coffee1 发表于 2018-1-29 15:28
STM32 LED灯的另一种写法
view plain copy
#ifndef __BSP_LED_
#define __BSP_LED_
#include <MM32x103.h> // 这个换成STM32的库文件就行
#include "type.h"
#define LED1_RUN_GRP      GPIOC
#define LED1_RUN_IDX      GPIO_Pin_6
#define LED1_RUN_OFF()    GPIO_ResetBits(LED1_RUN_GRP, LED1_RUN_IDX)
#define LED1_RUN_ON()   GPIO_SetBits(LED1_RUN_GRP, LED1_RUN_IDX)
#define LED1_RUN_IS_OFF() GPIO_ReadOutputDataBit(LED1_RUN_GRP, LED1_RUN_IDX)
#define LED2_RUN_GRP      GPIOA
#define LED2_RUN_IDX      GPIO_Pin_11
#define LED2_RUN_OFF()    GPIO_ResetBits(LED2_RUN_GRP, LED2_RUN_IDX)
#define LED2_RUN_ON()   GPIO_SetBits(LED2_RUN_GRP, LED2_RUN_IDX)
#define LED2_RUN_IS_OFF() GPIO_ReadOutputDataBit(LED2_RUN_GRP, LED2_RUN_IDX)
#define LED3_RUN_GRP      GPIOA
#define LED3_RUN_IDX      GPIO_Pin_12
#define LED3_RUN_OFF()    GPIO_ResetBits(LED3_RUN_GRP, LED3_RUN_IDX)
#define LED3_RUN_ON()   GPIO_SetBits(LED3_RUN_GRP, LED3_RUN_IDX)
#define LED3_RUN_IS_OFF() GPIO_ReadOutputDataBit(LED3_RUN_GRP, LED3_RUN_IDX)
#define LED_COUNT   3 // LED个数自己定义
typedef enum
RED   = 0x04,
GREEN = 0x02,
BLUE= 0x01
} led_t;
typedef struct
GPIO_TypeDef *GPIOx;
uint32_t pos;
} led_port_t;
void GPIOConfig(GPIO_TypeDef* GPIOx, uint16_t GPIO_Pin, GPIOMode_TypeDef GPIO_Mode);
void LEDConfig((uint8_t value) // value:1/2/4 --- RED GREEN BLUE
void LEDSet(uint8_t value);
void LEDReset(uint8_t value);
void LEDToggle(uint8_t value);
#endif /* __BSP_LED_ */
view plain copy
#include "bsp_led.h"
static led_port_t led_port =
{LED1_RUN_GRP, LED1_RUN_IDX}, /*蓝灯*/
{LED2_RUN_GRP, LED2_RUN_IDX}, /*绿灯*/
{LED3_RUN_GRP, LED3_RUN_IDX}, /*红灯*/
// GPIO配置
GPIO_InitTypeDef GPIO_InitStructure;//定义GPIO初始化结构体变量
// 这个GPIO口需要改的,根据自己情况而定
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC | RCC_APB2Periph_GPIOA, ENABLE);//开启GPIO时钟
//配置连接LED的GPIO为推挽输出模式
GPIO_InitStructure.GPIO_Pin=GPIO_Pin;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode;
GPIO_Init(GPIOx, &GPIO_InitStructure);
// LED GPIO配置
uint8_t i, mask = 1;
for(i = 0; i < LED_COUNT; ++i)
    if(value & mask)
      GPIOConfig(led_port.GPIOx, led_port.pos, GPIO_Mode_Out_PP);
      GPIO_ResetBits(led_port.GPIOx, led_port.pos);
    mask <<= 1;
/* 根据参数来打开LED灯 */
    if(value & mask)
      GPIO_SetBits(led_port.GPIOx, led_port.pos);
    mask <<= 1;
/* 根据参数来关闭LED灯 */
    if(value & mask)
    mask <<= 1;
// 取反
    if(value & mask)
      if(GPIO_ReadOutputDataBit(led_port.GPIOx, led_port.pos) == 0)
      else
    mask <<= 1;
dirtwillfly 发表于 2018-2-4 18:04
感谢分享
Prry 发表于 2018-2-5 11:54
Linux的思想就是这样干的
页: [1]
查看完整版本: STM32 LED灯的另一种写法
