alice84 发表于 2007-10-12 16:09
电子电路英文缩写一览
AC(alternating&nbsp;current)&nbsp;交流(电)<br />A/D(analog&nbsp;to&nbsp;digital)&nbsp;模拟/数字转换<br />ADC(analog&nbsp;to&nbsp;digital&nbsp;convertor)&nbsp;模拟/数字转换器<br />ADM(adaptive&nbsp;delta&nbsp;modulation)&nbsp;自适应增量调制<br />ADPCM(adaptive&nbsp;differential&nbsp;pulse&nbsp;code&nbsp;modulation)&nbsp;自适应差分脉冲编码调制<br />ALU(arithmetic&nbsp;logic&nbsp;unit)&nbsp;算术逻辑单元<br />ASCII(American&nbsp;standard&nbsp;code&nbsp;for&nbsp;information&nbsp;interchange)&nbsp;美国信息交换标准码<br />AV(audio&nbsp;visual)&nbsp;声视,视听<br />BCD(binary&nbsp;coded&nbsp;decimal)&nbsp;二进制编码的十进制数<br />BCR(bi-directional&nbsp;controlled&nbsp;rectifier)双向晶闸管&nbsp;<br />BCR(buffer&nbsp;courtier&nbsp;reset)&nbsp;缓冲计数器<br />BZ(buzzer)&nbsp;蜂鸣器,蜂音器<br />C(capacitance,capacitor)&nbsp;电容量,电容器<br />CATV(cable&nbsp;television)&nbsp;电缆电视<br />CCD(charge-coupled&nbsp;device)&nbsp;电荷耦合器件<br />CCTV(closed-circuit&nbsp;television)&nbsp;闭路电视<br />CMOS(complementary)&nbsp;互补MOS<br />CPU(central&nbsp;processing&nbsp;unit)中央处理单元<br />CS(control&nbsp;signal)&nbsp;控制信号<br />D(diode)&nbsp;二极管<br />DAST(direct&nbsp;analog&nbsp;store&nbsp;technology)&nbsp;直接模拟存储技术<br />DC(direct&nbsp;current)&nbsp;直流<br />DIP(dual&nbsp;in-line&nbsp;package)&nbsp;双列直插封装&nbsp;<br /><br />字串7<br /><br />DP(dial&nbsp;pulse)&nbsp;拨号脉冲<br />DRAM(dynamic&nbsp;random&nbsp;access&nbsp;memory)&nbsp;动态随机存储器<br />DTL(diode-transistor&nbsp;logic)&nbsp;二极管晶体管逻辑<br />DUT(device&nbsp;under&nbsp;test)&nbsp;被测器件<br />DVM(digital&nbsp;voltmeter)&nbsp;数字电压表<br />ECG(electrocardiograph)&nbsp;心电图<br />ECL(emitter&nbsp;coupled&nbsp;logic)&nbsp;射极耦合逻辑<br />EDI(electronic&nbsp;data&nbsp;interchange)&nbsp;电子数据交换<br />EIA(Electronic&nbsp;Industries&nbsp;Association)&nbsp;电子工业联合会<br />EOC(end&nbsp;of&nbsp;conversion)&nbsp;转换结束<br />EPROM(erasable&nbsp;programmable&nbsp;read&nbsp;only&nbsp;memory)&nbsp;可擦可编程只读存储器<br />EEPROM(electrically&nbsp;EPROM)&nbsp;电可擦可编程只读存储器<br />ESD(electro-static&nbsp;discharge)&nbsp;静电放电&nbsp;<br />FET(field-effect&nbsp;transistor)&nbsp;场效应晶体管<br />FS(full&nbsp;scale)&nbsp;满量程<br />F/V(frequency&nbsp;to&nbsp;voltage&nbsp;convertor)&nbsp;频率/电压转换<br />FM(frequency&nbsp;modulation)&nbsp;调频<br />FSK(frequency&nbsp;shift&nbsp;keying)&nbsp;频移键控<br />FSM(field&nbsp;strength&nbsp;meter)&nbsp;场强计<br />FST(fast&nbsp;switching&nbsp;shyster)&nbsp;快速晶闸管<br />FT(fixed&nbsp;time)&nbsp;固定时间<br />FU(fuse&nbsp;unit)&nbsp;保险丝装置<br />FWD(forward)&nbsp;正向的<br />GAL(generic&nbsp;array&nbsp;logic)&nbsp;通用阵列逻辑<br />GND(ground)&nbsp;接地,地线<br />GTO(Sate&nbsp;turn&nbsp;off&nbsp;thruster)&nbsp;门极可关断晶体管&nbsp;字串2&nbsp;<br />HART(highway&nbsp;addressable&nbsp;remote&nbsp;transducer)&nbsp;可寻址远程传感器数据公路<br />HCMOS(high&nbsp;density&nbsp;COMS)&nbsp;高密度互补金属氧化物半导体(器件)<br />HF(high&nbsp;frequency)&nbsp;高频<br />HTL(high&nbsp;threshold&nbsp;logic)&nbsp;高阈值逻辑电路<br />HTS(heat&nbsp;temperature&nbsp;sensor)&nbsp;热温度传感器<br />IC(integrated&nbsp;circuit)&nbsp;集成电路<br />ID(international&nbsp;data)&nbsp;国际数据<br />IGBT(insulated&nbsp;gate&nbsp;bipolar&nbsp;transistor)&nbsp;绝缘栅双极型晶体管<br />IGFET(insulated&nbsp;gate&nbsp;field&nbsp;effect&nbsp;transistor)&nbsp;绝缘栅场效应晶体管<br />I/O(input/output)&nbsp;输入/输出<br />I/V(current&nbsp;to&nbsp;voltage&nbsp;convertor)&nbsp;电流-电压变换器<br />IPM(incidental&nbsp;phase&nbsp;modulation)&nbsp;附带的相位调制<br />IPM(intelligent&nbsp;power&nbsp;module)&nbsp;智能功率模块<br />IR(infrared&nbsp;radiation)&nbsp;红外辐射<br />IRQ(interrupt&nbsp;request)&nbsp;中断请求<br />JFET(junction&nbsp;field&nbsp;effect&nbsp;transistor)&nbsp;结型场效应晶体管<br />LAS(light&nbsp;activated&nbsp;switch)光敏开关<br />LASCS(light&nbsp;activated&nbsp;silicon&nbsp;controlled&nbsp;switch)&nbsp;光控可控硅开关<br />LCD(liquid&nbsp;crystal&nbsp;display)&nbsp;液晶显示器<br />LDR(light&nbsp;dependent&nbsp;resistor)&nbsp;光敏电阻<br />LED(light&nbsp;emitting&nbsp;diode)&nbsp;发光二极管<br />LRC(longitudinal&nbsp;redundancy&nbsp;check)&nbsp;纵向冗余(码)校验&nbsp;<br />字串2<br /><br /><br />LSB(least&nbsp;significant&nbsp;bit)&nbsp;最低有效位<br />LSI(1arge&nbsp;scale&nbsp;integration)&nbsp;大规模集成电路<br />M(motor)&nbsp;电动机<br />MCT(MOS&nbsp;controlled&nbsp;gyrator)&nbsp;场控晶闸管<br />MIC(microphone)&nbsp;话筒,微音器,麦克风<br />min(minute)&nbsp;分<br />MOS(metal&nbsp;oxide&nbsp;semiconductor)金属氧化物半导体<br />MOSFET(metal&nbsp;oxide&nbsp;semiconductor&nbsp;FET)&nbsp;金属氧化物半导体场效应晶体管<br />N(negative)&nbsp;负<br />NMOS(N-channel&nbsp;metal&nbsp;oxide&nbsp;semiconductor&nbsp;FET)&nbsp;N沟道MOSFET<br />NTC(negative&nbsp;temperature&nbsp;coefficient)&nbsp;负温度系数<br />OC(over&nbsp;current)&nbsp;过电流<br />OCB(overload&nbsp;circuit&nbsp;breaker)&nbsp;过载断路器<br />OCS(optical&nbsp;communication&nbsp;system)&nbsp;光通讯系统<br />OR(type&nbsp;of&nbsp;logic&nbsp;circuit)&nbsp;或逻辑电路<br />OV(over&nbsp;voltage)&nbsp;过电压<br />P(pressure)&nbsp;压力<br />FAM(pulse&nbsp;amplitude&nbsp;modulation)&nbsp;脉冲幅度调制<br />PC(pulse&nbsp;code)&nbsp;脉冲码<br />PCM(pulse&nbsp;code&nbsp;modulation)&nbsp;脉冲编码调制<br />PDM(pulse&nbsp;duration&nbsp;modulation)&nbsp;脉冲宽度调制<br />PF(power&nbsp;factor)&nbsp;功率因数<br />PFM(pulse&nbsp;frequency&nbsp;modulation)&nbsp;脉冲频率调制<br />PG(pulse&nbsp;generator)&nbsp;脉冲发生器<br />PGM(programmable)&nbsp;编程信号<br />PI(proportional-integral(controller))&nbsp;比例积分(控制器)&nbsp;<br />字串9<br /><br /><br />PID(proportional-integral-differential(controller))比例积分微分(控制器)<br />PIN(positive&nbsp;intrinsic-negative)&nbsp;光电二极管<br />PIO(parallel&nbsp;input&nbsp;output)&nbsp;并行输入输出<br />PLD(phase-locked&nbsp;detector)&nbsp;同相检波<br />PLD(phase-locked&nbsp;discriminator)&nbsp;锁相解调器<br />PLL(phase-locked&nbsp;loop)&nbsp;锁相环路<br />PMOS(P-channel&nbsp;metal&nbsp;oxide&nbsp;semiconductor&nbsp;FET)&nbsp;P沟道MOSFET<br />P-P(peak-to-peak)&nbsp;峰--峰<br />PPM(pulse&nbsp;phase&nbsp;modulation)&nbsp;脉冲相位洲制<br />PRD(piezoelectric&nbsp;radiation&nbsp;detector)&nbsp;热电辐射控测器<br />PROM(programmable&nbsp;read&nbsp;only&nbsp;memory)&nbsp;可编只读程存储器<br />PRT(platinum&nbsp;resistance&nbsp;thermometer)&nbsp;铂电阻温度计<br />PRT(pulse&nbsp;recurrent&nbsp;time)&nbsp;脉冲周期时间<br />PUT(programmable&nbsp;unijunction&nbsp;transistor)&nbsp;可编程单结晶体管<br />PWM(pulse&nbsp;width&nbsp;modulation)&nbsp;脉宽调制<br />R(resistance,resistor)&nbsp;电阻,电阻器<br />RAM(random&nbsp;access&nbsp;memory)&nbsp;随机存储器<br />RCT(reverse&nbsp;conducting&nbsp;thyristor)&nbsp;逆导晶闸管<br />REF(reference)&nbsp;参考,基准<br />REV(reverse)&nbsp;反转<br />R/F(radio&nbsp;frequency)&nbsp;射频<br />RGB(red/green/blue)&nbsp;红绿蓝<br />ROM(read&nbsp;only&nbsp;memory)&nbsp;只读存储器<br />RP(resistance&nbsp;potentiometer)&nbsp;电位器&nbsp;字串3&nbsp;<br />RST(reset)&nbsp;复位信号<br />RT(resistor&nbsp;with&nbsp;inherent&nbsp;variability&nbsp;dependent)&nbsp;热敏电阻<br />RTD(resistance&nbsp;temperature&nbsp;detector)&nbsp;电阻温度传感器<br />RTL(resistor&nbsp;transistor&nbsp;logic)&nbsp;电阻晶体管逻辑(电路)<br />RV(resistor&nbsp;with&nbsp;inherent&nbsp;variability&nbsp;dependent&nbsp;on&nbsp;the&nbsp;voltage)&nbsp;压敏电阻器<br />SA(switching&nbsp;assembly)&nbsp;开关组件<br />SBS(silicon&nbsp;bi-directional&nbsp;switch)&nbsp;硅双向开关,双向硅开关<br />SCR(silicon&nbsp;controlled&nbsp;rectifier)&nbsp;可控硅整流器<br />SCS(safety&nbsp;control&nbsp;switch)&nbsp;安全控制开关<br />SCS(silicon&nbsp;controlled&nbsp;switch)&nbsp;可控硅开关<br />SCS(speed&nbsp;control&nbsp;system)&nbsp;速度控制系统<br />SCS(supply&nbsp;control&nbsp;system)&nbsp;电源控制系统<br />SG(spark&nbsp;gap)&nbsp;放电器<br />SIT(static&nbsp;induction&nbsp;transformer)&nbsp;静电感应晶体管<br />SITH(static&nbsp;induction&nbsp;thyristor)&nbsp;静电感应晶闸管<br />SP(shift&nbsp;pulse)&nbsp;移位脉冲<br />SPI(serial&nbsp;peripheral&nbsp;interface)&nbsp;串行外围接口<br />SR(sample&nbsp;realy,saturable&nbsp;reactor)&nbsp;取样继电器,饱和电抗器<br />SR(silicon&nbsp;rectifier)&nbsp;硅整流器<br />SRAM(static&nbsp;random&nbsp;access&nbsp;memory)&nbsp;静态随机存储器<br />SSR(solid-state&nbsp;relay)&nbsp;固体继电器<br />SSR(switching&nbsp;select&nbsp;repeater)&nbsp;中断器开关选择器&nbsp;<br />字串8<br /><br /><br />SSS(silicon&nbsp;symmetrical&nbsp;switch)&nbsp;硅对称开关,双向可控硅<br />SSW(synchro-switch)&nbsp;同步开关<br />ST(start)&nbsp;启动<br />ST(starter)&nbsp;启动器<br />STB(strobe)&nbsp;闸门,选通脉冲<br />T(transistor)&nbsp;晶体管,晶闸管<br />TACH(tachometer)&nbsp;转速计,转速表<br />TP(temperature&nbsp;probe)&nbsp;温度传感器<br />TRIAC(triodes&nbsp;AC&nbsp;switch)&nbsp;三极管交流开关<br />TTL(transistor-transistor&nbsp;logic)&nbsp;晶体管一晶体管逻辑<br />TV(television)&nbsp;电视<br />UART(universal&nbsp;asynchronous&nbsp;receiver&nbsp;transmitter)&nbsp;通用异步收发器<br />VCO(voltage&nbsp;controlled&nbsp;oscillator)&nbsp;压控振荡器<br />VD(video&nbsp;decoders)&nbsp;视频译码器<br />VDR(voltage&nbsp;dependent&nbsp;resistor)&nbsp;压敏电阻<br />VF(video&nbsp;frequency)&nbsp;视频<br />V/F(voltage-to-frequency)&nbsp;电压/频率转换<br />V/I(voltage&nbsp;to&nbsp;current&nbsp;convertor)&nbsp;电压-电流变换器<br />VM(voltmeter)&nbsp;电压表<br />VS(vacuum&nbsp;switch)&nbsp;电子开关<br />VT(visual&nbsp;telephone)&nbsp;电视电话<br />VT(video&nbsp;terminal)&nbsp;视频终端&nbsp;<br />字串9<br /><br />
alice84 发表于 2007-10-13 16:35
谁给加了裤裤?
https://bbs.21ic.com/upfiles/img/200710/20071013163513116.gif
ITXSS 发表于 2007-10-14 11:24
很棒
我正需要这些资料呢
hhblxm 发表于 2007-10-14 14:36
请问平时说的晶体的频率度是指什么?
一般手册里面有几个参数:<br />Frequency&nbsp;Tolerance<br />Frequency&nbsp;Stability<br />还有老化率<br />是上面的哪一个呢,还是它们综合的结果?
hhblxm 发表于 2007-10-14 14:38
请问平时说的晶体的频率稳定度是指什么?
一般手册里面有如下参数:<br />Frequency&nbsp;Tolerance<br />Frequency&nbsp;Stability<br />还有老化率<br /><br />请问频率稳定度是它们之一吗还是,它们的综合呢?
alice84 发表于 2007-10-14 14:41
我是一只菜菜鸟.我想是....
Frequency&nbsp;Stability<br /><br /><br />错了不关我事!不负责!https://bbs.21ic.com/upfiles/img/200710/20071014144115687.gif
jiangleyi 发表于 2007-10-16 21:43
haotie
yzqok 发表于 2007-10-17 19:54
很棒
alice84 发表于 2007-10-17 20:33
最近收集这些资料,这只是冰山一脚!
RabbitZeng 发表于 2007-10-18 13:11
我想了解更多,谁能发给我呀!谢谢了
我想了解更多,谁能发给我呀!谢谢了
雁过留痕 发表于 2007-10-18 20:52
00
在一个IC中~叫做LM723CN的有个引脚的缩写是F/C不知道表示什么意思?~看了下资料`说的是FREQ/COMP~不知道这是什么意思~有人知道么?
zjxing1122 发表于 2007-10-21 22:29
这些都是我们没想到的&nbsp;,
tangbohoo 发表于 2007-10-22 19:14
哈哈。。好帖。。
123654789 发表于 2007-10-22 19:20
电视机 里面有个 AGC 电路
楼主&nbsp;&nbsp;还缺少&nbsp;&nbsp;了&nbsp;这个&nbsp;AGC&nbsp;的解析<br /><br />AGC&nbsp;&nbsp;&nbsp;Auto&nbsp;Gain&nbsp;Control<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;自动&nbsp;&nbsp;增益&nbsp;控制<br /><br />还有&nbsp;AFC&nbsp;自动频率控制<br /><br />&nbsp;&nbsp;&nbsp;其中&nbsp;F&nbsp;=&nbsp;Frequence
wjcy131421 发表于 2007-10-22 20:05
多谢拉 ~!~
taoyubai 发表于 2007-10-23 16:07
早就有了,不过还是帮你顶,值得鼓励
hxq031 发表于 2007-10-24 15:54
好东西
要好好学习学习了,呵呵!
sdhz 发表于 2007-10-24 18:50
不错,好东西
yanxuyuan 发表于 2007-10-25 10:15
谢了
谢了
唐龙80 发表于 2007-10-28 08:42
蛮全面的
在哪里下的这些好东东啊?
页: [1] 2 3 4
查看完整版本: 电子电路英文缩写一览
