a6104617 发表于 2016-9-8 15:45
为什么28335ad输入寄存器里总是衡量没有随着我的输入改变...
各位大神请问一下你们
这是我的程序我就用了一路输入A0,然后dsp28335ADCINA0引脚上加上一个输入电压给A0寄存器显示依然是那个衡量大概2000左右换算成电压就是1.5V。如果先输入电压在链接dsp的话又都是杂乱数据不知道为什么?求大神指导,程序应该没什么问题。
#include "DSP2833x_Device.h"   // DSP2833x Headerfile Include File
#include "DSP2833x_Examples.h"   // DSP2833x Examples Include File
// Determine when the shift to right justify the data takes place
// Only one of these should be defined as 1.
// The other two should be defined as 0.
#define POST_SHIFT   0// Shift results after the entire sample table is full
#define INLINE_SHIFT 1// Shift results as the data is taken from the results regsiter
#define NO_SHIFT   0// Do not shift the results
// ADC start parameters
#if (CPU_FRQ_150MHZ)   // Default - 150 MHz SYSCLKOUT
#define ADC_MODCLK 0x3 // HSPCLK = SYSCLKOUT/2*ADC_MODCLK2 = 150/(2*3)   = 25.0 MHz
#endif
#if (CPU_FRQ_100MHZ)
#define ADC_MODCLK 0x2 // HSPCLK = SYSCLKOUT/2*ADC_MODCLK2 = 100/(2*2)   = 25.0 MHz
#endif
#define ADC_CKPS   0x0   // ADC module clock = HSPCLK/1      = 25.5MHz/(1)   = 25.0 MHz
#define ADC_SHCLK0x1   // S/H width in ADC module periods                  = 2 ADC cycle
#define AVG      1000// Average sample limit
#define ZOFFSET    0x00// Average Zero offset
#define BUF_SIZE   256// Sample buffer size
// Global variable for this example
Uint16 SampleTable;
float SampleValue;
main()
   Uint16 i;
   Uint16 j,k;
   Uint16 array_index;
   InitSysCtrl();
   EALLOW;
   SysCtrlRegs.HISPCP.all = ADC_MODCLK;        // HSPCLK = SYSCLKOUT/ADC_MODCLK
   EDIS;
//   EALLOW;
//   GpioCtrlRegs.GPBMUX2.bit.GPIO61 = 0; // GPIO61 = GPIO61
//GpioCtrlRegs.GPBDIR.bit.GPIO61 = 1;
//EDIS;
   DINT;
   InitPieCtrl();
// Disable CPU interrupts and clear all CPU interrupt flags:
   IER = 0x0000;
   IFR = 0x0000;
   InitPieVectTable();
   InitAdc();         // For this example, init the ADC
// Specific ADC setup for this example:
   AdcRegs.ADCTRL1.bit.ACQ_PS = ADC_SHCLK;// Sequential mode: Sample rate   = 1/[(2+ACQ_PS)*ADC clock in ns]
   AdcRegs.ADCTRL3.bit.ADCCLKPS = ADC_CKPS;
   AdcRegs.ADCTRL1.bit.SEQ_CASC = 1;      // 1Cascaded mode
   AdcRegs.ADCTRL1.bit.CONT_RUN = 1;         // Setup continuous run
   AdcRegs.ADCMAXCONV.bit.MAX_CONV1 = 0x0;// convert and store in 8 results registers
   AdcRegs.ADCTRL1.bit.SEQ_OVRD = 1;       // Enable Sequencer override feature
//AdcRegs.ADCCHSELSEQ1.bit.conv00 = 0x00;
   AdcRegs.ADCCHSELSEQ1.all = 0x00;
//   AdcRegs.ADCCHSELSEQ2.all = 0x00;
//   AdcRegs.ADCCHSELSEQ3.all = 0x00;
//   AdcRegs.ADCCHSELSEQ4.all = 0x00;
// Clear SampleTable
   for (i=0; i<BUF_SIZE; i++)
   SampleTable = 0;
// Start SEQ1
   AdcRegs.ADCTRL2.all = 0x2000;
   for(;;)
   {//Take ADC data and log them in SampleTable array
                array_index = 0;
           for (i=0; i<(BUF_SIZE); i++)
                       while (AdcRegs.ADCST.bit.INT_SEQ1== 0){}
//                 GpioDataRegs.GPBDAT.bit.GPIO61 = 1;// Set GPIO61 for monitoring-optional
                       AdcRegs.ADCST.bit.INT_SEQ1_CLR = 1;
                       SampleTable= ( (AdcRegs.ADCRESULT0)>>4);
                        SampleValue = SampleTable*3.0/4096;
                        array_index++;
                           for(j=0;j<100;j++)
                  k++;
//                  GpioDataRegs.GPBDAT.bit.GPIO61 = 0;// Clear GPIO61 for monitoring-optional
JY-DX-JY 发表于 2016-9-8 15:50
不知道你怎么弄的,软件没问题那就是硬件问题。
谢谢,配置应该没问题但是就是不知道为什么ADC输入接口接什么都没有变化,识别出来的换算成模拟量都是1.5V,接地输入也没变化
zhangmangui 发表于 2016-9-8 22:36
如果是一直1.5V那就是配置问题了    感觉好像是接错了口   1.5V应该是悬空的值
你刷新一下看看结果寄存器里面的值
你刷新一下看看结果寄存器 ...
谢谢你 确实是 接口有问题!!太感谢了
跳跳糖 发表于 2017-4-2 16:01
我也遇到相同的额问题,你是哪里的接口有问题啊
谢谢你 确实是 接口有问题!!太感谢了
你是哪个接口有问题啊,我也遇到相同的问题
谢谢你 确实是 接口有问题!!太感谢了
同问,是哪里的接口有问题
页: [1]
查看完整版本: 为什么28335ad输入寄存器里总是衡量没有随着我的输入改变...
