创龙 TMS320C665x 一维FFT性能测试程序
分享一个C66x系列FFT性能测试程序。(测试源码见附件。)此程序的作用是评估创龙DSP TMS320C665x数字信号函数库一维FFT计算性能,测试16~262144个实数点FFT性能。程序默认使用软件仿真测试(不计内存延迟),也可使用硬件禁用缓存及使能缓存测试。 本测试试用CCS5.5,按照工程导入步骤加载FFT_Real_Benchmark.out文件,然后点击程序运行file:///C:\Users\ADMINI~1\AppData\Local\Temp\ksohtml\wps33A4.tmp.jpg按钮。 l 软件仿真(不计内存延迟) Test signal-Include 2V DC Component -Include 3V AC Component,Frequency:50Hz Phase:-30 Degree-Include 1.5V AC Component,Frequency:75Hz Phase:90 Degree-Formula:y=2+3cos(2pi*50t-(30/180)pi)+1.5cos(2pi*75t+*(90/180)pi)--------------------------- Cache Disabled -------------------------------------------------------------------------------------------------1: 16 Point FFT Test -Sampling Period:1s Sampling Frequency:16Hz Frequency Resolution:1Hz-Forward Transformation Execution Cycle is 263 -Forward Transformation Execution Time is 0.2630000 us (CPU Frequency:1000MHz)-Inverse Transformation Execution Cycle is 288 -Inverse Transformation Execution Time is 0.2880000 us (CPU Frequency:1000MHz)16 Point FFT Test End----------------------------------------------------------------------2: 32 Point FFT Test -Sampling Period:1s Sampling Frequency:32Hz Frequency Resolution:1Hz-Forward Transformation Execution Cycle is 295 -Forward Transformation Execution Time is 0.2950000 us (CPU Frequency:1000MHz)-Inverse Transformation Execution Cycle is 297 -Inverse Transformation Execution Time is 0.2970000 us (CPU Frequency:1000MHz)32 Point FFT Test End----------------------------------------------------------------------3: 64 Point FFT Test -Sampling Period:1s Sampling Frequency:64Hz Frequency Resolution:1Hz-Forward Transformation Execution Cycle is 396 -Forward Transformation Execution Time is 0.3960000 us (CPU Frequency:1000MHz)-Inverse Transformation Execution Cycle is 394 -Inverse Transformation Execution Time is 0.3940000 us (CPU Frequency:1000MHz)64 Point FFT Test End----------------------------------------------------------------------4: 128 Point FFT Test -Sampling Period:1s Sampling Frequency:128Hz Frequency Resolution:1Hz-Forward Transformation Execution Cycle is 581 -Forward Transformation Execution Time is 0.5810000 us (CPU Frequency:1000MHz)-Inverse Transformation Execution Cycle is 576 -Inverse Transformation Execution Time is 0.5760000 us (CPU Frequency:1000MHz)128 Point FFT Test End----------------------------------------------------------------------5: 256 Point FFT Test -Sampling Period:1s Sampling Frequency:256Hz Frequency Resolution:1Hz-Forward Transformation Execution Cycle is 1138 -Forward Transformation Execution Time is 1.1380000 us (CPU Frequency:1000MHz)-Inverse Transformation Execution Cycle is 1112 -Inverse Transformation Execution Time is 1.1120000 us (CPU Frequency:1000MHz)256 Point FFT Test End----------------------------------------------------------------------6: 512 Point FFT Test -Sampling Period:1s Sampling Frequency:512Hz Frequency Resolution:1Hz-Forward Transformation Execution Cycle is 2027 -Forward Transformation Execution Time is 2.0270000 us (CPU Frequency:1000MHz)-Inverse Transformation Execution Cycle is 1974 -Inverse Transformation Execution Time is 1.9740000 us (CPU Frequency:1000MHz)512 Point FFT Test End----------------------------------------------------------------------7: 1024 Point FFT Test -Sampling Period:1s Sampling Frequency:1024Hz Frequency Resolution:1Hz-Forward Transformation Execution Cycle is 4520 -Forward Transformation Execution Time is 4.5200000 us (CPU Frequency:1000MHz)-Inverse Transformation Execution Cycle is 4398 -Inverse Transformation Execution Time is 4.3980000 us (CPU Frequency:1000MHz)1024 Point FFT Test End----------------------------------------------------------------------8: 2048 Point FFT Test -Sampling Period:1s Sampling Frequency:2048Hz Frequency Resolution:1Hz-Forward Transformation Execution Cycle is 8753 -Forward Transformation Execution Time is 8.7530000 us (CPU Frequency:1000MHz)-Inverse Transformation Execution Cycle is 8508 -Inverse Transformation Execution Time is 8.5080000 us (CPU Frequency:1000MHz)2048 Point FFT Test End----------------------------------------------------------------------9: 4096 Point FFT Test -Sampling Period:1s Sampling Frequency:4096Hz Frequency Resolution:1Hz-Forward Transformation Execution Cycle is 20046 -Forward Transformation Execution Time is 20.0460000 us (CPU Frequency:1000MHz)-Inverse Transformation Execution Cycle is 19540 -Inverse Transformation Execution Time is 19.5400000 us (CPU Frequency:1000MHz)4096 Point FFT Test End----------------------------------------------------------------------10: 8192 Point FFT Test -Sampling Period:1s Sampling Frequency:8192Hz Frequency Resolution:1Hz-Forward Transformation Execution Cycle is 39767 -Forward Transformation Execution Time is 39.7670000 us (CPU Frequency:1000MHz)-Inverse Transformation Execution Cycle is 38754 -Inverse Transformation Execution Time is 38.7540000 us (CPU Frequency:1000MHz)8192 Point FFT Test End----------------------------------------------------------------------11: 16384 Point FFT Test -Sampling Period:1s Sampling Frequency:16384Hz Frequency Resolution:1Hz-Forward Transformation Execution Cycle is 90484 -Forward Transformation Execution Time is 90.4840000 us (CPU Frequency:1000MHz)-Inverse Transformation Execution Cycle is 88442 -Inverse Transformation Execution Time is 88.4420000 us (CPU Frequency:1000MHz)16384 Point FFT Test End----------------------------------------------------------------------12: 32768 Point FFT Test -Sampling Period:1s Sampling Frequency:32768Hz Frequency Resolution:1Hz-Forward Transformation Execution Cycle is 180605 -Forward Transformation Execution Time is 180.6050000 us (CPU Frequency:1000MHz)-Inverse Transformation Execution Cycle is 176520 -Inverse Transformation Execution Time is 176.5200000 us (CPU Frequency:1000MHz)32768 Point FFT Test End----------------------------------------------------------------------13: 65536 Point FFT Test -Sampling Period:1s Sampling Frequency:65536Hz Frequency Resolution:1Hz-Forward Transformation Execution Cycle is 405914 -Forward Transformation Execution Time is 405.9140000 us (CPU Frequency:1000MHz)-Inverse Transformation Execution Cycle is 397728 -Inverse Transformation Execution Time is 397.7280000 us (CPU Frequency:1000MHz)65536 Point FFT Test End----------------------------------------------------------------------14: 131072 Point FFT Test -Sampling Period:1s Sampling Frequency:131072Hz Frequency Resolution:1Hz-Forward Transformation Execution Cycle is 811427 -Forward Transformation Execution Time is 811.4270000 us (CPU Frequency:1000MHz)-Inverse Transformation Execution Cycle is 795054 -Inverse Transformation Execution Time is 795.0540000 us (CPU Frequency:1000MHz)131072 Point FFT Test End----------------------------------------------------------------------15: 262144 Point FFT Test -Sampling Period:1s Sampling Frequency:262144Hz Frequency Resolution:1Hz-Forward Transformation Execution Cycle is 1802688 -Forward Transformation Execution Time is 1802.6880000 us (CPU Frequency:1000MHz)-Inverse Transformation Execution Cycle is 1769926 -Inverse Transformation Execution Time is 1769.9260000 us (CPU Frequency:1000MHz)262144 Point FFT Test EndTest Finished!l 硬件测试(禁用缓存及使用缓存)修改main.c文件中的代码可选择硬件测试模式,如下图所示: file:///C:\Users\ADMINI~1\AppData\Local\Temp\ksohtml\wps33B4.tmp.jpg Test signal-Include 2V DC Component -Include 3V AC Component,Frequency:50Hz Phase:-30 Degree-Include 1.5V AC Component,Frequency:75Hz Phase:90 Degree-Formula:y=2+3cos(2pi*50t-(30/180)pi)+1.5cos(2pi*75t+*(90/180)pi)--------------------------- Cache Disabled -------------------------------------------------------------------------------------------------1: 16 Point FFT Test -Sampling Period:1s Sampling Frequency:16Hz Frequency Resolution:1Hz-Forward Transformation Execution Cycle is 7558 -Forward Transformation Execution Time is 7.5580000 us (CPU Frequency:1000MHz)-Inverse Transformation Execution Cycle is 7442 -Inverse Transformation Execution Time is 7.4420000 us (CPU Frequency:1000MHz)16 Point FFT Test End----------------------------------------------------------------------2: 32 Point FFT Test -Sampling Period:1s Sampling Frequency:32Hz Frequency Resolution:1Hz-Forward Transformation Execution Cycle is 9380 -Forward Transformation Execution Time is 9.3800000 us (CPU Frequency:1000MHz)-Inverse Transformation Execution Cycle is 9678 -Inverse Transformation Execution Time is 9.6780000 us (CPU Frequency:1000MHz)32 Point FFT Test End----------------------------------------------------------------------3: 64 Point FFT Test -Sampling Period:1s Sampling Frequency:64Hz Frequency Resolution:1Hz-Forward Transformation Execution Cycle is 19494 -Forward Transformation Execution Time is 19.4940000 us (CPU Frequency:1000MHz)-Inverse Transformation Execution Cycle is 20236 -Inverse Transformation Execution Time is 20.2360000 us (CPU Frequency:1000MHz)64 Point FFT Test End----------------------------------------------------------------------4: 128 Point FFT Test -Sampling Period:1s Sampling Frequency:128Hz Frequency Resolution:1Hz-Forward Transformation Execution Cycle is 35840 -Forward Transformation Execution Time is 35.8400000 us (CPU Frequency:1000MHz)-Inverse Transformation Execution Cycle is 37002 -Inverse Transformation Execution Time is 37.0020000 us (CPU Frequency:1000MHz)128 Point FFT Test End----------------------------------------------------------------------5: 256 Point FFT Test -Sampling Period:1s Sampling Frequency:256Hz Frequency Resolution:1Hz-Forward Transformation Execution Cycle is 83414 -Forward Transformation Execution Time is 83.4140000 us (CPU Frequency:1000MHz)-Inverse Transformation Execution Cycle is 86428 -Inverse Transformation Execution Time is 86.4280000 us (CPU Frequency:1000MHz)256 Point FFT Test End----------------------------------------------------------------------6: 512 Point FFT Test -Sampling Period:1s Sampling Frequency:512Hz Frequency Resolution:1Hz-Forward Transformation Execution Cycle is 164924 -Forward Transformation Execution Time is 164.9240000 us (CPU Frequency:1000MHz)-Inverse Transformation Execution Cycle is 168962 -Inverse Transformation Execution Time is 168.9620000 us (CPU Frequency:1000MHz)512 Point FFT Test End----------------------------------------------------------------------7: 1024 Point FFT Test -Sampling Period:1s Sampling Frequency:1024Hz Frequency Resolution:1Hz-Forward Transformation Execution Cycle is 314634 -Forward Transformation Execution Time is 314.6340000 us (CPU Frequency:1000MHz)-Inverse Transformation Execution Cycle is 327308 -Inverse Transformation Execution Time is 327.3080000 us (CPU Frequency:1000MHz)1024 Point FFT Test End----------------------------------------------------------------------8: 2048 Point FFT Test -Sampling Period:1s Sampling Frequency:2048Hz Frequency Resolution:1Hz-Forward Transformation Execution Cycle is 619134 -Forward Transformation Execution Time is 619.1340000 us (CPU Frequency:1000MHz)-Inverse Transformation Execution Cycle is 626648 -Inverse Transformation Execution Time is 626.6480000 us (CPU Frequency:1000MHz)2048 Point FFT Test End----------------------------------------------------------------------9: 4096 Point FFT Test -Sampling Period:1s Sampling Frequency:4096Hz Frequency Resolution:1Hz-Forward Transformation Execution Cycle is 1403024 -Forward Transformation Execution Time is 1403.0240000 us (CPU Frequency:1000MHz)-Inverse Transformation Execution Cycle is 1391810 -Inverse Transformation Execution Time is 1391.8100000 us (CPU Frequency:1000MHz)4096 Point FFT Test End----------------------------------------------------------------------10: 8192 Point FFT Test -Sampling Period:1s Sampling Frequency:8192Hz Frequency Resolution:1Hz-Forward Transformation Execution Cycle is 3065058 -Forward Transformation Execution Time is 3065.0580000 us (CPU Frequency:1000MHz)-Inverse Transformation Execution Cycle is 2942344 -Inverse Transformation Execution Time is 2942.3440000 us (CPU Frequency:1000MHz)8192 Point FFT Test End----------------------------------------------------------------------11: 16384 Point FFT Test -Sampling Period:1s Sampling Frequency:16384Hz Frequency Resolution:1Hz-Forward Transformation Execution Cycle is 7421890 -Forward Transformation Execution Time is 7421.8900000 us (CPU Frequency:1000MHz)-Inverse Transformation Execution Cycle is 7359204 -Inverse Transformation Execution Time is 7359.2040000 us (CPU Frequency:1000MHz)16384 Point FFT Test End----------------------------------------------------------------------12: 32768 Point FFT Test -Sampling Period:1s Sampling Frequency:32768Hz Frequency Resolution:1Hz-Forward Transformation Execution Cycle is 16034550 -Forward Transformation Execution Time is 16034.5500000 us (CPU Frequency:1000MHz)-Inverse Transformation Execution Cycle is 15501746 -Inverse Transformation Execution Time is 15501.7460000 us (CPU Frequency:1000MHz)32768 Point FFT Test End----------------------------------------------------------------------13: 65536 Point FFT Test
-Forward Transformation Execution Cycle is 36493010
-Forward Transformation Execution Time is 36493.0100000 us (CPU Frequency:1000MHz)
-Inverse Transformation Execution Cycle is 35923952
-Inverse Transformation Execution Time is 35923.9520000 us (CPU Frequency:1000MHz)
-Forward Transformation Execution Cycle is 76507454
-Forward Transformation Execution Time is 76507.4540000 us (CPU Frequency:1000MHz)
-Inverse Transformation Execution Cycle is 75288972
-Inverse Transformation Execution Time is 75288.9720000 us (CPU Frequency:1000MHz)
-Forward Transformation Execution Cycle is 195097318
-Forward Transformation Execution Time is 195097.3180000 us (CPU Frequency:1000MHz)
-Inverse Transformation Execution Cycle is 168462636
-Inverse Transformation Execution Time is 168462.6360000 us (CPU Frequency:1000MHz)
--------------------------- Cache Enabled ----------------------------
-Forward Transformation Execution Cycle is 2034
-Forward Transformation Execution Time is 2.0340000 us (CPU Frequency:1000MHz)
-Inverse Transformation Execution Cycle is 1638
-Inverse Transformation Execution Time is 1.6380000 us (CPU Frequency:1000MHz)
-Forward Transformation Execution Cycle is 1048
-Forward Transformation Execution Time is 1.0480000 us (CPU Frequency:1000MHz)
-Inverse Transformation Execution Cycle is 1257
-Inverse Transformation Execution Time is 1.2570000 us (CPU Frequency:1000MHz)
-Forward Transformation Execution Cycle is 1302
-Forward Transformation Execution Time is 1.3020000 us (CPU Frequency:1000MHz)
-Inverse Transformation Execution Cycle is 1513
-Inverse Transformation Execution Time is 1.5130000 us (CPU Frequency:1000MHz)
-Forward Transformation Execution Cycle is 2080
-Forward Transformation Execution Time is 2.0800000 us (CPU Frequency:1000MHz)
-Inverse Transformation Execution Cycle is 2812
-Inverse Transformation Execution Time is 2.8120000 us (CPU Frequency:1000MHz)
-Forward Transformation Execution Cycle is 4246
-Forward Transformation Execution Time is 4.2460000 us (CPU Frequency:1000MHz)
-Inverse Transformation Execution Cycle is 3828
-Inverse Transformation Execution Time is 3.8280000 us (CPU Frequency:1000MHz)
-Forward Transformation Execution Cycle is 7632
-Forward Transformation Execution Time is 7.6320000 us (CPU Frequency:1000MHz)
-Inverse Transformation Execution Cycle is 7307
-Inverse Transformation Execution Time is 7.3070000 us (CPU Frequency:1000MHz)
-Forward Transformation Execution Cycle is 14718
-Forward Transformation Execution Time is 14.7180000 us (CPU Frequency:1000MHz)
-Inverse Transformation Execution Cycle is 12958
-Inverse Transformation Execution Time is 12.9580000 us (CPU Frequency:1000MHz)
-Forward Transformation Execution Cycle is 27603
-Forward Transformation Execution Time is 27.6030000 us (CPU Frequency:1000MHz)
-Inverse Transformation Execution Cycle is 24465
-Inverse Transformation Execution Time is 24.4650000 us (CPU Frequency:1000MHz)
-Forward Transformation Execution Cycle is 55642
-Forward Transformation Execution Time is 55.6420000 us (CPU Frequency:1000MHz)
-Inverse Transformation Execution Cycle is 51792
-Inverse Transformation Execution Time is 51.7920000 us (CPU Frequency:1000MHz)
-Forward Transformation Execution Cycle is 117352
-Forward Transformation Execution Time is 117.3520000 us (CPU Frequency:1000MHz)
-Inverse Transformation Execution Cycle is 110913
-Inverse Transformation Execution Time is 110.9130000 us (CPU Frequency:1000MHz)
-Forward Transformation Execution Cycle is 305480
-Forward Transformation Execution Time is 305.4800000 us (CPU Frequency:1000MHz)
-Inverse Transformation Execution Cycle is 338549
-Inverse Transformation Execution Time is 338.5490000 us (CPU Frequency:1000MHz)
-Forward Transformation Execution Cycle is 704543
-Forward Transformation Execution Time is 704.5430000 us (CPU Frequency:1000MHz)
-Inverse Transformation Execution Cycle is 716023
-Inverse Transformation Execution Time is 716.0230000 us (CPU Frequency:1000MHz)
-Forward Transformation Execution Cycle is 1855574
-Forward Transformation Execution Time is 1855.5740000 us (CPU Frequency:1000MHz)
-Inverse Transformation Execution Cycle is 1759068
-Inverse Transformation Execution Time is 1759.0680000 us (CPU Frequency:1000MHz)
-Forward Transformation Execution Cycle is 4640602
-Forward Transformation Execution Time is 4640.6020000 us (CPU Frequency:1000MHz)
-Inverse Transformation Execution Cycle is 3878201
-Inverse Transformation Execution Time is 3878.2010000 us (CPU Frequency:1000MHz)
-Forward Transformation Execution Cycle is 48638110
-Forward Transformation Execution Time is 48638.1100000 us (CPU Frequency:1000MHz)
-Inverse Transformation Execution Cycle is 14138131
-Inverse Transformation Execution Time is 14138.1310000 us (CPU Frequency:1000MHz)
Test Finished!
最好 是有个结论,比如跟core i7比较一下。
页:
[1]
