LINUX移植求助
编译好了linux 内核,下载到开发板出现如下结果,请高手不吝赐教NAND ID is 0xecf1
Set boot params = root=/dev/mtdblock3 init=/linuxrc load_ramdisk=0 console=ttySAC0,115200 mem=65536K devfs=mount display=sam320
Load Kernel...
Skipped bad block at 0xa00
Uncompressing Linux... done, booting the kernel.
Linux version 2.6.33 (root@bogon) (gcc version 3.4.1) #2 Wed Apr 7 22:51:24 CST 2010
CPU: ARM920T revision 0 (ARMv4T), cr=c0007177
CPU: VIVT data cache, VIVT instruction cache
Machine: SMDK2440
ATAG_INITRD is deprecated; please update your bootloader.
Memory policy: ECC disabled, Data cache writeback
CPU S3C2440A (id 0x32440001)
S3C24XX Clocks, Copyright 2004 Simtec Electronics
S3C244X: core 400.000 MHz, memory 100.000 MHz, peripheral 50.000 MHz
CLOCK: Slow mode (1.500 MHz), fast, MPLL on, UPLL on
Built 1 zonelists in Zone order, mobility grouping on.Total pages: 16256
Kernel command line: root=/dev/mtdblock3 init=/linuxrc load_ramdisk=0 console=ttySAC0,115200 mem=65536K devfs=mount display=sam320
PID hash table entries: 256 (order: -2, 1024 bytes)
Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
Memory: 64MB = 64MB total
Memory: 61804KB available (2668K code, 245K data, 132K init, 0K highmem)
Hierarchical RCU implementation.
NR_IRQS:99
irq: clearing pending ext status 00080000
irq: clearing subpending status 00000093
irq: clearing subpending status 00000092
Console: colour dummy device 80x30
console enabled
Calibrating delay loop... 199.47 BogoMIPS (lpj=498688)
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
S3C Power Management, Copyright 2004 Simtec Electronics
S3C2440: Initialising architecture
S3C2440: IRQ Support
S3C24XX DMA Driver, Copyright 2003-2006 Simtec Electronics
DMA channel 0 at c4808000, irq 33
DMA channel 1 at c4808040, irq 34
DMA channel 2 at c4808080, irq 35
DMA channel 3 at c48080c0, irq 36
S3C244X: Clock Support, DVS off
bio: create slab <bio-0> at 0
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
s3c-i2c s3c2440-i2c: slave address 0x10
s3c-i2c s3c2440-i2c: bus frequency set to 97 KHz
s3c-i2c s3c2440-i2c: i2c-0: S3C I2C adapter
Advanced Linux Sound Architecture Driver Version 1.0.21.
NetWinder Floating Point Emulator V0.97 (extended precision)
yaffs Apr7 2010 22:38:45 Installing.
msgmni has been set to 120
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
Console: switching to colour frame buffer device 30x40
fb0: s3c2410fb frame buffer device
lp: driver loaded but no devices found
ppdev: user-space parallel port driver
Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
s3c2440-uart.0: s3c2410_serial0 at MMIO 0x50000000 (irq = 70) is a S3C2440
s3c2440-uart.1: s3c2410_serial1 at MMIO 0x50004000 (irq = 73) is a S3C2440
s3c2440-uart.2: s3c2410_serial2 at MMIO 0x50008000 (irq = 76) is a S3C2440
brd: module loaded
loop: module loaded
Uniform Multi-Platform E-IDE driver
ide-gd driver 1.18
ide-cd driver 5.00
S3C24XX NAND Driver, (c) 2004 Simtec Electronics
s3c24xx-nand s3c2440-nand: Tacls=2, 20ns Twrph0=6 60ns, Twrph1=2 20ns
s3c24xx-nand s3c2440-nand: NAND ECC disabled
NAND device: Manufacturer ID: 0xec, Chip ID: 0xf1 (Samsung NAND 128MiB 3,3V 8-bit)
NAND_ECC_NONE selected by board driver. This is not recommended !!
Scanning device for bad blocks
Bad eraseblock 40 at 0x000000500000
Bad eraseblock 67 at 0x000000860000
Bad eraseblock 130 at 0x000001040000
Bad eraseblock 455 at 0x0000038e0000
Bad eraseblock 511 at 0x000003fe0000
Bad eraseblock 698 at 0x000005740000
Creating 6 MTD partitions on "NAND 128MiB 3,3V 8-bit":
0x000000000000-0x000000020000 : "boot"
0x000000020000-0x000000080000 : "bootParam"
0x000000500000-0x000000800000 : "Kernel"
0x000000800000-0x000004400000 : "fs_yaffs"
0x000004400000-0x000004480000 : "eboot"
0x000004480000-0x000008000000 : "WINCE"
usbmon: debugfs is not available
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
s3c2410-ohci s3c2410-ohci: S3C24XX OHCI
s3c2410-ohci s3c2410-ohci: new USB bus registered, assigned bus number 1
s3c2410-ohci s3c2410-ohci: irq 42, io mem 0x49000000
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
usbcore: registered new interface driver libusual
usbcore: registered new interface driver usbserial
USB Serial support registered for generic
usbcore: registered new interface driver usbserial_generic
usbserial: USB Serial Driver core
USB Serial support registered for FTDI USB Serial Device
usbcore: registered new interface driver ftdi_sio
ftdi_sio: v1.5.0:USB FTDI Serial Converters Driver
USB Serial support registered for pl2303
usbcore: registered new interface driver pl2303
pl2303: Prolific PL2303 USB to serial adaptor driver
mice: PS/2 mouse device common for all mice
S3C24XX RTC, (c) 2004,2006 Simtec Electronics
S3C2410 Watchdog Timer, (c) 2004 Simtec Electronics
s3c2410-wdt s3c2410-wdt: watchdog inactive, reset disabled, irq enabled
No device for DAI UDA134X
No device for DAI s3c24xx-i2s
ALSA device list:
No soundcards found.
drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
yaffs: dev is 32505859 name is "mtdblock3"
yaffs: passed flags ""
yaffs: Attempting MTD mount on 31.3, "mtdblock3"
yaffs: auto selecting yaffs2
block 4 is bad
block 67 is bad
block 392 is bad
block 448 is bad
yaffs_read_super: isCheckpointed 0
VFS: Mounted root (yaffs filesystem) on device 31:3.
Freeing init memory: 132K
Warning: unable to open an initial console.
Failed to execute /linuxrc.Attempting defaults...
Kernel panic - not syncing: No init found.Try passing init= option to kernel.
Backtrace:
[<c002d9cc>] (dump_backtrace+0x0/0x104) from [<c002dae8>] (dump_stack+0x18/0x1c)
r7:00000000 r6:00000000 r5:c002191c r4:c02e47f4
[<c002dad0>] (dump_stack+0x0/0x1c) from [<c004d4d4>] (panic+0x3c/0x124)
[<c004d498>] (panic+0x0/0x124) from [<c00295d4>] (init_post+0xd0/0x100)
r3:c3805e10 r2:00000005 r1:00000004 r0:c027d034
[<c0029504>] (init_post+0x0/0x100) from [<c0008c20>] (kernel_init+0xdc/0x10c)
r4:c02e47f8
[<c0008b44>] (kernel_init+0x0/0x10c) from [<c004fce0>] (do_exit+0x0/0x5a4)
r5:00000000 r4:00000000 不知楼主注意到了没有,是根文件系统下linuxrc文件的问题。要么就不要用linuxrc,要么就用busybox生成的。
Backtrace:
r4:c02e47f8
页:
[1]
