c语言.h头文件的一些问题
下面是在.h 头文件里对一个32位寄存器的定义,有些地方不明白,请教一下,先谢谢啦!1)为什么这里typedef union有4个 struct? 是不是针对不同情况?如果我使用第一个struct,就不能用其他的么?
2)如果我对某一位赋值,我可以使用, 比如PMCONbits.CS2P=1;(因为定义了unsigned CS2P:1;)
但是有些位没有定义,比如unsigned:1;是不是说明该位不能被赋值?如果能,怎么赋值?
3) 能不能用PMCON对整个寄存器赋值,比如PMCON=0xFFFFFF00
4) PMCONCLR是不是所有为置0, PMCONSET所有为置1?
#define PMCON PMCON
extern volatile unsigned int PMCON __attribute__((section("sfrs")));
typedef union {
struct {
unsigned RDSP:1;
unsigned WRSP:1;
unsigned :1;
unsigned CS1P:1;
unsigned CS2P:1;
unsigned ALP:1;
unsigned CSF:2;
unsigned PTRDEN:1;
unsigned PTWREN:1;
unsigned PMPTTL:1;
unsigned ADRMUX:2;
unsigned SIDL:1;
unsigned :1;
unsigned ON:1;
unsigned :1;
unsigned DUALBUF:1;
unsigned :5;
unsigned RDSTART:1;
struct {
unsigned :6;
unsigned CSF0:1;
unsigned CSF1:1;
unsigned :3;
unsigned ADRMUX0:1;
unsigned ADRMUX1:1;
struct {
unsigned :13;
unsigned PSIDL:1;
unsigned :1;
unsigned PMPEN:1;
struct {
unsigned w:32;
} __PMCONbits_t;
extern volatile __PMCONbits_t PMCONbits __asm__ ("PMCON") __attribute__((section("sfrs")));
extern volatile unsigned int PMCONCLR __attribute__((section("sfrs")));
extern volatile unsigned int PMCONSET __attribute__((section("sfrs")));
extern volatile unsigned int PMCONINV __attribute__((section("sfrs")));
头文件........你想明白啥
页:
[1]
