求助:用拨动开关控制发脉冲,编程遇到问题,得不到想...
本帖最后由 shukeli 于 2016-12-2 15:55 编辑#include "DSP2833x_Device.h" // DSP2833x Headerfile Include File
#include "DSP2833x_Examples.h" // DSP2833x Examples Include File
void StopPulse(void);//封锁脉冲
Uint16 *ExRamStart = (Uint16 *)0x100000;
void EPwmSetup();
Uint16i;
int Sw ;
void main(void)
// Step 1. Initialize System Control:
// PLL, WatchDog, enable Peripheral Clocks
// This example function is found in the DSP2833x_SysCtrl.c file.
InitSysCtrl();
GpioCtrlRegs.GPCPUD.bit.GPIO80 = 0;
GpioCtrlRegs.GPCMUX2.bit.GPIO80 = 0;
GpioCtrlRegs.GPCDIR.bit.GPIO80 = 1;
Sw = 0;
// Step 2. Initalize GPIO:
// This example function is found in the DSP2833x_Gpio.c file and
// illustrates how to set the GPIO to it's default state.
// InitGpio();// Skipped for this example
InitXintf16Gpio(); //zq
// Step 3. Clear all interrupts and initialize PIE vector table:
// Disable CPU interrupts
DINT;
// Initialize the PIE control registers to their default state.
// The default state is all PIE interrupts disabled and flags
// are cleared.
// This function is found in the DSP2833x_PieCtrl.c file.
InitPieCtrl();
// Disable CPU interrupts and clear all CPU interrupt flags:
IER = 0x0000;
IFR = 0x0000;
// Initialize the PIE vector table with pointers to the shell Interrupt
// Service Routines (ISR).
// This will populate the entire table, even if the interrupt
// is not used in this example.This is useful for debug purposes.
// The shell ISR routines are found in DSP2833x_DefaultIsr.c.
// This function is found in DSP2833x_PieVect.c.
InitPieVectTable();
// Interrupts that are used in this example are re-mapped to
// ISR functions found within this file.
// Step 4. Initialize the Device Peripheral. This function can be
// found in DSP2833x_CpuTimers.c
// InitCpuTimers(); // For this example, only initialize the Cpu Timers
// Configure CPU-Timer 0, 1, and 2 to interrupt every second:
// 150MHz CPU Freq, 1 second Period (in uSeconds)
//ConfigCpuTimer(&CpuTimer0, 150, 1000000);
//ConfigCpuTimer(&CpuTimer1, 150, 1000000);
//ConfigCpuTimer(&CpuTimer2, 150, 1000000);
// StartCpuTimer0();
// StopPulse();
for(; ;)
Sw = GpioDataRegs.GPCDAT.bit.GPIO80;
if(Sw==1 )
EPwmSetup();
else
StopPulse();//闭锁脉冲
void StopPulse(void)//闭锁脉冲
GpioDataRegs.GPACLEAR.bit.GPIO0=1;
GpioDataRegs.GPACLEAR.bit.GPIO1=1;
GpioDataRegs.GPACLEAR.bit.GPIO2=1;
GpioDataRegs.GPACLEAR.bit.GPIO3=1;
GpioDataRegs.GPACLEAR.bit.GPIO4=1;
GpioDataRegs.GPACLEAR.bit.GPIO5=1;
// No more.
一个简单的程序,我却出现如下几个问题:
1、Sw = GpioDataRegs.GPCDAT.bit.GPIO80;这句话如果放在for循环外面,就根本发不出波形。
2、按照如上的程序,我的本意是Sw=1的时候,即开关闭合时,发脉冲。否则,闭锁脉冲。但是最后示波器上显示出,当开关打开时,是有发脉冲,开关闭合,反而没有脉冲或者脉冲为1.
3、当把for循环里面的if(Sw==1)改为(Sw==0)时,能得到我大概想要的结果。但是整个程序的设计和我正好相反。。。。
不知道哪里错了???@zhangmangui 还有各位前辈 拨码开关闭合一般是为0的吧,看你硬件电路 JY-DX-JY 发表于 2016-12-2 15:24
哦哦,我打错了,是拨动开关 1.肯定不能放外面 放外面不是实时监测IO口的变化
2.从硬件设计较多一般开关闭合设计为0打开被上拉为1
3.贴出你的硬件设计就明白了 像这种监测按键开关的最好加上去抖动 zhangmangui 发表于 2016-12-2 22:09
2.从硬件设计较多一般开关闭合设计为0打开被上拉为1 ...
1、这是开关的硬件图。从图中怎么能够看出来当sw拨向1时,就是断开?sw拨向3时就是闭合呢?
2、假如确实是这样,那为什么sw=1时,脉冲有的时候是没有,有的时候却全是高?是因为我没有设置抖动吗?多谢!!
2、假如确实是这样,那为什么sw=1时,脉冲有的时候是没有,有的时候却全是高?是因为我没有设置抖动吗?多谢~~~
2、假如确实 ...
你这个开关应该是单刀双掷开关 推向1端应该是高电平 3端应该是低电平
脉冲时有时无可能是开关接触不好 你一直拿手摁着试试 zhangmangui 发表于 2016-12-3 22:29
脉冲时有时无可能是开关接触不 ...
开关接触貌似挺好的!封锁脉冲那个函数难道有问题?感觉也没问题啊 shukeli 发表于 2016-12-4 20:59
连续调用这个函数EPwmSetup();可能会有问题
比如函数中一直从头执行 或者怎么处理 无法让波形连续 zhangmangui 发表于 2016-12-4 22:53
比如函数中一直从头执行 或者怎么处理 无法让波形连续 ...
对,我把这儿setup放到for外面的话,根本无法封锁脉冲,一直显示脉冲,可能程序写这么简单有问题,估计有哪些没考虑到 多试试 解决了分享一把
页:
[1]
