tiger84 发表于 2010-3-15 13:31
高分求助:关于device_driver中probe函数的编写
小菜鸟最近在写一个SPI接口的AD驱动,用的是AD7888,主芯片是at91sam9260,在文件board-sam9260ek.c中,把结构体改成如下了
static struct spi_board_info ek_spi_devices[] = {
#if defined(CONFIG_AD7888)
      {   /* spi ad */
            .modalias   = "ad7888",
            .chip_select    = 0,
            .max_speed_hz   = 15 * 1000 * 1000,
            .bus_num    = 0,
            .mode= SPI_MODE_0,
#endif
#if defined(CONFIG_MMC_SPI)
{ /* DataFlash card */
.modalias = "mmc_spi",
.chip_select = 1,
.bus_num = 0,
#endif
然后参照其他的驱动,自己编写了一个AD7888的驱动,如下
#include <linux/kernel.h>
#include <linux/init.h>
#include <linux/module.h>
#include <linux/slab.h>
#include <linux/delay.h>
#include <linux/device.h>
#include <linux/sched.h>
#include <linux/platform_device.h>
#include <linux/spi/spi.h>
* NOTE: this is an *AD* driver.
* Handle SPI chips with the drivers/spi/
struct ad7888_data {
struct spi_device *spi;
struct mutexlock;
* Function Name: void ad7888_init(void)
* Description    : ad7888 init
* Input          : None
* Output         : None
* Return         : None
static void ad7888_init(void)
* Function Name: void ad7888_exit(void)
* Description    : ad7888 exit
* Input          : None
* Output         : None
* Return         : None
static void ad7888_exit(void)
* Function Name: static int ad7888_read_reg(struct spi_device *spi, int reg)
* Description    : depend on the channel to read ad7888 ad data
* Input          : None
* Output         : None
* Return         : None
    char buf;
    buf = reg;
    buf = 0;
    spi_write_then_read(spi, buf, 1, buf, 2);
    return buf << 8 | buf;
* Input          : None
* Output         : None
* Return         : None
static int ad7888_probe(struct spi_device *spi)
    struct ad7888_data *ts = NULL;
int         ret;
/* Chip description 暂时不加*/
//AD7888 上升沿接收数据,下降沿发送数据,选择模式0,16位数据(前4为0),MSB在前 默认可以不写
spi->mode = SPI_MODE_0;
spi->bits_per_word = 8;
ret = spi_setup(spi);
if (ret < 0)
return ret;
ts = kzalloc(sizeof(struct ad7888_data), GFP_KERNEL);
if (!ts)
   ret = -ENOMEM;
   return ret;
mutex_init(&ts->lock);
ts->spi = spi_dev_get(spi);
dev_set_drvdata(&spi->dev, ts);
/* Ping the chip ... the status register is pretty portable,
* unlike probing manufacturer IDs.We do expect that system
* firmware didn't write it in the past few milliseconds!
ret = spi_w8r16(spi, AD_ADD8_REG);
if (ret <= 0) {
dev_dbg(&spi->dev, "rdsr --> %d (%02x)\n", ret, ret);
ret = -ENXIO;
goto fail;
    // 注册设备
   // ret = device_register(&ts->spi->dev);
// if (ret)
//goto fail;
fail:
dev_dbg(&spi->dev, "probe err %d\n", ret);
dev_set_drvdata(&spi->dev, NULL);
mutex_destroy(&ts->lock);
kfree(ts);
return ret;
static int ad7888_remove(struct spi_device *spi)
    struct ad7888_data *ts;
ts = dev_get_drvdata(&spi->dev);
if (ts == NULL)
return -ENODEV;
   // 注册设备
//   device_unregister(&ts->spi->dev);
kfree(ts);
return 0;
static struct spi_driver ad7888_spi_driver = {
    .probe= ad7888_probe,
    .remove = ad7888_remove,
    .driver = {
                  .name   = "ad7888",
                  .owner= THIS_MODULE,
            .bus    = &spi_bus_type,
static int __init ad7888_spi_init(void)
    ad7888_init();
    return spi_register_driver(&ad7888_spi_driver);
static void __exit ad7888_spi_exit(void)
    ad7888_exit();
    spi_unregister_driver(&ad7888_spi_driver);
module_init(ad7888_spi_init);
module_exit(ad7888_spi_exit);
编译进去启动后,在/sys里面
#ls /sys/bus/spi/devices/spi1.0/
/sys/bus/spi/devices/spi1.0/bus/      /sys/bus/spi/devices/spi1.0/subsystem/
/sys/bus/spi/devices/spi1.0/driver/   /sys/bus/spi/devices/spi1.0/uevent
/sys/bus/spi/devices/spi1.0/modalias
# cat /sys/bus/spi/devices/spi1.0/modalias
ad7888
# ls /sys/bus/spi/drivers/
ad7888   mmc_spispidev
device和driver都找到了,但是我不知道probe函数怎么写,
它主要有2个作用,把这个驱动绑定到具体的SPI设备上,并能探测到存在的SPI设备,可能会配置一些在系统启动配置不了的参数。
以下是我写的probe函数
* Input          : None
* Output         : None
* Return         : None
      int         ret;
      if (ret < 0)
                return ret;
      if (!ts)
            ret = -ENOMEM;
            return ret;
      if (ret <= 0) {
                ret = -ENXIO;
                goto fail;
    // 注册设备
//      if (ret)
//                goto fail;
      fail:
      kfree(ts);
      return ret;
各位指教一二,看probe函数还要哪些?
sinanjj 发表于 2010-3-15 14:50
这个事啊. 只能靠你自己多试几次.....
goosen 发表于 2010-3-15 15:19
$ cd drivers
$ find ./ | grep 'ad78'
./input/touchscreen/ad7879.c
./input/touchscreen/ad7877.c
可以参考下以上两个SPI驱动。既然用linux,就充分的利用已经提供有的源码。
tiger84 发表于 2010-3-15 15:36
我已经试的汗流浃背了,但总是觉得不是很清楚。
芯片还没买回来,但又总是感觉不那么对劲。
撇开具体的设备,抽象一点,照我的理解,:
以这个SPI设备为例,
系统初始化时,
(1)向内核注册这些板级信息体
spi_register_board_info(devices, nr_devices);
(2)然后是platform_device注册
platform_device_register(&at91sam9260_spi1_device);
因为用的是atmel的SPI控制器,所以有如下代码
static struct platform_driver atmel_spi_driver = {
        .driver                = {
                .name        = "atmel_spi",
                .owner        = THIS_MODULE,
        .suspend        = atmel_spi_suspend,
        .resume                = atmel_spi_resume,
        .remove                = __exit_p(atmel_spi_remove),
static int __init atmel_spi_init(void)
        return platform_driver_probe(&atmel_spi_driver, atmel_spi_probe);
module_init(atmel_spi_init);
static void __exit atmel_spi_exit(void)
        platform_driver_unregister(&atmel_spi_driver);
这里主要是针对主控制器的,它的probe函数
static int __init atmel_spi_probe(struct platform_device *pdev)
        ------------------省略-----------------------
        ret = spi_register_master(master);
        if (ret)
                goto out_reset_hw;
        return 0;
out_reset_hw:
        spi_writel(as, CR, SPI_BIT(SWRST));
        clk_disable(clk);
        free_irq(irq, master);
out_unmap_regs:
        iounmap(as->regs);
out_free_buffer:
        dma_free_coherent(&pdev->dev, BUFFER_SIZE, as->buffer,
                        as->buffer_dma);
out_free:
        clk_put(clk);
        spi_master_put(master);
        return ret;
看下它的调用过程
atmel_spi_probe----->spi_register_master----->scan_boardinfo---->spi_new_device,相应的注释如下:
* spi_register_master - register SPI master controller
* @master: initialized master, originally from spi_alloc_master()
* Context: can sleep
* SPI master controllers connect to their drivers using some non-SPI bus,
* such as the platform bus.The final stage of probe() in that code
* includes calling spi_register_master() to hook up to this SPI bus glue.
* SPI controllers use board specific (often SOC specific) bus numbers,
* and board-specific addressing for SPI devices combines those numbers
* with chip select numbers.Since SPI does not directly support dynamic
* device identification, boards need configuration tables telling which
* chip is at which address.
* This must be called from context that can sleep.It returns zero on
* success, else a negative error code (dropping the master's refcount).
* After a successful return, the caller is responsible for calling
* spi_unregister_master().
int spi_register_master(struct spi_master *master)
/* FIXME someone should add support for a __setup("spi", ...) that
* creates board info from kernel command lines
static void scan_boardinfo(struct spi_master *master)
        struct boardinfo        *bi;
        mutex_lock(&board_lock);
        list_for_each_entry(bi, &board_list, list) {
                struct spi_board_info        *chip = bi->board_info;
                unsigned                n;
                for (n = bi->n_board_info; n > 0; n--, chip++) {
                        if (chip->bus_num != master->bus_num)
                                continue;
                        /* NOTE: this relies on spi_new_device to
                       * issue diagnostics when given bogus inputs
                        (void) spi_new_device(master, chip);
        mutex_unlock(&board_lock);
* spi_new_device - instantiate one new SPI device
* @master: Controller to which device is connected
* @chip: Describes the SPI device
* On typical mainboards, this is purely internal; and it's not needed
* after board init creates the hard-wired devices.Some development
* platforms may not be able to use spi_register_board_info though, and
* this is exported so that for example a USB or parport based adapter
* driver could add devices (which it would learn about out-of-band).
* Returns the new device, or NULL.
struct spi_device *spi_new_device(struct spi_master *master,
                                  struct spi_board_info *chip)
        struct spi_device        *proxy;
        int                        status;
        /* NOTE:caller did any chip->bus_num checks necessary.
       * Also, unless we change the return value convention to use
       * error-or-pointer (not NULL-or-pointer), troubleshootability
       * suggests syslogged diagnostics are best here (ugh).
        proxy = spi_alloc_device(master);
        if (!proxy)
                return NULL;
        WARN_ON(strlen(chip->modalias) >= sizeof(proxy->modalias));
        proxy->chip_select = chip->chip_select;
        proxy->max_speed_hz = chip->max_speed_hz;
        proxy->mode = chip->mode;
        proxy->irq = chip->irq;
        strlcpy(proxy->modalias, chip->modalias, sizeof(proxy->modalias));
        proxy->dev.platform_data = (void *) chip->platform_data;
        proxy->controller_data = chip->controller_data;
        proxy->controller_state = NULL;
        status = spi_add_device(proxy);
        if (status < 0) {
                spi_dev_put(proxy);
                return NULL;
        return proxy;
* spi_add_device - Add spi_device allocated with spi_alloc_device
* @spi: spi_device to register
* Companion function to spi_alloc_device.Devices allocated with
* spi_alloc_device can be added onto the spi bus with this function.
* Returns 0 on success; negative errno on failure
int spi_add_device(struct spi_device *spi)
        static DEFINE_MUTEX(spi_add_lock);
        struct device *dev = spi->master->dev.parent;
        int status;
        /* Chipselects are numbered 0..max; validate. */
        if (spi->chip_select >= spi->master->num_chipselect) {
                dev_err(dev, "cs%d >= max %d\n",
                        spi->chip_select,
                        spi->master->num_chipselect);
                return -EINVAL;
        /* Set the bus ID string */
        snprintf(spi->dev.bus_id, sizeof spi->dev.bus_id,
                        "%s.%u", spi->master->dev.bus_id,
                        spi->chip_select);
        /* We need to make sure there's no other device with this
       * chipselect **BEFORE** we call setup(), else we'll trash
       * its configuration.Lock against concurrent add() calls.
        mutex_lock(&spi_add_lock);
        if (bus_find_device_by_name(&spi_bus_type, NULL, spi->dev.bus_id)
                        != NULL) {
                dev_err(dev, "chipselect %d already in use\n",
                                spi->chip_select);
                status = -EBUSY;
                goto done;
        /* Drivers may modify this initial i/o setup, but will
       * normally rely on the device being setup.Devices
       * using SPI_CS_HIGH can't coexist well otherwise...
        status = spi->master->setup(spi);
        if (status < 0) {
                dev_err(dev, "can't %s %s, status %d\n",
                                "setup", spi->dev.bus_id, status);
                goto done;
        /* Device may be bound to an active driver when this returns */
        status = device_add(&spi->dev);
        if (status < 0)
                                "add", spi->dev.bus_id, status);
        else
                dev_dbg(dev, "registered child %s\n", spi->dev.bus_id);
done:
        mutex_unlock(&spi_add_lock);
        return status;
有如下几个疑问:
(1)设备已经增加到平台设备里面了,平台设备和平台驱动都已经注册,并且在这个主控制器的probe函数里面已经把具体的device设备加进去了,那么我写spi 设备驱动时,比如这里的AD7888,只需要注册driver就行了,不知道我理解的是否对不?但是我对比了其他具体的设备驱动,发现那些设备又注册了一次设备。
(2)按照这样写驱动的话,一些读写及控制函数怎么加进去,我看了一些其他的驱动,
比如一个eeprom驱动
* NOTE: this is an *EEPROM* driver.The vagaries of product naming
* mean that some AT25 products are EEPROMs, and others are FLASH.
* Handle FLASH chips with the drivers/mtd/devices/m25p80.c driver,
* not this one!
struct at25_data {
        struct mutex                lock;
        struct spi_eeprom        chip;
        struct bin_attribute        bin;
        unsigned                addrlen;
就把读写函数都放在struct bin_attribute        bin;
一个SPI扩展IO芯片MAX7301是这样定义结构体的:
* Some registers must be read back to modify.
* To save time we cache them here in memory
struct max7301 {
        struct mutex        lock;
        u8                port_config;        /* field 0 is unused */
        u32                out_level;        /* cached output levels */
        struct gpio_chip chip;
把控制都放在struct gpio_chip chip;里面了。
而DS1305呢
/* register RTC ... from here on, ds1305->ctrl needs locking */
        rtc = rtc_device_register("ds1305", &spi->dev,
                        &ds1305_ops, THIS_MODULE);
这个比较好理解,就放在ds1305_ops里面了。
于是我打算把这个读写函数放在
        struct mutex                lock;
这个结构体,
我对驱动理解很肤浅,各位提提建议
tiger84 发表于 2010-3-15 15:46
sinanjj,我试的快晕倒了,呵呵,但是又只能继续试。
goosen,我的是2.6.27的,没有你说的那2个文件
$ find ./ -iname *ad7*
./drivers/spi/ad7888.o
./drivers/spi/ad7888.c
./drivers/spi/.ad7888.o.cmd
./drivers/hwmon/ad7414.c
./drivers/hwmon/ad7418.c
./include/linux/spi/ad7877.h
./include/config/ad7888.h
./include/config/spi/ad7888.h
很奇怪,不知道为什么会多了几个文件,红色部分。
其实我有参考过其他的,但是还是摸不着门路。
goosen 发表于 2010-3-15 16:11
我的是2.6.31。找参考驱动的时候,优先找同一公司同一系列芯片的驱动。
或这里,
http://www.google.com/codesearch?hl=zh-CN&lr=&q=ad7877.c&sbtn=%E6%90%9C%E7%B4%A2
tiger84 发表于 2010-3-15 16:36
atmel没有2.6.31的补丁,我先下个2.6.30的看下
tiger84 发表于 2010-3-15 16:36 https://bbs.21ic.com/images/common/back.gif
这里已更至2.6.32
http://maxim.org.za/at91_26.html
tiger84 发表于 2010-3-15 17:22
谢谢goosen,2.6.30里面也有这2个设备的驱动了,不过还是蛮复杂的。不管了,先参照这2个文件改改吧。
打算把SPI相关再仔细看一遍,然后根据已有文件修改,争取今天能把文件改完
tiger84 发表于 2010-3-15 22:01
简单的改了下
    struct ad7888_data            *chip;
    struct ad7888_platform_data   *pdata;
    int    ret;
    // 若需要更改,请在下面配置,配置后需要调用spi_setup
//        spi->mode = SPI_MODE_0;
//        spi->bits_per_word = 8;
//    ret = spi_setup(spi);
//      if (ret < 0)
//            return ret;
   /* assuming the driver requires board-specific data: */
    pdata = &spi->dev.platform_data;
    if (!pdata)
            return -ENODEV;
    /* get memory for driver's per-chip state, set up driver data */
    chip = kzalloc(sizeof *chip, GFP_KERNEL);
    if (!chip)
            return -ENOMEM;
    spi_set_drvdata(spi, chip);
    chip->spi = spi_dev_get(spi);
   // 用来确认器件在板子上
        if (ret <= 0) {
                ret = -ENXIO;
                goto fail;
        fail:
        kfree(chip);
        return ret;
明天看是否能拿到器件,飞线调试。
tiger84 发表于 2010-3-16 21:13
拿到器件,也飞线了,少飞了一根线,实验室关了,明天测试。
tiger84 发表于 2010-3-19 13:27
最后是用class写的,经过2天的调试,OK了。
后来才发现已经有现成的可以用了,spidev。不过也收获了不少
页: [1]
查看完整版本: 高分求助:关于device_driver中probe函数的编写
