Clovee 发表于 2017-10-20 10:19
TMS320F28335的GPIO
TMS320F28335的GPIO
F28335有三种32位的I/O口,依次PORTA(GPIO0-GPIO31),PORTB(GPIO32-GPIO63),PORTC(GPIO64-GPIO87),这些口都可以配置为普通的数字IO口同样也能被配置为外部接口。这样涉及到了IO的寄存器,IO口共有三类寄存器:控制寄存器、数据寄存器和中断控制寄存器。下面依次介绍这些寄存器。
[*]struct GPIO_CTRL_REGS {
[*]   unionGPACTRL_REGGPACTRL;      // GPIO A Control Register (GPIO0 to 31)
[*]   unionGPA1_REG      GPAQSEL1;   // GPIO A Qualifier Select 1 Register (GPIO0 to 15)
[*]   unionGPA2_REG      GPAQSEL2;   // GPIO A Qualifier Select 2 Register (GPIO16 to 31)
[*]   unionGPA1_REG      GPAMUX1;    // GPIO A Mux 1 Register (GPIO0 to 15)
[*]   unionGPA2_REG      GPAMUX2;    // GPIO A Mux 2 Register (GPIO16 to 31)
[*]   unionGPADAT_REG    GPADIR;            // GPIO A Direction Register (GPIO0 to 31)
[*]   unionGPADAT_REG    GPAPUD;      // GPIO A Pull Up Disable Register (GPIO0 to 31)
[*]   Uint32               rsvd1;
[*]   unionGPBCTRL_REGGPBCTRL;   // GPIO B Control Register (GPIO32 to 63)
[*]   unionGPB1_REG      GPBQSEL1;// GPIO B Qualifier Select 1 Register (GPIO32 to 47)
[*]   unionGPB2_REG      GPBQSEL2;// GPIO B Qualifier Select 2 Register (GPIO48 to 63)
[*]   unionGPB1_REG      GPBMUX1;   // GPIO B Mux 1 Register (GPIO32 to 47)
[*]   unionGPB2_REG      GPBMUX2;   // GPIO B Mux 2 Register (GPIO48 to 63)
[*]   unionGPBDAT_REG    GPBDIR;      // GPIO B Direction Register (GPIO32 to 63)
[*]   unionGPBDAT_REG    GPBPUD;   // GPIO B Pull Up Disable Register (GPIO32 to 63)
[*]   Uint16                rsvd2;
[*]   unionGPC1_REG      GPCMUX1;   // GPIO C Mux 1 Register (GPIO64 to 79)
[*]   unionGPC2_REG      GPCMUX2;   // GPIO C Mux 2 Register (GPIO80 to 95)
[*]   unionGPCDAT_REG    GPCDIR;      // GPIO C Direction Register (GPIO64 to 95)
[*]   unionGPCDAT_REG    GPCPUD;    // GPIO C Pull Up Disable Register (GPIO64 to 95)
复制代码
       其中GPXCTRL寄存器的作用是设置采样窗周期T=2*GPXCTRL*Tsysclk;GPxQSEL中每两位控制一个引脚,确定是3周期采样还是6周期采样或者不用采样;GPxMUX的功能很简单就是配置各个引脚的功能,或者是数字IO口,或者是外部接口。同样是两位控制一个引脚;GPxDIR是控制每个引脚的输入或是输出,0是输入,1是输出。还有一个GPxPUD寄存器,是用来使能或禁止指定接口的内部上拉。以上这些就是属于IO口的控制寄存器。下面的是IO数据类寄存器所有集合
[*]struct GPIO_DATA_REGS {
[*]   unionGPADAT_REG   GPADAT;         // GPIO Data Register (GPIO0 to 31)
[*]   unionGPADAT_REG   GPASET;         // GPIO Data Set Register (GPIO0 to 31)
[*]   unionGPADAT_REG   GPACLEAR;   // GPIO Data Clear Register (GPIO0 to 31)
[*]   unionGPADAT_REG   GPATOGGLE;   // GPIO Data Toggle Register (GPIO0 to 31)
[*]   unionGPBDAT_REG   GPBDAT;         // GPIO Data Register (GPIO32 to 63)
[*]   unionGPBDAT_REG   GPBSET;         // GPIO Data Set Register (GPIO32 to 63)
[*]   unionGPBDAT_REG   GPBCLEAR;   // GPIO Data Clear Register (GPIO32 to 63)
[*]   unionGPBDAT_REG   GPBTOGGLE;   // GPIO Data Toggle Register (GPIO32 to 63)
[*]   unionGPCDAT_REG   GPCDAT;         // GPIO Data Register (GPIO64 to 95)
[*]   unionGPCDAT_REG   GPCSET;         // GPIO Data Set Register (GPIO64 to 95)
[*]   unionGPCDAT_REG   GPCCLEAR;   // GPIO Data Clear Register (GPIO64 to 95)
[*]   unionGPCDAT_REG   GPCTOGGLE;   // GPIO Data Toggle Register (GPIO64 to 95)
[*]   Uint16                  rsvd1;};这些寄存器就是为了写数据,读数据用的。再下面就是中断寄存器struct GPIO_INT_REGS {
[*]   unionGPIOXINT_REG   GPIOXINT1SEL; // XINT1 GPIO Input Selection
[*]   unionGPIOXINT_REG   GPIOXINT2SEL; // XINT2 GPIO Input Selection
[*]   unionGPIOXINT_REG   GPIOXNMISEL;// XNMI_Xint13 GPIO Input Selection
[*]   unionGPIOXINT_REG   GPIOXINT3SEL; // XINT3 GPIO Input Selection
[*]   unionGPIOXINT_REG   GPIOXINT4SEL; // XINT4 GPIO Input Selection
[*]   unionGPIOXINT_REG   GPIOXINT5SEL; // XINT5 GPIO Input Selection
[*]   unionGPIOXINT_REG   GPIOXINT6SEL; // XINT6 GPIO Input Selection
[*]   unionGPIOXINT_REG   GPIOXINT7SEL; // XINT7 GPIO Input Selection
[*]   unionGPADAT_REG       GPIOLPMSEL;   // Low power modes GP I/O input select
复制代码
       以上就是IO口的外部中断寄存器,我们可以对上面GPIO0-GPIO63进行外部中断配置。
pklong 发表于 2017-10-20 21:24
手把手教你学DSP—基于TMS320F2833 这个很全面。
touser 发表于 2017-10-20 21:24
《TMS320F28335DSP原理与开发编程》介绍的非常详细。
myiclife 发表于 2017-10-20 21:25
IO的定义都差不多的。
pklong 发表于 2017-10-20 21:27
DSP28335 GPIO模块分为三类IO口:PORTA(0-31),PORTB(32-63),PORTC(64-87)
touser 发表于 2017-10-20 21:27
这个是哪里的头文件?
myiclife 发表于 2017-10-20 21:27
普通的数字IO的驱动能力不足,需要上拉电阻补充。
页: [1]
查看完整版本: TMS320F28335的GPIO
