i.MX6编译报错
seuls@ubuntu:~/fsl-release-bsp/build-dfb$ bitbake fsl-image-guiWARNING: Host distribution "Ubuntu-16.04" has not been validated with this version of the build system; you may possibly experience unexpected failures. It is recommended that you use a tested distribution.
Loading cache: 100% |###########################################| ETA:00:00:00
Loaded 2565 entries from dependency cache.
NOTE: Resolving any missing task queue dependencies
NOTE: multiple providers are available for jpeg (jpeg, libjpeg-turbo)
NOTE: consider defining a PREFERRED_PROVIDER entry to match jpeg
NOTE: multiple providers are available for jpeg-native (jpeg-native, libjpeg-turbo-native)
NOTE: consider defining a PREFERRED_PROVIDER entry to match jpeg-native
Build Configuration:
BB_VERSION = "1.26.0"
BUILD_SYS = "i686-linux"
NATIVELSBSTRING = "Ubuntu-16.04"
TARGET_SYS = "arm-poky-linux-gnueabi"
MACHINE = "imx6qsabreauto"
DISTRO = "poky"
DISTRO_VERSION = "1.8"
TUNE_FEATURES = "arm armv7a vfp thumb neon callconvention-hard cortexa9"
TARGET_FPU = "vfp-neon"
meta
meta-yocto = "(nobranch):83aa565d93aacae484976562ef1ae8dbbb6b2bc0"
meta-oe
meta-multimedia = "(nobranch):10d3c8f85280a0bf867a8e4f84bcda81c290d28e"
meta-fsl-arm = "(nobranch):c5326c90d6754c8630504ae29244907b0841c3a9"
meta-fsl-arm-extra = "(nobranch):436b86e3421736216412bdbb21cd9cb08c758c75"
meta-fsl-demos = "(nobranch):836bdf5a9d500ed258f1ddc07d89eca74a704098"
meta-bsp
meta-sdk = "(nobranch):2f59ef1080f616f391b1c488fb2204e570f90239"
meta-browser = "(nobranch):4b27058a8275a5310161459c9bb8f4c52a77762c"
meta-gnome
meta-networking
meta-python
meta-ruby
meta-filesystems= "(nobranch):10d3c8f85280a0bf867a8e4f84bcda81c290d28e"
meta-qt5 = "(nobranch):fc026381545650e10fdd488d5b2a3b2d78f87793"
NOTE: Preparing RunQueue
NOTE: Executing SetScene Tasks
NOTE: Executing RunQueue Tasks
ERROR: Command Error: exit status: 1Output:
Applying patch gstplaybin-enable-native-video.patch
patching file gst/playback/gstplaybin2.c
Hunk #1 FAILED at 511.
1 out of 1 hunk FAILED -- rejects in file gst/playback/gstplaybin2.c
Patch gstplaybin-enable-native-video.patch does not apply (enforce with -f)
ERROR: Function failed: patch_do_patch
ERROR: Logfile of failure stored in: /home/seuls/fsl-release-bsp/build-dfb/tmp/work/cortexa9hf-vfp-neon-mx6qdl-poky-linux-gnueabi/gstreamer1.0-plugins-base/1.4.5-r0/temp/log.do_patch.29220
ERROR: Task 2645 (/home/seuls/fsl-release-bsp/sources/poky/meta/recipes-multimedia/gstreamer/gstreamer1.0-plugins-base_1.4.5.bb, do_patch) failed with exit code '1'
文档上要求安装的包都装了吗?我也刚接触用14.04,还在编译中。。。 阿南 发表于 2017-12-20 09:40
文档上要求的都安装了,用的是Ubuntu16.04 Seuls1211 发表于 2017-12-20 13:28
文档上好像只注明了14.04和12.04,并没有注明16.04。楼主只下载安装到一半?还是一点都没下载就出错了 阿南 发表于 2017-12-20 13:41
文档上好像只注明了14.04和12.04,并没有注明16.04。楼主只下载安装到一半?还是一点都没下载就出错了 ...
换到14.04就可以了。下载到一半报的错
页:
[1]
