强仔 发表于 2009-8-31 11:15
DAC芯片AD5547的使用求助!
最近我用FPGA控制AD5547设计一个DAC的电路,电路图是手册上给出的典型电路做的,但是死活没有任何输出,小弟实在不知是哪里除了问题,VHDL代码如下,希望谁能够帮帮忙。
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
entity DAC is port
clk : in std_logic;
a : out std_logic_vector(1 downto 0);
rs : inout std_logic;
wr : inout std_logic;
ldac: inout std_logic;
msb : out std_logic;
data: out std_logic_vector(15 downto 0)
end DAC;
architecture behavior of DAC is
signal dac_clk : std_logic:='0';
type StateType is (write_prepare,write,transfer,reset,end_reset);
signal present_state, next_state : StateType;
signal counter : std_logic_vector(11 downto 0):=(others=>'0');
signal temp : std_logic_vector(2 downto 0):="000";
begin
--initializing ad5547
a<= "00"; --a="00"代表只选择A通道,"01"选择AB通道,"11"只选择B通道,"10"都不选择
msb<= '0';
--rs<= '1';
--wr<= '1';
--ldac<= '0';
--分频
process(clk)
begin
if rising_edge(clk) then
   if counter="000000000001" then
    counter <= (others=>'0');
    dac_clk <= not dac_clk;
   else
    counter <= counter+1;
   end if;
end if;
end process;
--产生控制信号
process(dac_clk)
--variable temp : std_logic_vector(2 downto 0):="000";
begin
if rising_edge(dac_clk) then
   if temp="000" then
    temp <= temp+1;
    wr<= '0';
   elsif temp="001" then
    temp <= temp+1;
    wr<= '1';
   elsif temp="010" then
    temp <= temp+1;
    ldac <= '1';
   elsif temp="011" then
    temp <= temp+1;
    ldac <= '0';
    rs<= '0';
   elsif temp="100" then
    temp <= "000";
    rs<= '1';
   else
    temp <= temp +1;
   end if;
end if;
end process;
data <= "1000111111111111";
end behavior;
jxb163 发表于 2009-9-2 08:58
...,LZ,你太有才了
xym1020 发表于 2012-5-23 10:34
1# 强仔
这位大哥,你这个DA转换使用调试成功没?我最近也调试 调试不出来啊!求助!!!
我QQ297316265
页: [1]
查看完整版本: DAC芯片AD5547的使用求助!
