Peonys 发表于 2017-11-9 10:37
FSK信号鉴频的程序
FSK信号鉴频的程序
[*]/* This program implements the function of finding out the largest */
[*]/* and the second largest values of the sequence of "in_buffer"*/
[*]#include <stdio.h>
[*]#include <math.h>
[*]#include "freq_max_finding.h"
[*]//extern float cosf(float x);
[*]extern int in_buffer={0,0,0,0,0,0,0,0,0,0}; /* in_buffer[]中的值为频谱点 */
[*]//int out_buffer;
[*]static void dataIN(void);
[*]void main()
[*]      int                i=0;
[*]//      float         data_max=0;
[*]      int                data_max=0;
[*]//      float         data_max2=0;
[*]      int   data_max2=0;
[*]      int         i_max=0;
[*]      int         i_max2=0;
[*]      float         f_max=0;
[*]      float         f_max2=0;
[*]      int                p=0;
[*]      int                q=0;
[*]//      float a=0, b=3.14159;
[*]//      a=a+0;
[*]//      b=b+0;
[*]//      a=cosf(b);
[*]      /** 几句废话,消除warning:data_max was set but never used **/
[*]      data_max=data_max+0;
[*]      data_max2=data_max2+0;
[*]//      i_max=i_max+0;
[*]//      i_max2=i_max2+0;
[*]      f_max=f_max+0;
[*]      f_max2=f_max2+0;
[*]      dataIN();      /* read data into memory */
[*]/** find out the greatest value of "in_buffer" **/
[*]      for(i=0;i<=POINT_ALL-2;i++)
[*]               if (in_buffer>in_buffer)
[*]                           {data_max=in_buffer; i_max=i+1;}
[*]               else {data_max=in_buffer; i_max=i;}
[*]      f_max=FS*i_max/POINT_ALL; /* calculate the value of carrier frequency */
[*]/* find out the second greatest value of "in_buffer" */
[*]                in_buffer=0;      /* set 0 to "in_buffer"*/
[*]                for(p=1;p<=POINT_ALL/2;p++)
[*]                         for(q=0;q<=POINT_ALL/2-2;q++)
[*]                                                    {data_max2=in_buffer; i_max2=q+1;}
[*]                                    else      {data_max2=in_buffer; i_max2=q;}
[*]                         /* determines the availability of i_max2 through
[*]                            estimating the distance of i_max between i_max2 */
[*]                         if (abs(i_max-i_max2)<=GAP)      in_buffer=0;
[*]                         else      break;
[*]                f_max2=FS*i_max2/POINT_ALL;      /* calculate the value of carrier frequency2 */
[*]      while(1);
[*]static void dataIN()
[*]      /* do read data from host file */
[*]      return;
复制代码
页: [1]
查看完整版本: FSK信号鉴频的程序
