Uint16 right_mic_input_volume_control[2] ={0x06,0x79};
/*AIC23耳机左通路音频调节*/
Uint16 left_headphone_volume_control[2] ={0x05,0x79};
/*AIC23耳机右通路音频调节*/
Uint16 right_headphone_volume_control[2] = {0x07,0x79};
不清楚什么问题
