adofu2008 发表于 2009-12-15 11:27
请教高手解决MCBSP的DLB问题
* Copyright (C) 2003 Texas Instruments Incorporated
* All Rights Reserved
*---------main_mcbsp1.c---------
* In this example, the MCBSP is configured in digital loopback
* mode, with 32 bit data transfer, in multi-frame mode, using
* sample rate generator to sync frames
#include <stdio.h>
#include <csl.h>
#include <csl_mcbsp.h>
#include <csl_pll.h>
//---------Global constants---------
#define N 20
//---------Global data definition---------
/* Create a MCBSP configuration structure */
MCBSP_Config ConfigLoopBack32= {
   MCBSP_SPCR1_RMK(
    MCBSP_SPCR1_RRST_ENABLE,
    MCBSP_SPCR1_RRDY_YES,
    MCBSP_SPCR1_RFULL_NO,
    MCBSP_SPCR1_RSYNCERR_NO,
    MCBSP_SPCR1_RINTM_RRDY,
    MCBSP_SPCR1_ABIS_DISABLE,
    MCBSP_SPCR1_DXENA_NA,
    MCBSP_SPCR1_CLKSTP_DISABLE,
    MCBSP_SPCR1_RJUST_RZF,
    MCBSP_SPCR1_DLB_ON
   MCBSP_SPCR2_RMK(
    MCBSP_SPCR2_XRST_ENABLE,
    MCBSP_SPCR2_XRDY_YES,
    MCBSP_SPCR2_XEMPTY_NO,
    MCBSP_SPCR2_XSYNCERR_NO,
    MCBSP_SPCR2_XINTM_XRDY,
    MCBSP_SPCR2_GRST_CLKG,
    MCBSP_SPCR2_FRST_FSG,
    MCBSP_SPCR2_SOFT_NO,
    MCBSP_SPCR2_FREE_NO
   MCBSP_RCR1_RMK(
    MCBSP_RCR1_RWDLEN1_16BIT,
    MCBSP_RCR1_RFRLEN1_OF(0)
   MCBSP_RCR2_RMK(
    MCBSP_RCR2_RDATDLY_2BIT,
    MCBSP_RCR2_RFIG_YES,
    MCBSP_RCR2_RCOMPAND_MSB,
    MCBSP_RCR2_RWDLEN2_8BIT,
    MCBSP_RCR2_RFRLEN2_OF(0),
    MCBSP_RCR2_RPHASE_SINGLE
   MCBSP_XCR1_RMK(
    MCBSP_XCR1_XWDLEN1_16BIT,
    MCBSP_XCR1_XFRLEN1_OF(0)
   MCBSP_XCR2_RMK(
    MCBSP_XCR2_XDATDLY_2BIT,
    MCBSP_XCR2_XFIG_YES,
    MCBSP_XCR2_XCOMPAND_MSB,
    MCBSP_XCR2_XWDLEN2_8BIT,
    MCBSP_XCR2_XFRLEN2_OF(0),
    MCBSP_XCR2_XPHASE_SINGLE
   MCBSP_SRGR1_RMK(
    MCBSP_SRGR1_CLKGDV_OF(10),
    MCBSP_SRGR1_FWID_OF(1)
   MCBSP_SRGR2_RMK(
    MCBSP_SRGR2_FPER_OF(15),
    MCBSP_SRGR2_FSGM_DXR2XSR,
    MCBSP_SRGR2_CLKSM_INTERNAL,
    MCBSP_SRGR2_CLKSP_RISING,
    MCBSP_SRGR2_GSYNC_FREE
   MCBSP_MCR1_DEFAULT,
   MCBSP_MCR2_DEFAULT,
   MCBSP_PCR_RMK(
    MCBSP_PCR_CLKRP_FALLING,
    MCBSP_PCR_CLKXP_RISING,
    MCBSP_PCR_FSRP_ACTIVEHIGH,
    MCBSP_PCR_FSXP_ACTIVEHIGH,
    MCBSP_PCR_CLKRM_INPUT,
    MCBSP_PCR_CLKXM_INPUT,
    MCBSP_PCR_DRSTAT_0,
    MCBSP_PCR_DXSTAT_0,
    MCBSP_PCR_CLKSSTAT_0,
    MCBSP_PCR_SCLKME_NO,
    MCBSP_PCR_FSRM_INTERNAL,
    MCBSP_PCR_FSXM_INTERNAL,
    MCBSP_PCR_RIOEN_SP,
    MCBSP_PCR_XIOEN_SP,
    MCBSP_PCR_IDLEEN_RESET
MCBSP_RCERA_DEFAULT,
MCBSP_RCERB_DEFAULT,
MCBSP_RCERC_DEFAULT,
MCBSP_RCERD_DEFAULT,
MCBSP_RCERE_DEFAULT,
MCBSP_RCERF_DEFAULT,
MCBSP_RCERG_DEFAULT,
MCBSP_RCERH_DEFAULT,
MCBSP_XCERA_DEFAULT,
MCBSP_XCERB_DEFAULT,
MCBSP_XCERC_DEFAULT,
MCBSP_XCERD_DEFAULT,
MCBSP_XCERE_DEFAULT,
MCBSP_XCERF_DEFAULT,
MCBSP_XCERG_DEFAULT,
MCBSP_XCERH_DEFAULT
/* Create data buffers for transfer */
Uint16 xmt, rcv;
//---------Function prototypes---------
void taskFunc(void);
//---------main routine---------
void main() {
Uint16 i;
/* Initialize CSL library, this step is required */
CSL_init();
PLL_setFreq(1, 0xF, 0, 1, 3, 3, 0);
/* Initilize data buffers. xmt will be 32 bit value      */
/* with element number in lower 16 bits and 2 * element*/
/* in upper 16 bits.i.e.0x00020001, 0x00040002, etc. */
for(i=0;i<=N-1;i++) {
    xmt = i;
    rcv = 0;
/* Call example function to perform task */
taskFunc();
void taskFunc(void) {
MCBSP_Handle mhMcbsp;
Uint16 i;
Uint16 err = 0;
/* Open MCBSP Port 0, this will return a MCBSP handle that will */
/* be used in calls to other CSl functions.                     */
mhMcbsp = MCBSP_open(MCBSP_PORT0, MCBSP_OPEN_RESET);
/* Write configuration structure values to MCBSP control */
/* registers                                             */
MCBSP_config(mhMcbsp, &ConfigLoopBack32);
/* Start Sample Rate Generator and Frame Sync */
MCBSP_start(mhMcbsp,
    MCBSP_SRGR_START | MCBSP_SRGR_FRAMESYNC,
    0x300
/* Enable MCBSP transmit and receive */
    MCBSP_RCV_START | MCBSP_XMIT_START,
/* Begin data transfer loop. We will loop thru to transmit */
/* and receive the data.                                 */
for (i=0; i<=N-1;i++) {
    /* Wait for XRDY signal before writing data to DXR */
    while (!MCBSP_xrdy(mhMcbsp));
    /* Write 32 bit data value to DXR */
    MCBSP_write16(mhMcbsp,xmt);
    /* Wait for RRDY signal to read data from DRR */
    while (!MCBSP_rrdy(mhMcbsp));
    /* Read 32 bit value from DRR */
    rcv = MCBSP_read16(mhMcbsp);
/* Check data to make sure transfer was successful */
for(i=0; i<= N-1;i++) {
    if (xmt != rcv) {
       ++err;
       break;
/* We are done with MCBSP, so close it */
MCBSP_close(mhMcbsp);
printf("%s\n",err?"TEST FAILED\n":"TEST PASSED\n");
在运行程序时,程序指针一直停在   while (!MCBSP_rrdy(mhMcbsp));请问,为什么接收不到数据呢?谢谢!
sun1988227 发表于 2013-5-21 09:22
lz 这个问题弄明白了了!!我也想知道
zhangmangui 发表于 2013-5-21 09:30
sun1988227 发表于 2013-5-21 09:22 static/image/common/back.gif
lz 这个问题弄明白了了!!我也想知道
几年前的问题啦   你可以发帖问   新帖看的人较多
页: [1]
查看完整版本: 请教高手解决MCBSP的DLB问题
