怎么malloc经常会返回NULL?(keil lpc23xx)
3557|0
shkliu|  楼主 | 2007-2-11 17:38 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
compiler: keil arm
cpu:      lpc2378
在startup.s
;*   startup.s: startup file for NXP LPC230x Family Microprocessors
;*   Copyright(C) 2006, NXP Semiconductor
;*   All rights reserved.
;*   History
;*   2006.09.01  ver 1.00    Prelimnary version, first Release
    PRESERVE8
; *  The STARTUP.S code is executed after CPU Reset. This file may be
; *  translated with the following SET symbols. In uVision these SET
; *  symbols are entered under Options - ASM - Define.
; *  REMAP: when set the startup code initializes the register MEMMAP
; *  which overwrites the settings of the CPU configuration pins. The
; *  startup and interrupt vectors are remapped from:
; *     0x00000000  default setting (not remapped)
; *     0x40000000  when RAM_MODE is used
; *  RAM_MODE: when set the device is configured for code execution
; *  from on-chip RAM starting at address 0x40000000.
; Standard definitions of Mode bits and Interrupt (I & F) flags in PSRs
Mode_USR        EQU     0x10
Mode_FIQ        EQU     0x11
Mode_IRQ        EQU     0x12
Mode_SVC        EQU     0x13
Mode_ABT        EQU     0x17
Mode_UND        EQU     0x1B
Mode_SYS        EQU     0x1F
I_Bit           EQU     0x80            ; when I bit is set, IRQ is disabled
F_Bit           EQU     0x40            ; when F bit is set, FIQ is disabled
;// <h> Stack Configuration (Stack Sizes in Bytes)
;//   <o0> Undefined Mode      <0x0-0xFFFFFFFF:8>
;//   <o1> Supervisor Mode     <0x0-0xFFFFFFFF:8>
;//   <o2> Abort Mode          <0x0-0xFFFFFFFF:8>
;//   <o3> Fast Interrupt Mode <0x0-0xFFFFFFFF:8>
;//   <o4> Interrupt Mode      <0x0-0xFFFFFFFF:8>
;//   <o5> User/System Mode    <0x0-0xFFFFFFFF:8>
;// </h>
UND_Stack_Size  EQU     0x00000004
SVC_Stack_Size  EQU     0x00000100
ABT_Stack_Size  EQU     0x00000004
FIQ_Stack_Size  EQU     0x00000004
IRQ_Stack_Size  EQU     0x00000100
USR_Stack_Size  EQU     0x00001000;modify by sliu
Stack_Size      EQU     (UND_Stack_Size + SVC_Stack_Size + ABT_Stack_Size +                          FIQ_Stack_Size + IRQ_Stack_Size + USR_Stack_Size)
                AREA    STACK, NOINIT, READWRITE, ALIGN=3
Stack_Mem       SPACE   Stack_Size
Stack_Top       EQU     Stack_Mem + Stack_Size
;// <h> Heap Configuration
;//   <o>  Heap Size (in Bytes) <0x0-0xFFFFFFFF>
;// </h>
Heap_Size       EQU     0x00002240
                AREA    HEAP, NOINIT, READWRITE, ALIGN=3
Heap_Mem        SPACE   Heap_Size
; Area Definition and Entry Point
;  Startup Code must be linked first at Address at which it expects to run.
                AREA    RESET, CODE, READONLY
                ARM
; Exception Vectors
;  Mapped to Address 0.
;  Absolute addressing mode must be used.
;  Dummy Handlers are implemented as infinite loops which can be modified.
Vectors         LDR     PC, Reset_Addr
                LDR     PC, Undef_Addr
                LDR     PC, SWI_Addr
                LDR     PC, PAbt_Addr
                LDR     PC, DAbt_Addr
                NOP                            ; Reserved Vector
;               LDR     PC, IRQ_Addr
                LDR     PC, [PC, #-0x0120]     ; Vector from VicVectAddr
                LDR     PC, FIQ_Addr
Reset_Addr      DCD     Reset_Handler
Undef_Addr      DCD     Undef_Handler
SWI_Addr        DCD     SWI_Handler
PAbt_Addr       DCD     PAbt_Handler
DAbt_Addr       DCD     DAbt_Handler
                DCD    0xB9206E28             ; Reserved Address
IRQ_Addr        DCD     IRQ_Handler
FIQ_Addr        DCD     FIQ_Handler
Undef_Handler   B       Undef_Handler
SWI_Handler     B       SWI_Handler
PAbt_Handler    B       PAbt_Handler
DAbt_Handler    B       DAbt_Handler
IRQ_Handler     B       IRQ_Handler
FIQ_Handler     B       FIQ_Handler
; Reset Handler
                EXPORT  Reset_Handler
Reset_Handler
; Setup Stack for each mode
                LDR     R0, =Stack_Top
;  Enter Undefined Instruction Mode and set its Stack Pointer
                MSR     CPSR_c, #Mode_UND:OR:I_Bit:OR:F_Bit
                MOV     SP, R0
                SUB     R0, R0, #UND_Stack_Size
;  Enter Abort Mode and set its Stack Pointer
                MSR     CPSR_c, #Mode_ABT:OR:I_Bit:OR:F_Bit
                MOV     SP, R0
                SUB     R0, R0, #ABT_Stack_Size
;  Enter FIQ Mode and set its Stack Pointer
                MSR     CPSR_c, #Mode_FIQ:OR:I_Bit:OR:F_Bit
                MOV     SP, R0
                SUB     R0, R0, #FIQ_Stack_Size
;  Enter IRQ Mode and set its Stack Pointer
                MSR     CPSR_c, #Mode_IRQ:OR:I_Bit:OR:F_Bit
                MOV     SP, R0
                SUB     R0, R0, #IRQ_Stack_Size
;  Enter Supervisor Mode and set its Stack Pointer
                MSR     CPSR_c, #Mode_SVC:OR:I_Bit:OR:F_Bit
                MOV     SP, R0
                SUB     R0, R0, #SVC_Stack_Size
;  Enter User Mode and set its Stack Pointer
                MSR     CPSR_c, #Mode_USR
                MOV     SP, R0
                SUB     SL, SP, #USR_Stack_Size
                ;BL         __user_initial_stackheap
                IMPORT    TargetResetInit
                BL        TargetResetInit
; Enter the C code
                IMPORT  __main
                LDR     R0, =__main
                BX      R0
; User Initial Stack & Heap
                AREA    |.text|, CODE, READONLY
                IMPORT  __use_two_region_memory
                EXPORT  __user_initial_stackheap
                LDR     R0, =  Heap_Mem
                LDR     R1, =(Stack_Mem + USR_Stack_Size)
                LDR     R2, = (Heap_Mem +      Heap_Size)
                LDR     R3, = Stack_Mem
                BX      LR
                END
我已经给了heapsize.
谢谢!
