kaikaisi 发表于 2015-8-17 17:20
imx6
在运行./ltib命令时报错:
/usr/include/linux/fs.h:22:24: fatal error: asm/atomic.h: No such file or directory
compilation terminated.
make: *** Error 1
error: Bad exit status from /home/kaikai/imx6/L3.0.35_4.1.0_130816_source/source/ltib/tmp/rpm-tmp.89482 (%build)
RPM build errors:
Build time for mtd-utils: 9 seconds
Failed building mtd-utils
Died at ./ltib line 1392.
traceback:
main::build_host_rpms:1392
main::host_checks:1447
   main:554
Started: Mon Aug 17 16:34:35 2015
Ended:   Mon Aug 17 16:34:44 2015
Elapsed: 9 seconds
These packages failed to build:
mtd-utils
Build Failed
页: [1]
查看完整版本: imx6
