TXQDM 发表于 2017-7-8 13:32
GRBL七: STM32代码移植——IO
首先看引脚映射,关于引脚的定义都在pin_map.h中
其实感觉GRBL的引脚这地做的不太人性,因为他的几个引脚都是用的同一个IO通道且是挨在一起的,程序中对引脚的操作也是按照挨在一起的算法进行的,如果用的是不一个通道IO
且重复的话就不适合了,例如如果X_STEP使用A0Y_STEP使用B0这样就会出现错误,可以使用不同通道,但是要确保X_STEP_BIT ,Y_STEP_BIT, Z_STEP_BIT,X_DIRECTION_BIT ,Y_DIRECTION_BIT ,Z_DIRECTION_BIT 使用的是不同位,这是默认的情况,也可以在参数中修改这些bit的具体位置$6的值就是这六个引脚的映射
pin_map.h
view plain copy
[*]pin_map.h - Pin mapping configuration file
[*]Part of Grbl
[*]The MIT License (MIT)
[*]GRBL(tm) - Embedded CNC g-code interpreter and motion-controller
[*]Copyright (c) 2013 Sungeun K. Jeon
[*]Permission is hereby granted, free of charge, to any person obtaining a copy
[*]of this software and associated documentation files (the "Software"), to deal
[*]in the Software without restriction, including without limitation the rights
[*]to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
[*]copies of the Software, and to permit persons to whom the Software is
[*]furnished to do so, subject to the following conditions:
[*]The above copyright notice and this permission notice shall be included in
[*]all copies or substantial portions of the Software.
[*]THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
[*]IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
[*]FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
[*]AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
[*]LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
[*]OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
[*]THE SOFTWARE.
[*]/* The pin_map.h file serves as a central pin mapping settings file for different processor
[*]   types, i.e. AVR 328p or AVR Mega 2560. Grbl officially supports the Arduino Uno, but the
[*]   other supplied pin mappings are supplied by users, so your results may vary. */
[*]#ifndef pin_map_h
[*]#define pin_map_h
[*]//add by zjk for stm32
[*]#ifdef PIN_MAP_STM32 // AVR 328p, Officially supported by Grbl.
[*]// Serial port pins
[*]//#define SERIAL_RX USART_RX_vect
[*]//#define SERIAL_UDRE USART_UDRE_vect
[*]// NOTE: All step bit and direction pins must be on the same port.
[*]//#define STEPPING_DDR       DDRD
[*]//#define STEPPING_PORT      PORTD
[*]//#define X_STEP_BIT         2// Uno Digital Pin 2
[*]//#define Y_STEP_BIT         3// Uno Digital Pin 3
[*]//#define Z_STEP_BIT         4// Uno Digital Pin 4
[*]//#define X_DIRECTION_BIT    5// Uno Digital Pin 5
[*]//#define Y_DIRECTION_BIT    6// Uno Digital Pin 6
[*]//#define Z_DIRECTION_BIT    7// Uno Digital Pin 7
[*]//#define STEP_MASK ((1<<X_STEP_BIT)|(1<<Y_STEP_BIT)|(1<<Z_STEP_BIT)) // All step bits
[*]//#define DIRECTION_MASK ((1<<X_DIRECTION_BIT)|(1<<Y_DIRECTION_BIT)|(1<<Z_DIRECTION_BIT)) // All direction bits
[*]//#define STEPPING_MASK (STEP_MASK | DIRECTION_MASK) // All stepping-related bits (step/direction)
[*]#define X_STEP_PORT      GPIOA->ODR
[*]#define Y_STEP_PORT      GPIOD->ODR
[*]#define Z_STEP_PORT
[*]#define X_STEP_BIT         8// PA8
[*]#define Y_STEP_BIT         15// PD15
[*]#define Z_STEP_BIT
[*]#define X_STEP_MASK      (1<<X_STEP_BIT)
[*]#define Y_STEP_MASK      (1<<Y_STEP_BIT)
[*]#define Z_STEP_MASK      (1<<Z_STEP_BIT)
[*]#define X_STEP_TRASLATE(a)((a>>2)<<X_STEP_BIT)
[*]#define Y_STEP_TRASLATE(a)((a>>3)<<Y_STEP_BIT)
[*]#define Z_STEP_TRASLATE(a)((a>>4)<<Z_STEP_BIT)
[*]#define X_DIRECTION_PORTGPIOA->ODR
[*]#define Y_DIRECTION_PORTGPIOA->ODR
[*]#define Z_DIRECTION_PORT
[*]#define X_DIRECTION_BIT    6// PC6
[*]#define Y_DIRECTION_BIT    2// PA2
[*]#define Z_DIRECTION_BIT
[*]#define X_DIRECTION_MASK   (1<<X_DIRECTION_BIT)
[*]#define Y_DIRECTION_MASK   (1<<Y_DIRECTION_BIT)
[*]#define Z_DIRECTION_MASK   (1<<Z_DIRECTION_BIT)
[*]#define X_DIRECTION_TRASLATE(a) ((a>>5)<<X_DIRECTION_BIT)
[*]#define Y_DIRECTION_TRASLATE(a) (a)
[*]#define Z_DIRECTION_TRASLATE(a) ((a>>7)<<Z_DIRECTION_BIT)
[*]#define X_STEP_EN   GPIO_SetBits(GPIOA , GPIO_Pin_8)
[*]#define X_STEP_DISGPIO_ResetBits(GPIOA , GPIO_Pin_8)
[*]#define Y_STEP_EN   GPIO_SetBits(GPIOD , GPIO_Pin_15)
[*]#define Y_STEP_DISGPIO_ResetBits(GPIOD , GPIO_Pin_15)
[*]#define STEPPING_EN   X_STEP_EN;Y_STEP_EN
[*]#define STEPPING_DISX_STEP_DIS;Y_STEP_DIS
[*]#define X_DIRECTION_EN   GPIO_SetBits(GPIOA , GPIO_Pin_6)
[*]#define X_DIRECTION_DISGPIO_ResetBits(GPIOA , GPIO_Pin_6)
[*]#define Y_DIRECTION_EN   GPIO_SetBits(GPIOA , GPIO_Pin_2)
[*]#define Y_DIRECTION_DISGPIO_ResetBits(GPIOA , GPIO_Pin_2)
[*]#define DIRECTION_EN   X_DIRECTION_EN;Y_DIRECTION_EN
[*]#define DIRECTION_DISX_DIRECTION_DIS;Y_DIRECTION_DIS
[*]//#define STEPPERS_DISABLE_DDR    DDRB
[*]//#define STEPPERS_DISABLE_PORT   PORTB
[*]//#define STEPPERS_DISABLE_BIT    0// Uno Digital Pin 8
[*]//#define STEPPERS_DISABLE_MASK (1<<STEPPERS_DISABLE_BIT)
[*]#define STEPPERS_DISABLE_ENGPIO_SetBits(GPIOA , GPIO_Pin_3);GPIO_SetBits(GPIOA , GPIO_Pin_4)
[*]#define STEPPERS_DISABLE_DISGPIO_ResetBits(GPIOA , GPIO_Pin_3);GPIO_ResetBits(GPIOA , GPIO_Pin_4)
[*]// NOTE: All limit bit pins must be on the same port
[*]//#define LIMIT_DDR       DDRB
[*]//#define LIMIT_PIN       PINB
[*]//#define LIMIT_PORT      PORTB
[*]//#define X_LIMIT_BIT   1// Uno Digital Pin 9
[*]//#define Y_LIMIT_BIT   2// Uno Digital Pin 10
[*]//#define Z_LIMIT_BIT   3// Uno Digital Pin 11
[*]//#define LIMIT_INT       PCIE0// Pin change interrupt enable pin
[*]//#define LIMIT_INT_vectPCINT0_vect
[*]//#define LIMIT_PCMSK   PCMSK0 // Pin change interrupt register
[*]//#define LIMIT_MASK ((1<<X_LIMIT_BIT)|(1<<Y_LIMIT_BIT)|(1<<Z_LIMIT_BIT)) // All limit bits
[*]//带刀轴主轴电机
[*]//#define SPINDLE_ENABLE_DDR   DDRB
[*]//#define SPINDLE_ENABLE_PORTPORTB
[*]//#define SPINDLE_ENABLE_BIT   4// Uno Digital Pin 12
[*]//#define SPINDLE_DIRECTION_DDR   DDRB
[*]//#define SPINDLE_DIRECTION_PORTPORTB
[*]//#define SPINDLE_DIRECTION_BIT   5// Uno Digital Pin 13 (NOTE: D13 can't be pulled-high input due to LED.)
[*]//#define COOLANT_FLOOD_DDR   DDRC
[*]//#define COOLANT_FLOOD_PORTPORTC
[*]//#define COOLANT_FLOOD_BIT   3// Uno Analog Pin 3
[*]// NOTE: Uno analog pins 4 and 5 are reserved for an i2c interface, and may be installed at
[*]// a later date if flash and memory space allows.
[*]// #define ENABLE_M7// Mist coolant disabled by default. Uncomment to enable.
[*]#ifdef ENABLE_M7
[*]    #define COOLANT_MIST_DDR   DDRC
[*]    #define COOLANT_MIST_PORTPORTC
[*]    #define COOLANT_MIST_BIT   4 // Uno Analog Pin 4
[*]#endif
[*]// NOTE: All pinouts pins must be on the same port
[*]#define PINOUT_DDR       DDRC
[*]#define PINOUT_PIN       PINC
[*]#define PINOUT_PORT      PORTC
[*]#define PIN_RESET      0// Uno Analog Pin 0
[*]#define PIN_FEED_HOLD    1// Uno Analog Pin 1
[*]#define PIN_CYCLE_START2// Uno Analog Pin 2
[*]#define PINOUT_INT       PCIE1// Pin change interrupt enable pin
[*]#define PINOUT_INT_vectPCINT1_vect
[*]#define PINOUT_PCMSK   PCMSK1 // Pin change interrupt register
[*]#define PINOUT_MASK ((1<<PIN_RESET)|(1<<PIN_FEED_HOLD)|(1<<PIN_CYCLE_START))
[*]#endif
[*]//end zjk
[*]#ifdef PIN_MAP_ARDUINO_UNO // AVR 328p, Officially supported by Grbl.
[*]#define SERIAL_RX USART_RX_vect
[*]#define SERIAL_UDRE USART_UDRE_vect
[*]#define STEPPING_DDR       DDRD
[*]#define STEPPING_PORT      PORTD
[*]#define X_STEP_BIT         2// Uno Digital Pin 2
[*]#define Y_STEP_BIT         3// Uno Digital Pin 3
[*]#define Z_STEP_BIT         4// Uno Digital Pin 4
[*]#define X_DIRECTION_BIT    5// Uno Digital Pin 5
[*]#define Y_DIRECTION_BIT    6// Uno Digital Pin 6
[*]#define Z_DIRECTION_BIT    7// Uno Digital Pin 7
[*]#define STEP_MASK ((1<<X_STEP_BIT)|(1<<Y_STEP_BIT)|(1<<Z_STEP_BIT)) // All step bits
[*]#define DIRECTION_MASK ((1<<X_DIRECTION_BIT)|(1<<Y_DIRECTION_BIT)|(1<<Z_DIRECTION_BIT)) // All direction bits
[*]#define STEPPING_MASK (STEP_MASK | DIRECTION_MASK) // All stepping-related bits (step/direction)
[*]#define STEPPERS_DISABLE_DDR    DDRB
[*]#define STEPPERS_DISABLE_PORT   PORTB
[*]#define STEPPERS_DISABLE_BIT    0// Uno Digital Pin 8
[*]#define STEPPERS_DISABLE_MASK (1<<STEPPERS_DISABLE_BIT)
[*]#define LIMIT_DDR       DDRB
[*]#define LIMIT_PIN       PINB
[*]#define LIMIT_PORT      PORTB
[*]#define X_LIMIT_BIT   1// Uno Digital Pin 9
[*]#define Y_LIMIT_BIT   2// Uno Digital Pin 10
[*]#define Z_LIMIT_BIT   3// Uno Digital Pin 11
[*]#define LIMIT_INT       PCIE0// Pin change interrupt enable pin
[*]#define LIMIT_INT_vectPCINT0_vect
[*]#define LIMIT_PCMSK   PCMSK0 // Pin change interrupt register
[*]#define LIMIT_MASK ((1<<X_LIMIT_BIT)|(1<<Y_LIMIT_BIT)|(1<<Z_LIMIT_BIT)) // All limit bits
[*]#define SPINDLE_ENABLE_DDR   DDRB
[*]#define SPINDLE_ENABLE_PORTPORTB
[*]#define SPINDLE_ENABLE_BIT   4// Uno Digital Pin 12
[*]#define SPINDLE_DIRECTION_DDR   DDRB
[*]#define SPINDLE_DIRECTION_PORTPORTB
[*]#define SPINDLE_DIRECTION_BIT   5// Uno Digital Pin 13 (NOTE: D13 can't be pulled-high input due to LED.)
[*]#define COOLANT_FLOOD_DDR   DDRC
[*]#define COOLANT_FLOOD_PORTPORTC
[*]#define COOLANT_FLOOD_BIT   3// Uno Analog Pin 3
[*]#ifdef ENABLE_M7
[*]#endif
[*]#endif
[*]#ifdef PIN_MAP_ARDUINO_MEGA_2560 // Working @EliteEng
[*]#define SERIAL_RX USART0_RX_vect
[*]#define SERIAL_UDRE USART0_UDRE_vect
[*]// Increase Buffers to make use of extra SRAM
[*]#define RX_BUFFER_SIZE 256
[*]#define TX_BUFFER_SIZE 128
[*]#define BLOCK_BUFFER_SIZE 36
[*]#define LINE_BUFFER_SIZE 100
[*]#define STEPPING_DDR      DDRA
[*]#define STEPPING_PORT   PORTA
[*]#define STEPPING_PIN      PINA
[*]#define X_STEP_BIT      2 // MEGA2560 Digital Pin 24
[*]#define Y_STEP_BIT      3 // MEGA2560 Digital Pin 25
[*]#define Z_STEP_BIT      4 // MEGA2560 Digital Pin 26
[*]#define X_DIRECTION_BIT   5 // MEGA2560 Digital Pin 27
[*]#define Y_DIRECTION_BIT   6 // MEGA2560 Digital Pin 28
[*]#define Z_DIRECTION_BIT   7 // MEGA2560 Digital Pin 29
[*]#define STEPPERS_DISABLE_PORTPORTB
[*]#define STEPPERS_DISABLE_BIT   7 // MEGA2560 Digital Pin 13
[*]#define X_LIMIT_BIT   4 // MEGA2560 Digital Pin 10
[*]#define Y_LIMIT_BIT   5 // MEGA2560 Digital Pin 11
[*]#define Z_LIMIT_BIT   6 // MEGA2560 Digital Pin 12
[*]#define SPINDLE_ENABLE_DDR   DDRC
[*]#define SPINDLE_ENABLE_PORTPORTC
[*]#define SPINDLE_ENABLE_BIT   2 // MEGA2560 Digital Pin 35
[*]#define SPINDLE_DIRECTION_DDR   DDRC
[*]#define SPINDLE_DIRECTION_PORTPORTC
[*]#define SPINDLE_DIRECTION_BIT   1 // MEGA2560 Digital Pin 36
[*]#define COOLANT_FLOOD_BIT   0 // MEGA2560 Digital Pin 37
[*]#ifdef ENABLE_M7
[*]    #define COOLANT_MIST_BIT   3 // MEGA2560 Digital Pin 34
[*]#endif
[*]#define PINOUT_DDR       DDRK
[*]#define PINOUT_PIN       PINK
[*]#define PINOUT_PORT      PORTK
[*]#define PIN_RESET      0// MEGA2560 Analog Pin 8
[*]#define PIN_FEED_HOLD    1// MEGA2560 Analog Pin 9
[*]#define PIN_CYCLE_START2// MEGA2560 Analog Pin 10
[*]#define PINOUT_INT       PCIE2// Pin change interrupt enable pin
[*]#define PINOUT_INT_vectPCINT2_vect
[*]#define PINOUT_PCMSK   PCMSK2 // Pin change interrupt register
[*]#endif
[*]#ifdef PIN_MAP_CUSTOM_PROC
[*]// For a custom pin map or different processor, copy and paste one of the default pin map
[*]// settings above and modify it to your needs. Then, make sure the defined name is also
[*]// changed in the config.h file.
[*]#endif
[*]#endif
pinmap中其实定义的是三种单片机的引脚定义,具体使用哪一个在config.h中有定义,如下: view plain copy
[*]#define PIN_MAP_STM32
[*]//#define PIN_MAP_ARDUINO_UNO
由于我修改的是STM32的,所以我额外定义了个STM32的选项,可以看到我使用的是不同通道的IO,所以定义起来就有所小不同,为了尽量少修改GRBL源程序,尽量修改定义这地方的代码,减少调用出代码的修改stepper.c中关于引脚的初始化如下:
view plain copy
[*]/ Initialize and start the stepper motor subsystem
[*]void st_init()
[*]// Configure directions of interface pins
[*]//STEPPING_DDR |= STEPPING_MASK;
[*]//STEPPING_PORT = (STEPPING_PORT & ~STEPPING_MASK) | settings.invert_mask;
[*]//STEPPERS_DISABLE_DDR |= 1<<STEPPERS_DISABLE_BIT;
[*]//ZJK ADD FOR STEP_IO INIT
[*]GPIO_InitTypeDef GPIO_InitStructure;
[*]//X_STEP:PA8
[*]RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA,ENABLE);
[*]GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
[*]GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
[*]GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
[*]GPIO_Init(GPIOA, &GPIO_InitStructure);
[*]X_STEP_PORT = (X_STEP_PORT & ~X_STEP_MASK) | (settings.invert_mask&X_STEP_MASK);
[*]//Y_STEP:PD15
[*]RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD,ENABLE);
[*]GPIO_InitStructure.GPIO_Pin = GPIO_Pin_15;
[*]GPIO_Init(GPIOD, &GPIO_InitStructure);
[*]Y_STEP_PORT = (Y_STEP_PORT & ~Y_STEP_MASK) | (settings.invert_mask&Y_STEP_MASK);
[*]//X_DIR :PA6
[*]GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;
[*]X_DIRECTION_PORT = (X_DIRECTION_PORT & ~X_DIRECTION_MASK) | (settings.invert_mask&X_DIRECTION_MASK);
[*]//Y_DIR :PA2
[*]GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
[*]Y_DIRECTION_PORT = (Y_DIRECTION_PORT & ~Y_DIRECTION_MASK) | (settings.invert_mask&Y_DIRECTION_MASK);
[*]//X_RES :PA3
[*]GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3;
[*]//Y_RES :PA4
[*]GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4;
[*]//END ZJK STEPP_IO INIT
view plain copy
[*]//接下来是定时器的初始化参考:<a target=_blank href="http://blog.csdn.net/zhangjikuan/article/details/46697657">http://blog.csdn.net/zhangjikuan/article/details/46697657</a>
调用处如下所示: view plain copy
[*]//定时器4中断服务函数
[*]void TIM4_IRQHandler(void) //中断服务函数名一定正确
[*]    if(TIM4->SR&0X0001)//再次判断是否更新事件
[*]      // Reset stepping pins (leave the direction pins)
[*]      //STEPPING_PORT = (STEPPING_PORT & ~STEP_MASK) | (settings.invert_mask & STEP_MASK);
[*]      X_STEP_PORT = (X_STEP_PORT & ~X_STEP_MASK) | (settings.invert_mask & X_STEP_MASK);
[*]      Y_STEP_PORT = (Y_STEP_PORT & ~Y_STEP_MASK) | (settings.invert_mask & Y_STEP_MASK);
[*]      //TCCR2B = 0; // Disable Timer2 to prevent re-entering this interrupt when it's not needed.
[*]      //bit0=1关闭定时器
[*]      TIM4->CR1&=~0X01;
[*]    TIM4->SR&=~(1<<0); //状态寄存器清除
页: [1]
查看完整版本: GRBL七: STM32代码移植——IO
