付费求助 Linux命令 time make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf
duan@ubuntu:~/u-boot-sunxi$ time make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- 2>&1 | tee build.logCHK include/config/uboot.release
CHK include/generated/version_autogenerated.h
CHK include/generated/timestamp_autogenerated.h
UPD include/generated/timestamp_autogenerated.h
CHK include/generated/generic-asm-offsets.h
CHK include/generated/asm-offsets.h
HOSTCCtools/mkenvimage.o
HOSTLDtools/mkenvimage
HOSTCCtools/fit_image.o
HOSTCCtools/image-host.o
HOSTCCtools/dumpimage.o
HOSTLDtools/dumpimage
HOSTCCtools/mkimage.o
HOSTLDtools/mkimage
CC cmd/version.o
LD cmd/built-in.o
CC common/main.o
CC common/board_f.o
LD common/built-in.o
CC drivers/video/cfb_console.o
LD drivers/video/built-in.o
LD drivers/built-in.o
CC drivers/usb/gadget/f_fastboot.o
LD drivers/usb/gadget/built-in.o
CC lib/display_options.o
LD lib/built-in.o
LD u-boot
make: *** No rule to make target 'arch/arm/dts/sun5i-a13-lichee.dtb', needed by 'dtbs'.Stop.
dts/Makefile:36: recipe for target 'arch-dtbs' failed
make: *** Error 2
Makefile:833: recipe for target 'dts/dt.dtb' failed
make: *** Error 2
该怎么解决 从最后的错误提示看,是需要dtbs文件,生成dtb文件。看下你的dtbs文件有吗? snakeemail说的对,最后解决了吗,应该有个回复啊 提示楼主,Linux对文件名的大小写敏感哦
错误提示中文件名是“sun5i-a13-lichee.dtb”
页:
[1]
