LPC1114基于定时器的onewire程序,可用于DHT11
#define AM2302_L LPC_GPIO0->DATA &= ~(1<<1)#define AM2302_I GPIOSetDir(0, 1,0)
#define AM2302_O GPIOSetDir(0, 1,1)
#define AM2302_D LPC_GPIO0->DATA & (1<<1)
#define TMR32_0_TCLPC_TMR32B0->TC
void Timer32_0_Start(void)
LPC_TMR32B0->TCR = 2;
LPC_TMR32B0->TCR = 1;
/*us延时函数 */
void Timer32_0_Delay_us(uint32_t Timer_Count)
Timer32_0_Start();
while(TMR32_0_TC < Timer_Count);
uint32_t AM2302_READ(void)
uint64_t data_temp= 0;
uint32_t timer_temp = 0;
uint32_t data = 0;
uint8_t crc1 = 0;
uint8_t crc2 = 0;
uint8_t AM2302 = 0;
uint8_t Counter = 0;
AM2302_O; //引脚设置为输出
AM2302_L; //拉低
Timer32_0_Delay_us(1000); //延时1ms (如果是DHT11改为20000)
Timer32_0_Start(); //启动us定时器
AM2302_I; //引脚设置为输入
while(TMR32_0_TC < 5000) //5ms内结束
if( AM2302_D )
if(AM2302 == 0)
if( AM2302_D )
{AM2302 = 1;}
else
if(AM2302 == 1)
if( !(AM2302_D) )
AM2302 = 0;
if( (TMR32_0_TC - timer_temp) > 98 ) //单个CLK大于98us认为是1
{data_temp |= ( 0x20000000000 >> Counter );}
timer_temp = TMR32_0_TC;
if(++Counter == 42)
{TMR32_0_TC = 5000;}
if(Counter == 42)
data = data_temp >> 8;
crc1 = data_temp;
crc2 = (data>>24) + (data>>16) + (data>>8) + data;
if(crc1 != crc2)
{data = 0;}
else
data = 0x80000000;
return data;
页:
[1]
