SI4463用WDS3生成的配置无法使用,求高手指导?
配置是用WDS3生成的配置:#define RADIO_CONFIGURATION_DATA_ARRAY { \
0x07, RF_POWER_UP, \
0x08, RF_GPIO_PIN_CFG, \
0x06, RF_GLOBAL_XO_TUNE_2, \
0x05, RF_GLOBAL_CONFIG_1, \
0x06, RF_INT_CTL_ENABLE_2, \
0x08, RF_FRR_CTL_A_MODE_4, \
0x0D, RF_PREAMBLE_TX_LENGTH_9, \
0x0A, RF_SYNC_CONFIG_6, \
0x0B, RF_PKT_CRC_CONFIG_7, \
0x10, RF_PKT_LEN_12, \
0x10, RF_PKT_FIELD_2_CRC_CONFIG_12, \
0x10, RF_PKT_FIELD_5_CRC_CONFIG_12, \
0x0D, RF_PKT_RX_FIELD_3_CRC_CONFIG_9, \
0x08, RF_PKT_CRC_SEED_31_24_4, \
0x10, RF_MODEM_MOD_TYPE_12, \
0x05, RF_MODEM_FREQ_DEV_0_1, \
0x10, RF_MODEM_TX_RAMP_DELAY_12, \
0x10, RF_MODEM_BCR_NCO_OFFSET_2_12, \
0x07, RF_MODEM_AFC_LIMITER_1_3, \
0x05, RF_MODEM_AGC_CONTROL_1, \
0x10, RF_MODEM_AGC_WINDOW_SIZE_12, \
0x0C, RF_MODEM_RAW_CONTROL_8, \
0x07, RF_MODEM_RSSI_CONTROL_3, \
0x06, RF_MODEM_RAW_SEARCH2_2, \
0x06, RF_MODEM_SPIKE_DET_2, \
0x05, RF_MODEM_RSSI_MUTE_1, \
0x09, RF_MODEM_DSA_CTRL1_5, \
0x10, RF_MODEM_CHFLT_RX1_CHFLT_COE13_7_0_12, \
0x10, RF_MODEM_CHFLT_RX1_CHFLT_COE1_7_0_12, \
0x10, RF_MODEM_CHFLT_RX2_CHFLT_COE7_7_0_12, \
0x08, RF_PA_MODE_4, \
0x0B, RF_SYNTH_PFDCP_CPFF_7, \
0x10, RF_MATCH_VALUE_1_12, \
0x0C, RF_FREQ_CONTROL_INTE_8, \
0x00 \
写命令函数:
static uint8_t si4463_cmd(const uint8_t *pCmd, uint16_t len){
register uint16_t i;
for(i = 0; i < len; i++)
spi_readwrite(pCmd);
return si4463_cts(255);
每写入一行,取CHIP STATUS, 都是Bad command issued.:'( 求高指导。 我也在学习,楼主加油 啊,我还在看数据手册,API指令,没摸着关键 我也刚学,觉得没CC1101的指令设计的好,那个进村器一看就知道,是哪,对那个味操作的 可以比较2个芯片性能,高性能需求时,用SI较好。邻道抑制60DB,镜像抑制50DB。 楼主现在怎摸样了?
我也遇到了此类问题,固定数据包收发没有问题,变长数据包收发就不行了
页:
[1]
