AlieZore 发表于 2017-6-16 21:49
使用STM32CubeMX生成HAL直接使用的问题
使用Cube直接生成的HAL进行can通讯是CAN2总是显示超时
AlieZore 发表于 2017-6-16 21:51
void MX_can_transAndreceve()
CAN_FilterConfTypeDef sFilterConfig;
static CanTxMsgTypeDef      TxMessage;
static CanRxMsgTypeDef      RxMessage;
hcan2.pTxMsg = &TxMessage;
hcan1.pRxMsg = &RxMessage;
hcan2.pTxMsg->StdId = 0x11;
hcan2.pTxMsg->RTR = CAN_RTR_DATA;
hcan2.pTxMsg->IDE = CAN_ID_STD;
hcan2.pTxMsg->DLC = 8;
hcan2.pTxMsg->Data = 0Xff;
hcan2.pTxMsg->Data = 0x00;
hcan2.pTxMsg->Data = 0xff;
sFilterConfig.FilterNumber = 0;
sFilterConfig.FilterMode = CAN_FILTERMODE_IDMASK;
sFilterConfig.FilterScale = CAN_FILTERSCALE_32BIT;
sFilterConfig.FilterIdHigh = 0x0000;
sFilterConfig.FilterIdLow = 0x0000;
sFilterConfig.FilterMaskIdHigh = 0x0000;
sFilterConfig.FilterMaskIdLow = 0x0000;
sFilterConfig.FilterFIFOAssignment = 0;
sFilterConfig.FilterActivation = ENABLE;
sFilterConfig.BankNumber = 14;
// HAL_CAN_ConfigFilter(&hcan1, &sFilterConfig); Â˲¨
if (HAL_CAN_ConfigFilter(&hcan1, &sFilterConfig) != HAL_OK)
    /* Filter configuration Error */
    Error_Handler();
void MX_can_use()
if(HAL_CAN_Transmit(&hcan2, 100) != HAL_OK)
        Error_Handler();
if(HAL_CAN_GetState(&hcan2) != HAL_CAN_STATE_READY)
       Error_Handler();
if(HAL_CAN_Receive(&hcan1, CAN_FIFO0,10) != HAL_OK)
                        Error_Handler();
if(HAL_CAN_GetState(&hcan1) != HAL_CAN_STATE_READY)
        Error_Handler();
HAL_Delay(1000);
AlieZore 发表于 2017-6-16 21:52
配置部分
static void MX_CAN1_Init(void)
hcan1.Instance = CAN1;
hcan1.Init.Prescaler = 5;
hcan1.Init.Mode = CAN_MODE_NORMAL;
hcan1.Init.SJW = CAN_SJW_1TQ;
hcan1.Init.BS1 = CAN_BS1_3TQ;
hcan1.Init.BS2 = CAN_BS2_5TQ;
hcan1.Init.TTCM = DISABLE;
hcan1.Init.ABOM = ENABLE;
hcan1.Init.AWUM = DISABLE;
hcan1.Init.NART = DISABLE;
hcan1.Init.RFLM = DISABLE;
hcan1.Init.TXFP = DISABLE;
if (HAL_CAN_Init(&hcan1) != HAL_OK)
    _Error_Handler(__FILE__, __LINE__);
static void MX_CAN2_Init(void)
hcan2.Instance = CAN2;
hcan2.Init.Prescaler = 5;
hcan2.Init.Mode = CAN_MODE_NORMAL;
hcan2.Init.SJW = CAN_SJW_1TQ;
hcan2.Init.BS1 = CAN_BS1_3TQ;
hcan2.Init.BS2 = CAN_BS2_5TQ;
hcan2.Init.TTCM = DISABLE;
hcan2.Init.ABOM = ENABLE;
hcan2.Init.AWUM = DISABLE;
hcan2.Init.NART = DISABLE;
hcan2.Init.RFLM = DISABLE;
hcan2.Init.TXFP = DISABLE;
if (HAL_CAN_Init(&hcan2) != HAL_OK)
AlieZore 发表于 2017-6-16 21:53
hal库can启动部分包括自己分析出问题的位置
HAL_StatusTypeDef HAL_CAN_Init(CAN_HandleTypeDef* hcan)
uint32_t InitStatus = CAN_INITSTATUS_FAILED;
uint32_t tickstart = 0U;
/* Check CAN handle */
if(hcan == NULL)
   return HAL_ERROR;
/* Check the parameters */
assert_param(IS_CAN_ALL_INSTANCE(hcan->Instance));
assert_param(IS_FUNCTIONAL_STATE(hcan->Init.TTCM));
assert_param(IS_FUNCTIONAL_STATE(hcan->Init.ABOM));
assert_param(IS_FUNCTIONAL_STATE(hcan->Init.AWUM));
assert_param(IS_FUNCTIONAL_STATE(hcan->Init.NART));
assert_param(IS_FUNCTIONAL_STATE(hcan->Init.RFLM));
assert_param(IS_FUNCTIONAL_STATE(hcan->Init.TXFP));
assert_param(IS_CAN_MODE(hcan->Init.Mode));
assert_param(IS_CAN_SJW(hcan->Init.SJW));
assert_param(IS_CAN_BS1(hcan->Init.BS1));
assert_param(IS_CAN_BS2(hcan->Init.BS2));
assert_param(IS_CAN_PRESCALER(hcan->Init.Prescaler));
if(hcan->State == HAL_CAN_STATE_RESET)
    /* Allocate lock resource and initialize it */
    hcan->Lock = HAL_UNLOCKED;
    /* Init the low level hardware */
    HAL_CAN_MspInit(hcan);
/* Initialize the CAN state*/
hcan->State = HAL_CAN_STATE_BUSY;
/* Exit from sleep mode */
hcan->Instance->MCR &= (~(uint32_t)CAN_MCR_SLEEP);
/* Request initialisation */
hcan->Instance->MCR |= CAN_MCR_INRQ ;
/* Get tick */
tickstart = HAL_GetTick();
/* Wait the acknowledge */
while((hcan->Instance->MSR & CAN_MSR_INAK) != CAN_MSR_INAK)//µ÷ÊÔÏÔʾ³¬Ê±Î»ÖÃ
    if((HAL_GetTick() - tickstart ) > CAN_TIMEOUT_VALUE)
      hcan->State= HAL_CAN_STATE_TIMEOUT;
      /* Process unlocked */
      __HAL_UNLOCK(hcan);
      return HAL_TIMEOUT;
/* Check acknowledge */
if ((hcan->Instance->MSR & CAN_MSR_INAK) == CAN_MSR_INAK)
    /* Set the time triggered communication mode */
    if (hcan->Init.TTCM == ENABLE)
      hcan->Instance->MCR |= CAN_MCR_TTCM;
    else
      hcan->Instance->MCR &= ~(uint32_t)CAN_MCR_TTCM;
    /* Set the automatic bus-off management */
    if (hcan->Init.ABOM == ENABLE)
      hcan->Instance->MCR |= CAN_MCR_ABOM;
    else
      hcan->Instance->MCR &= ~(uint32_t)CAN_MCR_ABOM;
    /* Set the automatic wake-up mode */
    if (hcan->Init.AWUM == ENABLE)
      hcan->Instance->MCR |= CAN_MCR_AWUM;
    else
      hcan->Instance->MCR &= ~(uint32_t)CAN_MCR_AWUM;
    /* Set the no automatic retransmission */
    if (hcan->Init.NART == ENABLE)
      hcan->Instance->MCR |= CAN_MCR_NART;
    else
      hcan->Instance->MCR &= ~(uint32_t)CAN_MCR_NART;
    /* Set the receive FIFO locked mode */
    if (hcan->Init.RFLM == ENABLE)
      hcan->Instance->MCR |= CAN_MCR_RFLM;
    else
      hcan->Instance->MCR &= ~(uint32_t)CAN_MCR_RFLM;
    /* Set the transmit FIFO priority */
    if (hcan->Init.TXFP == ENABLE)
      hcan->Instance->MCR |= CAN_MCR_TXFP;
    else
      hcan->Instance->MCR &= ~(uint32_t)CAN_MCR_TXFP;
    /* Set the bit timing register */
    hcan->Instance->BTR = (uint32_t)((uint32_t)hcan->Init.Mode) | \
                ((uint32_t)hcan->Init.SJW) | \
                ((uint32_t)hcan->Init.BS1) | \
                ((uint32_t)hcan->Init.BS2) | \
               ((uint32_t)hcan->Init.Prescaler - 1U);
    /* Request leave initialisation */
    hcan->Instance->MCR &= ~(uint32_t)CAN_MCR_INRQ;
/* Get tick */
   while((hcan->Instance->MSR & CAN_MSR_INAK) == CAN_MSR_INAK)
       __HAL_UNLOCK(hcan);
       return HAL_TIMEOUT;
    /* Check acknowledged */
    if ((hcan->Instance->MSR & CAN_MSR_INAK) != CAN_MSR_INAK)
      InitStatus = CAN_INITSTATUS_SUCCESS;
if(InitStatus == CAN_INITSTATUS_SUCCESS)
    /* Set CAN error code to none */
    hcan->ErrorCode = HAL_CAN_ERROR_NONE;
    /* Initialize the CAN state */
    hcan->State = HAL_CAN_STATE_READY;
    /* Return function status */
    return HAL_OK;
else
    hcan->State = HAL_CAN_STATE_ERROR;
    return HAL_ERROR;
这个乱码的地方就是出问题的部分//后面本来是 调试显示超时位置
页: [1]
查看完整版本: 使用STM32CubeMX生成HAL直接使用的问题
