sinanjj 发表于 2010-1-30 20:09
超高速端口扫描器 syn rawsocket
#include <stdio.h>
#include <stdlib.h>
#include <strings.h>
#include <string.h>
#include <unistd.h>
#include <sys/types.h>
#include <sys/socket.h>
#include <netinet/in.h>
#include <arpa/inet.h>
#include <netdb.h>
#include <sys/stat.h>
#include <fcntl.h>
#include <netinet/tcp.h>
#include <net/if.h>
#include <sys/ioctl.h>
unsigned long int get_host_ip ()
      int tempSock = socket(PF_INET, SOCK_DGRAM, 0);
      struct ifreq ifr;
      strcpy(ifr.ifr_name, "eth0");
      if (ioctl(tempSock, SIOCGIFADDR, &ifr) < 0) { printf("error: ioctl\n"); exit (0); }
      close (tempSock);
      unsigned long int host_ip = (((struct sockaddr_in *)&(ifr.ifr_addr))->sin_addr).s_addr;
      return host_ip;
long int get_random (void)
      int fd = 0;
      if ((fd = open ("/dev/urandom", O_RDONLY | O_NONBLOCK)) == -1) { printf ("error: open /dev/urandom. exit\n"); exit (0); }
      long int buf;
      if (read (fd, (char *)&buf, 4) != 4) { printf ("error: read /dev/urandom. exit\n"); exit (0); }
      if (close (fd) != 0) { printf ("error: close() fd. exit\n"); exit (0); }
      return buf;
unsigned short csum (unsigned short *buf, int nwords)      /* generates header checksums */
      unsigned long sum;
      for (sum = 0; nwords > 0; nwords--)
                sum += *buf++;
      sum = (sum >> 16) + (sum & 0xffff);
      sum += (sum >> 16);
      return ~sum;
struct pseudohdr {
      u_int32_t saddr;      /* source IP address */
      u_int32_t daddr;      /* destination IP address */
      u_int8_t res;                /* contains binary zeroes.(0) */
      u_int8_t ptcl;                /* protocol. can be tcp (6), udp(17), icmp(1) */
      u_int16_t len;                /* TCP/UDP packet length. (unit:byte) */
int main (int argc, char *argv[])
      if (argc != 5) { printf ("usage: %s fromip toip fromport toport\n", argv); exit (0); }
      unsigned long fromip, toip;
      fromip = ntohl(inet_addr(argv)); toip = ntohl(inet_addr(argv));      /* inet_aton() returns non-zero if the address is valid, zero if not. */
      if ((fromip == 0) || (toip == 0) || ((toip-fromip) < 0)) { printf ("error: fromip or toip\n"); exit (0); }
      unsigned short fromport, toport;
      fromport = atoi (argv); toport = atoi (argv);
      if ((fromport == 0) || (toport == 0) || ((toport-fromport) < 0)) { printf ("error: fromport or toport\n"); exit (0); }
      int raw_sock_tcp;
      if ((raw_sock_tcp = socket(PF_INET, SOCK_RAW, IPPROTO_TCP)) == -1) { printf("socket() failed!\nMust be root to make raw socket.\n"); exit(0); }
      unsigned char packet; bzero (packet, 80);
      struct tcphdr *tcph = (struct tcphdr *)packet;
      /* fill in the tcp header values */
//      tcph->source = htons (1234);
      tcph->source = htons (get_random());
      tcph->dest = htons (1);
      tcph->seq = get_random ();      /* in a SYN packet, the sequence is a random */
      tcph->ack_seq = 0;      /* number, and the ack sequence is 0 in the 1st packet */
      tcph->doff = 5;
      tcph->syn = 1;      /* initial connection request */
      tcph->window = htonl (65535);      /* maximum allowed window size */
      tcph->check = 0;
      tcph->urg_ptr = 0;
      struct sockaddr_in dest; bzero (&dest, sizeof (dest));
      dest.sin_family = PF_INET; dest.sin_addr.s_addr = inet_addr ("1.2.3.4"); dest.sin_port = htons (1);
      unsigned long int host_ip = get_host_ip ();
      int ip_i,port_i;
      for(ip_i = 0; ip_i <= (toip-fromip); ip_i++) {
                for(port_i = 0; port_i <= (toport-fromport); port_i++) {
                        dest.sin_addr.s_addr = htonl (fromip + ip_i); dest.sin_port = htons (fromport + port_i);
                        tcph->dest = htons (fromport + port_i);
                        unsigned char buf; bzero (buf, 512);
                        struct pseudohdr *pseudohdr;
                        pseudohdr = (struct pseudohdr *)buf;
                        /* full pseudohdr */
                        pseudohdr->daddr = dest.sin_addr.s_addr;
                        pseudohdr->saddr = host_ip;
                        pseudohdr->res = 0; pseudohdr->ptcl = 0x06;
                        pseudohdr->len = htons((tcph->doff)<<2);
                        tcph->check = 0;
                        memcpy((unsigned char *)pseudohdr+sizeof(struct pseudohdr), (unsigned char *)tcph, (tcph->doff)<<2);
                        tcph->check = csum((unsigned short *)pseudohdr, (((tcph->doff)<<2) + sizeof(struct pseudohdr))>>1);
                        if (sendto (raw_sock_tcp, packet,      /* the buffer containing headers and data */
                              ((tcph->doff)<<2),      /* total length of our packet */
                              0, (struct sockaddr *) &dest, sizeof (struct sockaddr)) < 0)
                              printf ("error: sendto()\n");
                        fd_set readfs;      /* file descriptor set */
                        FD_ZERO (&readfs); FD_SET (raw_sock_tcp, &readfs);
                        struct timeval timeout = {0, 0};      /* 0s */
                        while (select (raw_sock_tcp+1, &readfs, NULL, NULL, &timeout)) {
                              bzero (buf, 512);
                              int n_recv;
                              n_recv = recvfrom(raw_sock_tcp, buf, 512, 0, NULL, NULL);
                              if(n_recv < 40) { continue; }      /* 20byte ip header + 20byte tcp header */
                              if(buf == 0x12) {
                                        printf ("%d.%d.%d.%d %d\n", buf, buf, buf, buf,
                                                ((buf<<8)&0XFF00 | buf&0XFF));
      return 0;
sinanjj 发表于 2012-5-21 00:39
udp_sniffer.c
#include <stdio.h>
#include <errno.h>
#include <unistd.h>
#include <stdlib.h>
#include <fcntl.h>
#include <time.h>
#include <sys/time.h>
void be_daemon (void)
    switch (fork()) {    // fork off the parent process
      case -1: { printf ("error: fork()\n"); exit(0); }
      case 0: break;
      default: exit (0);
    umask (0);    // change the file mode mask
    setsid();    // create a new SID for the child process
    chdir ("/");    // change the current working directory
    close (STDIN_FILENO); close (STDOUT_FILENO); close (STDERR_FILENO);    // close out the standard file descriptors
int main()
    FILE * log_f;
    int raw_sock, n_rcved, i;
    unsigned char buf;
    if ((raw_sock = socket(PF_INET, SOCK_RAW, IPPROTO_UDP))<0) { printf("error: socket()\n"); exit(0); }
    be_daemon ();
    for(;;) {
      n_rcved = recvfrom(raw_sock, buf, 65535, 0, NULL, NULL);
      if (n_rcved <= 0) continue;
      if ((buf == 0x7f) && (buf==0x00) && (buf == 0x00) && (buf == 0x01)) {    // filter 127.0.0.1
            continue;
      log_f = fopen("/udp_log","a+"); if (log_f == NULL) { exit(0); }
      struct timeval time_now; gettimeofday(&time_now,NULL);
      struct tm *tm_ptr;
      tm_ptr = localtime(&time_now.tv_sec);
      fprintf(log_f, "time:%04d-%02d-%02d %02d:%02d:%02d:%06d source:%d.%d.%d.%d sport:%d dport:%d length:%d data:", tm_ptr->tm_year+1900,tm_ptr->tm_mon+1,tm_ptr->tm_mday,tm_ptr->tm_hour,tm_ptr->tm_min,tm_ptr->tm_sec,(int)time_now.tv_usec,buf,buf,buf,buf,(((unsigned int)buf)<<8) + buf,(((unsigned int)buf)<<8) + buf, n_rcved-28);
      for (i=0; i<(n_rcved-28); i++) fprintf(log_f, "%02x ", buf);
      fprintf(log_f, "\n");
      fclose(log_f);
sinanjj 发表于 2014-4-5 22:54
天命风流 发表于 2018-5-21 18:27
顶!!!!!!
页: [1]
查看完整版本: 超高速端口扫描器 syn rawsocket
