请教一下linux下编译问题
<br />在编译三星ARM9 2410 的vivi时,出现下面的错误<br />个人感觉是gcc有问题, 我用的arm-linux-gcc 2.95.3<br />本人新手,请各位大侠指教。。。。。。<br /><br /><br /># make menuconfig<br />make -C scripts/lxdialog all<br />make: Entering directory `/opt/FriendlyARM/SBC2410/vivi/scripts/lxdialog'<br />/usr/local/arm/2.95.3/arm-linux/bin/ld: cannot find -lncurses<br />collect2: ld returned 1 exit status<br /> <br />>> Unable to find the Ncurses libraries.<br />>><br />>> You must have Ncurses installed in order<br />>> to use 'make menuconfig'<br /> <br />make: *** Error 1<br />make: Leaving directory `/opt/FriendlyARM/SBC2410/vivi/scripts/lxdialog'<br />make: *** Error 2<br />需要安装ncurses开发包
需要安装ncurses开发包 libncurses5-dev<br />如果你系统是ubuntu的话,源里有<br />$sudo apt-get install libncurses5-dev
页:
[1]
