ccs编译器,用typedef时出现警告
用ccs,程序里面有一段#ifndef TYPES_H
#define TYPES_H
// datatypes
typedef unsigned char uint8_t;
typedef unsigned shortuint16_t;
typedef unsigned int uint32_t;
typedef unsigned long ulong_t;
typedef signed char int8_t;
typedef signed short int16_t;
typedef signed int int32_t;
typedef signed long long_t;
typedef enum
false = 0,
true = 1
}bool_e;
#endif
总提示我警告
#303-D typedef name has already been declared(with same type)
我理解这个警告的意思是这个类型已经被定义过了,可是这程序里不是有#ifndef #endif吗??
求大神告知 搜索一下,看看有其他地方的重复没有。 像这些unsigned char 有头文件里面一定定义为Uint8等了
你再次定义可能警告了
页:
[1]
