masege 发表于 2015-7-24 17:10
c64+ 的FFT问题
目前在研究FFT的问题。C64+有专门的FFT函数库: void DSP_fft16x16(short *w, int nx, short *x, short *y)16 bits 复输入输出数据,复数按先实部/后虚部交织存放除最后一级外,每级的结果右移 1 并四舍五入
void DSP_fft16x16r(int nx, short *x, short *w, short *y,int radix, int offset, int n_max)16 bits 复输入输出数据,复数按先实部/后虚部交织存放除最后一级外,每级的结果右移 1 并四舍五入针对比较小的 Cache 优化)
void DSP_fft32x32(int *w, int nx, int *x, int *y)32 bits 复输入输出数据,复数按先实部/后虚部交织存放32 bits 旋转因子。
void DSP_fft32x32s(int *w, int nx, int *x, int *y)32 bits 复输入输出数据,复数按先实部/后虚部交织存放32 bits 旋转因子除最后一级外,每级的结果右移 1
旋转因子(w)的产生是由tw_fft16x16 产生。现在问题来了,样才能结合它使用 DSP_fft16x16进行FFT变换。这个tw_fft16x16在库函数里面有.exe的应用程序,不知道怎么用。能不能给一个FFT变换的实例。求大神解答。
海中水 发表于 2015-7-24 17:49
没有接触过希望用到的大神帮忙解答。
aresc 发表于 2015-7-25 22:04
你把这几个函数的原版的函数说明贴出来看看!
/*TEXAS INSTRUMENTS, INC.                                                 */
/*NAME        */
/*      tw_fft16x16                                                         */
/*USAGE        */
/*      This is a stand-alone program intended to generate twiddle-factor   */
/*      arrays for the DSP_fft, DSP_fft16x16r and DSP_fft16x16t FFT         */
/*      library routines.It is called as follows:                         */
/*          tw_fft16x16 [-s scale] N > outputfile.c                         */
/*      The argument 'N' specifies the size of the FFT.This value         */
/*      must be a power of 2.The switch '-s scale' allows selecting       */
/*      a different scale factor for the coefficients.The default         */
/*      scale factor is 32767.5.                                          */
/*      This program will generate the twiddle factor array 'w' and         */
/*      output the result to the display.Redirect the output to         */
/*      a file as shown above.                                              */
/*DESCRIPTION                                                             */
/*      This program contains the twiddle-factor generation routine         */
/*      that is described within the source code for the DSPLIB             */
/*      FFT functions DSP_fft16x16r and DSP_fft16x16t.It does not         */
/*      produce appropriate twiddle-factor arrays for the other FFT         */
/*      implementations.                                                    */
/*      Please consult the specific FFT that you are using for details.   */
/*      The final twiddle-factor array generated by the routine will      */
/*      be 2 * N elements long.                                             */
/*NOTES        */
/*      The code below may be adapted to run directly on the target,      */
/*      rather than running as a separate program running off-line.         */
/*      Such adaptation is not recommended for time-critical applications.*/
/*      To adapt this program, remove the 'usage' and 'main' functions,   */
/*      and call 'gen_twiddle' directly.                                    */
/*            Copyright (c) 2001 Texas Instruments, Incorporated.         */
/*                           All Rights Reserved.                           */
#include <math.h>
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <ctype.h>
#ifndef PI
# ifdef M_PI
#define PI M_PI
# else
#define PI 3.14159265358979323846
# endif
#endif
/*D2S -- Truncate a 'double' to a 'short', with clamping.               */
static short d2s(double d)
    if (d >=32767.0) return32767;
    if (d <= -32768.0) return -32768;
    return (short)d;
/*GEN_TWIDDLE -- Generate twiddle factors for TI's custom FFTs.         */
/*USAGE        */
/*      This routine is called as follows:                                  */
/*          int gen_twiddle(short *w, int n, double scale)                  */
/*          short*w   Pointer to twiddle-factor array                   */
/*          int    n      Size of FFT                                       */
/*          double scaleScale factor to apply to values.                  */
/*      The routine will generate the twiddle-factors directly into the   */
/*      array you specify.The array needs to be approximately 2*N         */
/*      elements long.(The actual size, which is slightly smaller, is   */
/*      returned by the function.)                                          */
    int i, j, k;
    for (j = 1, k = 0; j < n >> 2; j = j << 2)
      for (i = 0; i < n >> 2; i += j << 1)
            w = d2s(scale * cos(6.0 * PI * (i + j) / n));
            w = d2s(scale * sin(6.0 * PI * (i + j) / n));
            w = d2s(scale * cos(6.0 * PI * (i    ) / n));
            w = d2s(scale * sin(6.0 * PI * (i    ) / n));
            w = d2s(scale * cos(4.0 * PI * (i + j) / n));
            w = d2s(scale * sin(4.0 * PI * (i + j) / n));
            w = d2s(scale * cos(4.0 * PI * (i    ) / n));
            w = d2s(scale * sin(4.0 * PI * (i    ) / n));
            w = d2s(scale * cos(2.0 * PI * (i + j) / n));
            w = d2s(scale * sin(2.0 * PI * (i + j) / n));
            w = d2s(scale * cos(2.0 * PI * (i    ) / n));
            w = d2s(scale * sin(2.0 * PI * (i    ) / n));
            k += 12;
    return k;
/*USAGE -- Print usage information and optionally an error message.       */
void usage(char *error)
    fprintf(stderr,
"        \n"
"USAGE        \n"
"    This is a stand-alone program intended to generate twiddle-factor   \n"
"    arrays for the DSP_fft, DSP_fft16x16r and DSP_fft16x16t FFT         \n"
"    library routines.It is called as follows:                         \n"
"        \n"
"      tw_fft16x16 [-s scale] N > outputfile.c                         \n"
"        \n"
"    The argument 'N' specifies the size of the FFT.This value         \n"
"    must be a power of 2.The switch '-s scale' allows selecting       \n"
"    a different scale factor for the coefficients.The default         \n"
"    scale factor is 32767.5.                                          \n"
"        \n"
"    This program will generate the twiddle factor array 'w' and         \n"
"    output the result to the display.Redirect the output to         \n"
"    a file as shown above.                                              \n"
"        \n");
    if (error)
      fprintf(stderr, "ERROR:%s\n", error);
    exit(1);
/*MAIN -- Where the action happens.                                       */
int main(int argc, char *argv[])
    int i, n = -1, size;
    int is_pow_4 = 0;
    short *w;
    double scale = 32767.5;
    char *s;
    char buf;
    /*Parse the arguments.                                                */
    if (argc < 2) { usage(NULL); }
    while (argc-->1)
      if (**++argv == '-' || **argv == '/')
            switch (argv)
                case 's' : case 'S' :
                  if (argv)
                        s = &argv;
                  } else
                        argc--;
                        s = *++argv;
                  if (!s || !*s || sscanf(s, "%lf", &scale) != 1)
                        usage("The -s switch requires a numeric argument.\n");
                  if (scale <= 0.0 || scale >32767.6)
                        usage("Scale factor out of range.\n");
                  break;
                default:
                  sprintf(buf, "Unrecognized switch character: '%c'\n",
                            argv);
                  usage(buf);
                  break;
      } else
            if (!isdigit(argv) || sscanf(argv, "%d", &n) != 1)
                sprintf(buf, "Unrecognized argument:%-.32s\n",
                        argv);
                usage(buf);
            if (n < 16 || n > 32768)
                usage("FFT size must be between 16 and 32768 points.");
            for (i = 2; i < 24; i++)
                if ((1 << i) == n) break;
            is_pow_4 = !(i & 1);
            if (i >= 24)
                usage("FFT size must be a power of 2\n");
                exit(1);
    if (n == -1)
      usage("Must specify FFT size.");
    /*Allocate memory for the FFT twiddle factors.                        */
    w = calloc(2 * sizeof(short), n);
    if (!w)
      fprintf(stderr, "ERROR:Unable to allocate memory for "
                        "twiddle factors\n");
      exit(1);
    /*Generate the twiddle-factor array.                                  */
    size = gen_twiddle(w, n, scale);
    /*Print out the resulting twiddle factors.                            */
    printf(
"/* -------------------------------------------------------------------- */\n"
"/*Automatically generated twiddle-factor array.                     */\n"
"/*      Number of points:    %-5d                                    */\n"
"/*      Scale factor:      %-20.9f                     */\n"
"/*      Appropriate FFTs:    DSP_fft16x16r, DSP_fft16x16t%s      */\n"
"/*      Required alignment:8 byte (double-word)                     */\n"
"/* -------------------------------------------------------------------- */\n",
      n, scale, is_pow_4 ? ", DSP_fft" : "         ");
    printf("#pragma DATA_ALIGN(w, 8);\n");
    printf("const short w =\n{", size / 2);
    for (i = 0; i < size; i++)
      printf("%s%c0x%.4X",
               i == 0 ? "\n    " : (i & 7) == 0 ? ",\n    " : ", ",
               w < 0 ? '-' : ' ', abs(w));
    printf("\n};\n");
    return 0;
DSP-fft的只有.h文件
aresc 发表于 2015-7-27 21:04
所有FFT中的twiddle factor都是正弦、余弦表,但可能不同FFT的实现方法,具体的twiddle不一样。
那个默认的32767.5的用处是把[-1.0,1.0]的正弦、余弦值转成16位的定点整数而已。因为
   return (short)d;
所以scale值不能超过2^16次方,
我不太明白 “除最后一级外,每级的结果右移 1 并四舍五入”,所以让你贴英文的函数说明看看。
另外short *y是个什么用处?难道不是同址运算?
void DSP_fft16x16(short *w, int nx, short *x, short *y)16 bits 复输入输出数据,复数按先实部/后虚部交 ...
谢谢~short*y 是输出的傅立叶变换数组地址。 我再贴一个 DSP_fft32x32(int *w, int nx, int *x, int *y)的说明,麻烦您再看看。有个问题:在使用我DSP_fft32x32(int *w, int nx, int *x, int *y)的时候,我如何知道*w呢,是调用gen_twiddle_fft32x32 这个函数产生一个数组吗或者其他?
DSP_fft32x32
谢谢~short*y 是输出的傅立叶变换数组地址。 我再贴一个 DSP_fft32x32(int *w, int nx, int *x, int *y) ...
是的!
页: [1]
查看完整版本: c64+ 的FFT问题
