STM32F407 PDM转PCM问题
rt我在调试数字麦克风时,接收到的是PDM格式的音频数据,需要转换成PCM。我在调用ST官网上下载的libPDMFilter_Keil.lib库中的PDM_Filter_64_LSB函数时,进入了HardFault_Handler,请问有哪个大神知道是什么原因吗?
代码如下:
#include "sph0644.h"
#include "pdm_filter.h"
#define INTERNEL_BUFF_SIZE 64
#define PCM_OUT_SIZE 16
PDMFilter_InitStruct Filter;
u16 PDM_Output_Buffer;
u16 *pAudioRecBuf;
u16 InternalBuffer;
u16 InternalBufferSize = 0;
static void Sph0644_Config(void)
GPIO_InitTypeDefGPIO_InitStructure;
NVIC_InitTypeDef NVIC_InitStructure;
RCC_AHB1PeriphClockCmd(SPI_SCK_GPIO_CLK|SPI_MOSI_GPIO_CLK, ENABLE);//ʹÄÜÍâÉèGPIOB,GPIOCʱÖÓ
GPIO_InitStructure.GPIO_Pin = SPI_SCK_PIN;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;//¸´Óù¦ÄÜ
GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;//ÍÆÍì
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;//100MHz
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;//ÉÏÀ
GPIO_Init(SPI_SCK_GPIO_PORT, &GPIO_InitStructure);//³õʼ»¯
GPIO_InitStructure.GPIO_Pin =SPI_MOSI_PIN;
GPIO_Init(SPI_MOSI_GPIO_PORT, &GPIO_InitStructure);//³õʼ»¯
GPIO_PinAFConfig(SPI_SCK_GPIO_PORT,SPI_SCK_SOURCE,SPI_SCK_AF); //PB13,AF5I2S_SCLK
GPIO_PinAFConfig(SPI_MOSI_GPIO_PORT,SPI_MOSI_SOURCE,SPI_MOSI_AF); //PC3 ,AF5I2S_DACDATA
I2S2_Init(I2S_Standard_LSB,I2S_Mode_MasterRx,I2S_CPOL_High,I2S_DataFormat_16b);
I2S2_SampleRate_Set(32000); //ÉèÖòÉÑùÂÊ
// Configure the SPI interrupt priority
NVIC_InitStructure.NVIC_IRQChannel = SPI2_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 6;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
SPI_I2S_ITConfig(SPI2,SPI_I2S_IT_RXNE,ENABLE);
void Sph0644_Init(void)
//Enable CRC module/*
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_CRC, ENABLE);
//ÅäÖÃI2S2£¬CLKƵÂÊ1024MHz
Sph0644_Config();
//16KHz,ÔÚ´Ë֮ǰ£¬±ØÐ뿪ÆôCRCʱÖÓ£¬·ñÔò½øÈëËÀÑ»·
Filter.LP_HZ = 8000;
Filter.HP_HZ = 10;
Filter.Fs = 16000;
Filter.Out_MicChannels = 1;
Filter.In_MicChannels = 1;
PDM_Filter_Init(&Filter);
void Sph0644_Start(void)
pAudioRecBuf = PDM_Output_Buffer;
I2S_Cmd(SPI2,ENABLE);
void Sph0644_Stop(void)
I2S_Cmd(SPI2,DISABLE);
void SPI2_IRQHandler(void)
u16 app;
u16 volume;
if(SPI_GetITStatus(SPI2,SPI_I2S_IT_RXNE) == SET)
app = SPI_I2S_ReceiveData(SPI2);
InternalBuffer = HTONS(app);
if(InternalBufferSize >= INTERNEL_BUFF_SIZE)
volume = 50;
PDM_Filter_64_LSB((u8*)InternalBuffer,pAudioRecBuf,volume,&Filter);
} 是不是内存溢出 已经找到原因了,是其他地方占用内存比较多,调用库的时候导致内存溢出。 你好,看到您有处理过PDM转PCM数据,你那还有这个代码备份吗?能分享一下经验不,我现在使用的st的mems数字麦克风,得到了PDM数据,但是转换成PCM计算声压级dBs数据,出来老是80左右的分贝值,而环境实际只有40-50左右的分贝大小。
页:
[1]
