程序进非法中断interrupt void ILLEGAL_ISR(void)
请教各位高手,芯片TMS320F28027,程序进入main2()函数,经过大括号就会进入后面的非法中断程序,请问有人遇到过吗?怎么解决?谢谢!#pragma CODE_SECTION(main2,"ramfuncs");
void main2(void)
Uint16 Receive_a=0x00;
Uint16 cun1=0,cun2=0;
// SET485=1;
//MBUF=1;
//filesize1=510;
SCI_SendStatus("AAAAUnderlying software executing.CC33C33C");
SCI_SendStatus("AAAAType 'a' to relock baud-rate:CC33C33C");
interrupt void ILLEGAL_ISR(void) // Illegal operation TRAP
// Insert ISR Code here
// Next two lines for debug only to halt the processor here
// Remove after inserting ISR Code
asm(" ESTOP0");
for(;;);
main2是你自己定义的吗 main2是你的主函数吗
如果是主函数需要在code start处指定
页:
[1]
