一路向北lm 发表于 2018-6-16 08:28
基于单片机12864单片机简易示波器
1.程序源码 下载地址:
#include <STC12c5a.H>
#include<intrins.h>
#include<math.h>
sbit RS=P1^0; //并行的指令/数据选择信号, H数据, L命令
sbit RW=P1^1; //并行读写选择信号, H读, L写
sbit E=P1^2; //并行使能端, H有效, L无效
sbit jiakey=P3^0;
sbit jiankey=P3^1;
#defineLcdData P0
unsigned char dati=0;
unsigned char dat;
unsigned char over=0;
unsigned int temp=0;
unsigned char mode=0;
unsigned int delnop=0;
unsigned char Lcd_CheckBusy(void)
    unsigned char Busy;
          LcdData=0xff;
    RS=0;
    RW=1;
    E=1;
    _nop_();
    Busy=LcdData&0x80;
    E=0;
    return Busy;
向LCD写入字节数据
void Lcd_WriteData(unsigned char Data)
        while(Lcd_CheckBusy());
        RS=1;
        RW=0;
        E=0;
        _nop_();
        _nop_();
        LcdData=Data;
        E=1;
        _nop_();
        _nop_();
        E=0;
从LCD中读出数据
unsigned char Lcd_ReadData(void)
        unsigned char Temp;
        LcdData=0xff;
        RS=1;
        RW=1;
        E=1;
        _nop_();
           Temp=LcdData;
           E=0;
           return Temp;
想LCD中写入指令代码
void Lcd_WriteCmd(unsigned char CmdCode)
           RS=0;
           RW=0;
           E=0;
           _nop_();
        _nop_();
           LcdData=CmdCode;
           _nop_();
        _nop_();
           E=1;
           _nop_();
        _nop_();
           E=0;
为加速逻辑运算而设置的掩码表,这是以牺牲空间而换取时间的办法
code unsigned int LcdMaskTab[]={0x0001,0x0002,0x0004,0x0008,0x0010,0x0020,0x0040,0x0080,0x0100,0x0200,0x0400,0x0800,0x1000,0x2000,0x4000,0x8000};
向LCD指定坐标写入一个象素,象素颜色有两种,0代表白(无显示),1代表黑(有显示)
void Lcd_PutPixel(unsigned char x,unsigned char y,unsigned char Color)
        unsigned char z,w;
        unsigned int Temp;
        if(x>=128||y>=64)
                return;
        Color=Color%2;
        w=15-x%16;//确定对这个字的第多少位进行操作
        x=x/16;//确定为一行上的第几字
        if(y<32) //如果为上页
                z=0x80;
        else   //否则如果为下页
                z=0x88;
        y=y%32;
        //EA=0;
        Lcd_WriteCmd(0x36);
        Lcd_WriteCmd(y+0x80);      //行地址
        Lcd_WriteCmd(x+z);   //列地址
        Temp=Lcd_ReadData();//先空读一次
        Temp=(unsigned int)Lcd_ReadData()<<8;//再读出高8位
        Temp|=(unsigned int)Lcd_ReadData();//再读出低8位
        //EA=1;
        if(Color==1) //如果写入颜色为1
                Temp|=LcdMaskTab;//在此处查表实现加速
        else         //如果写入颜色为0
                Temp&=~LcdMaskTab;//在此处查表实现加速
        //EA=0;
   Lcd_WriteData(Temp>>8);//先写入高8位,再写入低8位
   Lcd_WriteData(Temp&0x00ff);
        Lcd_WriteCmd(0x30);
        //EA=1;
清除Lcd全屏,如果清除模式Mode为0,则为全屏清除为颜色0(无任何显示)
否则为全屏清除为颜色1(全屏填充显示)
void Lcd_Clear(unsigned char Mode)
        unsigned char x,y,ii;
        unsigned char Temp;
        if(Mode%2==0)
                Temp=0x00;
        else
                Temp=0xff;
        Lcd_WriteCmd(0x36);//扩充指令 绘图显示
        for(ii=0;ii<9;ii+=8)
                for(y=0;y<0x20;y++)
                        for(x=0;x<8;x++)
                                //EA=0;
                                Lcd_WriteCmd(x+0x80+ii);   //列地址
                                Lcd_WriteData(Temp); //写数据 D15-D8
                                Lcd_WriteData(Temp); //写数据 D7-D0
                                //EA=1;
        Lcd_WriteCmd(0x30);
LCD初始化
void Lcd_Reset()
        Lcd_WriteCmd(0x30);       //选择基本指令集
        Lcd_WriteCmd(0x0c);       //开显示(无游标、不反白)
        Lcd_WriteCmd(0x01);       //清除显示,并且设定地址指针为00H
        Lcd_WriteCmd(0x06);       //指定在资料的读取及写入时,设定游标的移动方向及指定显示的移位
void InitADC()
P1ASF=0X80;
ADC_RES=0;
ADC_CONTR=0xef;
EADC=1;
void adc_isr() interrupt 5 using 1
ADC_CONTR=0xef;
if(over==0)
        temp=delnop;
        while(temp)
        temp--;
        dat=ADC_RES;
        dati++;
        if(dati>100)
        dati=0;
        over=1;
void disp_0(unsigned char x,unsigned char y)
Lcd_PutPixel(x+1,y+1,1);
Lcd_PutPixel(x+1,y+2,1);
Lcd_PutPixel(x+1,y+3,1);
Lcd_PutPixel(x+2,y+0,1);
Lcd_PutPixel(x+2,y+4,1);
Lcd_PutPixel(x+3,y+1,1);
Lcd_PutPixel(x+3,y+2,1);
Lcd_PutPixel(x+3,y+3,1);
void disp_1(unsigned char x,unsigned char y)
Lcd_PutPixel(x+1,y+4,1);
Lcd_PutPixel(x+2,y+1,1);
Lcd_PutPixel(x+2,y+2,1);
Lcd_PutPixel(x+2,y+3,1);
Lcd_PutPixel(x+3,y+4,1);
void disp_2(unsigned char x,unsigned char y)
Lcd_PutPixel(x+1,y+0,1);
Lcd_PutPixel(x+3,y+0,1);
void disp_3(unsigned char x,unsigned char y)
void disp_4(unsigned char x,unsigned char y)
void disp_5(unsigned char x,unsigned char y)
void disp_p(unsigned char x,unsigned char y)
Lcd_PutPixel(x+0,y+0,1);
Lcd_PutPixel(x+4,y+0,1);
void disp_k(unsigned char x,unsigned char y)
Lcd_PutPixel(x+0,y+1,1);
Lcd_PutPixel(x+0,y+2,1);
Lcd_PutPixel(x+0,y+3,1);
Lcd_PutPixel(x+0,y+4,1);
void disp_hz(unsigned char x,unsigned char y)
Lcd_PutPixel(x+4,y+1,1);
Lcd_PutPixel(x+4,y+3,1);
Lcd_PutPixel(x+4,y+4,1);
Lcd_PutPixel(x+5,y+1,1);
Lcd_PutPixel(x+5,y+2,1);
Lcd_PutPixel(x+5,y+4,1);
void clr(unsigned char starx,unsigned char stary,unsigned char endx,unsigned char endy)
char x=0;
char y=0;
for(x=starx;x<endx;x++)
        for(y=stary;y<endy;y++)
                Lcd_PutPixel(x,y,0);
void disp_bj(void)
unsigned char x=0;
unsigned char y=0;
for(x=13;x<114;x++)
Lcd_PutPixel(x,52,1);
for(y=0;y<52;y++)
Lcd_PutPixel(13,y,1);
for(y=0;y<52;y++)
Lcd_PutPixel(114,y,1);
Lcd_PutPixel(13,51,0);
Lcd_PutPixel(13,41,0);
Lcd_PutPixel(13,31,0);
Lcd_PutPixel(13,21,0);
Lcd_PutPixel(13,11,0);
Lcd_PutPixel(13,1,0);
Lcd_PutPixel(114,51,0);
Lcd_PutPixel(114,41,0);
Lcd_PutPixel(114,31,0);
Lcd_PutPixel(114,21,0);
Lcd_PutPixel(114,11,0);
Lcd_PutPixel(114,1,0);
disp_0(5,50);
disp_1(5,40);
disp_2(5,30);
disp_3(5,20);
disp_4(5,10);
disp_5(5,0);
disp_0(117,50);
disp_1(117,40);
disp_2(117,30);
disp_3(117,20);
disp_4(117,10);
disp_5(117,0);
disp_2(13,58);
disp_hz(18,58);
disp_2(38,58);
disp_0(43,58);
disp_hz(48,58);
disp_2(63,58);
disp_0(68,58);
disp_0(73,58);
disp_hz(78,58);
disp_2(88,58);
disp_k(93,58);
disp_hz(98,58);
void line(unsigned char x0,unsigned char y0,unsigned char x1,unsigned char y1)
int i,dx,dy,e,x,y;
Lcd_PutPixel(x0,y0,1);
Lcd_PutPixel(x1,y1,1);
dx=x1-x0;
dy=y1-y0;
x=x0;
y=y0;
if(dx>0&&dy>0)
if(dx>dy)
e=-dx;
for(i=0;i<dx;i++)
        Lcd_PutPixel(x,y,1);
        x++;
        e=e+2*dy;
        if(e>=0)
                y++;
                e=e-2*dx;
else
e=-dy;
x=x0;
y=y0;
for(i=0;i<dy;i++)
        y++;
        e=e+2*dx;
        if(e>=0)
                x++;
                e=e-2*dy;
if(dx<0&&dy<0)
dx=x0-x1;
dy=y0-y1;
if(dx>dy)
e=-dx;
for(i=0;i<dx;i++)
        x--;
        e=e+2*dy;
        if(e>=0)
                y--;
                e=e-2*dx;
else
e=-dy;
for(i=0;i<dy;i++)
        y--;
        e=e+2*dx;
        if(e>=0)
                x--;
                e=e-2*dy;
if(dx>0&&dy<0)
dy=y0-y1;
if(dx>dy)
e=-dx;
for(i=0;i<dx;i++)
        x++;
        e=e+2*dy;
        if(e>=0)
                y--;
                e=e-2*dx;
else
e=-dy;
for(i=0;i<dy;i++)
        y--;
        e=e+2*dx;
        if(e>=0)
                x++;
                e=e-2*dy;
if(dx<0&&dy>0)
dx=x0-x1;
if(dx>dy)
e=-dx;
for(i=0;i<dx;i++)
        x--;
        e=e+2*dy;
        if(e>=0)
                y++;
                e=e-2*dx;
else
e=-dy;
for(i=0;i<dy;i++)
        y++;
        e=e+2*dx;
        if(e>=0)
                x--;
                e=e-2*dy;
if(dx!=0&&dy==0)
if(dx>0)
for(i=0;i<dx;i++)
        x++;
else
dx=x0-x1;
for(i=0;i<dx;i++)
        x--;
if(dx==0&&dy!=0)
if(dy>0)
for(i=0;i<dy;i++)
        y++;
else
dy=y0-y1;
for(i=0;i<dy;i++)
        y--;
void disp_ware()
unsigned char x=0;
unsigned char y=0;
                clr(14,0,15,52);
                for(x=1;x<100;x++)
                        clr(x+14,0,x+15,52);
                        line(x+13,51-(dat/5),x+14,51-(dat/5));
main()
Lcd_Reset();
Lcd_Clear(0);
InitADC();
disp_bj();
EA=1;
while(1)
if(over)
                disp_ware();
                if(jiakey==0)
                  if(mode<3)
                          mode++;
//                        while(!jiakey);
                if(jiankey==0)
                if(mode>0)
                        mode--;
//                        while(!jiankey);
        switch(mode)
        case 0:
                delnop=1;
                disp_p(91,54);
                clr(66,54,71,57);
                clr(41,54,46,57);
                clr(16,54,21,57);
        break;
        case 1:
                delnop=40;
                disp_p(66,54);
                clr(91,54,96,57);
                clr(41,54,46,57);
                clr(16,54,21,57);
        break;
        case 2:
                delnop=440;
                disp_p(41,54);
                clr(91,54,96,57);
                clr(66,54,71,57);
                clr(16,54,21,57);
        break;
        case 3:
                delnop=4440;
                disp_p(16,54);
                clr(91,54,96,57);
                clr(41,54,46,57);
                clr(66,54,71,57);
        break;
        default:
        break;
        over=0;
一路向北lm 发表于 2018-6-16 08:31
电路原理图(各种版本,AD.word)
一路向北lm 发表于 2018-6-16 08:32
3.PCB文件
caijie001 发表于 2018-6-16 15:05
一言不合就放代码。。。。。。。。。。。。。。。。。。。
这个示波器还凑合能用,能显示波形哦
蔬木果 发表于 2018-6-16 23:07
感谢楼主,最近正好需要这方面的资料。
一路向北lm 发表于 2018-6-17 10:38
本人亲测可用,满足基本波形,基本频率的测试,可以显示波形,感兴趣的可以下载一个。
junpeng324 发表于 2018-6-17 20:39
感谢楼主,好想做个示波器,给力。
aizaixiyuanqian 发表于 2018-6-17 20:52
12864液晶可以显示波形吗?好像试一下
感谢楼主,好想做个示波器,给力。
可以参考下我的帖子,代码没有问题,算法还行吧,你可以做个试试,原理图也有的,就看你的动手能力了。
可以的,波形可以显示正弦 方波三角波等,频率区间也可以设置,还行吧,能凑合用。
dukecheng 发表于 2018-6-18 14:30
不知道好不好改在STC15w4k32的的学习板上,上面正好有个12864的OLED显示器?
不知道好不好改在STC15w4k32的的学习板上,上面正好有个12864的OLED显示器? ...
你参考下程序,应该不是很难,单片机部分好改就是OLED部分不太好改,成功了分享下经验。
henangongda123 发表于 2018-6-18 17:34
不错 不错!
877049204 发表于 2018-6-18 18:20
放代码的时候可以试试这个,比较好看些
877049204 发表于 2018-6-18 19:51
在这里,这样放出来大家看起来好看些,像CSDN里面的代码一样,方便共享
xyz549040622 发表于 2018-6-19 07:33
放个图片,看看你的效果如何?
6688hyc 发表于 2018-6-19 08:15
楼主给力
古的 发表于 2018-6-19 09:32
回复只为收藏
学习了,下次注意,不不不,等下就改回来。{:smile:}
页: [1] 2 3
查看完整版本: 基于单片机12864单片机简易示波器
