28069_RAM_lnk.cmd
"../28069_RAM_lnk.cmd", line 113: error #10099-D: program will not fit into available memory. placement with alignment/blocking fails for section ".text" size 0x2210 page 0. Available memory ranges:RAML0_L3 size: 0x2000 unused: 0x2000 max hole: 0x2000
我应该怎么修改cmd文件比较合适?
如果直接修改 RAML0_L3 : origin = 0x008000, length = 0x002000 中的 length = 0x003000 是否可以?
谢谢
页:
[1]
