初踏江湖 发表于 2017-12-15 15:05
Mesa8.0.4交叉编译
交叉编译Mesa的时候出现如下问题
Regenerating builtin_function.cpp...
python2 -t -O -O builtins/tools/generate_builtins.py ./builtin_compiler > builtin_function.cpp || rm -f builtin_function.cpp
Traceback (most recent call last):
File "builtins/tools/generate_builtins.py", line 199, in <module>
    write_profiles()
File "builtins/tools/generate_builtins.py", line 104, in write_profiles
    write_profile(filename, profile)
File "builtins/tools/generate_builtins.py", line 76, in write_profile
    (proto_ir, returncode) = run_compiler()
File "builtins/tools/generate_builtins.py", line 63, in run_compiler
    p = Popen(command, 1, stdout=PIPE, shell=False)
File "/usr/lib/python2.7/subprocess.py", line 679, in __init__
    errread, errwrite)
File "/usr/lib/python2.7/subprocess.py", line 1249, in _execute_child
    raise child_exception
OSError: Exec format error
初踏江湖 发表于 2017-12-20 08:35
解决了 先编译x86的 编译出来编译成功的builtin_compile那个应用存起来 在编译arm的出错后把x86提换在编译就可以了
静默的羔羊 发表于 2017-12-22 16:42
这是啥东西,表看不懂
页: [1]
查看完整版本: Mesa8.0.4交叉编译
