dsp的cmd问题(仿真器和写flash运行结果不同)
求助:我在我的dsp中做一个滤波,使用仿真器时,滤波后的波形正确的(使用28335_RAM_Lnk.cmd),但是在写进片子中运行时波形就成直线啦(使用28335.cmd)
使用同一个cmd(28335.cmd)在把程序中滤波注释掉后,也就是不进行滤波写进片子运行,波形正常
哪位大侠帮我找找原因!!
谢谢!!!
28335.cmd:
MEMORY
PAGE 0: /* Program Memory */
/* Memory (RAM/FLASH/OTP) blocks can be moved to PAGE1 for data allocation */
ZONE0 : origin = 0x004000, length = 0x001000 /* XINTF zone 0 */
RAML0 : origin = 0x008000, length = 0x001500 /* on-chip RAM block L0 */
RAML1 : origin = 0x009500, length = 0x001000 /* on-chip RAM block L1 */
RAML2 : origin = 0x00A500, length = 0x001000 /* on-chip RAM block L2 */
RAML3 : origin = 0x00B500, length = 0x000500 /* on-chip RAM block L3 */
/*ZONE6 : origin = 0x0100000, length = 0x100000*/ /* XINTF zone 6 */
/*ZONE7A : origin = 0x0200000, length = 0x00FC00*/ /* XINTF zone 7 - program space */
ZONE7A : origin = 0x0200000, length = 0x080000 /* XINTF zone 7 - program space */
FLASHH : origin = 0x300000, length = 0x008000 /* on-chip FLASH */
FLASHG : origin = 0x308000, length = 0x008000 /* on-chip FLASH */
FLASHF : origin = 0x310000, length = 0x008000 /* on-chip FLASH */
FLASHE : origin = 0x318000, length = 0x008000 /* on-chip FLASH */
FLASHD : origin = 0x320000, length = 0x008000 /* on-chip FLASH */
FLASHC : origin = 0x328000, length = 0x008000 /* on-chip FLASH */
FLASHA : origin = 0x338000, length = 0x007F80 /* on-chip FLASH */
CSM_RSVD : origin = 0x33FF80, length = 0x000076 /* Part of FLASHA.Program with all 0x0000 when CSM is in use. */
BEGIN : origin = 0x33FFF6, length = 0x000002 /* Part of FLASHA.Used for "boot to Flash" bootloader mode. */
CSM_PWL : origin = 0x33FFF8, length = 0x000008 /* Part of FLASHA.CSM password locations in FLASHA */
OTP : origin = 0x380400, length = 0x000400 /* on-chip OTP */
ADC_CAL : origin = 0x380080, length = 0x000009 /* ADC_cal function in Reserved memory */
IQTABLES : origin = 0x3FE000, length = 0x000b50 /* IQ Math Tables in Boot ROM */
IQTABLES2 : origin = 0x3FEB50, length = 0x00008c /* IQ Math Tables in Boot ROM */
FPUTABLES : origin = 0x3FEBDC, length = 0x0006A0 /* FPU Tables in Boot ROM */
ROM : origin = 0x3FF27C, length = 0x000D44 /* Boot ROM */
RESET : origin = 0x3FFFC0, length = 0x000002 /* part of boot ROM*/
VECTORS : origin = 0x3FFFC2, length = 0x00003E /* part of boot ROM*/
PAGE 1 :
BOOT_RSVD : origin = 0x000000, length = 0x000050 /* Part of M0, BOOT rom will use this for stack */
RAMM0 : origin = 0x000050, length = 0x0003B0 /* on-chip RAM block M0 */
RAMM1 : origin = 0x000400, length = 0x000400 /* on-chip RAM block M1 */
RAML4 : origin = 0x00C000, length = 0x001000 /* on-chip RAM block L1 */
RAML5 : origin = 0x00D000, length = 0x001000 /* on-chip RAM block L1 */
RAML6 : origin = 0x00E000, length = 0x004000 /* on-chip RAM block L1 */
RAML7 : origin = 0x013000, length = 0x001000 /* on-chip RAM block L1 */
/*ZONE7B : origin = 0x20FC00, length = 0x000400*/ /* XINTF zone 7 - data space */
ZONE7B : origin = 0x280000, length = 0x080000 /* XINTF zone 7 - data space */
FLASHB : origin = 0x330000, length = 0x008000 /* on-chip FLASH */
SECTIONS
/* Allocate program areas: */
.cinit : > FLASHH PAGE = 0
.pinit : > FLASHH, PAGE = 0
.text : > FLASHH PAGE = 0
codestart : > BEGIN PAGE = 0
ramfuncs : LOAD = FLASHD,
RUN = RAML0,
LOAD_START(_RamfuncsLoadStart),
LOAD_END(_RamfuncsLoadEnd),
RUN_START(_RamfuncsRunStart),
PAGE = 0
csmpasswds : > CSM_PWL PAGE = 0
csm_rsvd : > CSM_RSVD PAGE = 0
/* Allocate uninitalized data sections: */
.stack : > RAMM1 PAGE = 1
//.ebss : > RAML4 PAGE = 1
.ebss : > ZONE7B, PAGE = 1
.esysmem : > RAMM1 PAGE = 1
/* Initalized sections go in Flash */
/* For SDFlash to program these, they must be allocated to page 0 */
.econst : > FLASHA PAGE = 0
.switch : > FLASHA PAGE = 0
/***********2011-7-1 added by charlie********fir lvbo**************/增加的滤波
firdb : > RAML6 PAGE = 1
firfilt : > RAML4 PAGE = 1
//coefffilt : > RAML7 PAGE = 1
sigIn : > RAML7 PAGE = 1
sigOut : > RAML5 PAGE = 1
/* Allocate IQ math areas: */
IQmath : > FLASHC PAGE = 0 /* Math Code */
IQmathTables : > IQTABLES,PAGE = 0, TYPE = NOLOAD
IQmathTables2 : > IQTABLES2, PAGE = 0, TYPE = NOLOAD
FPUmathTables : > FPUTABLES, PAGE = 0, TYPE = NOLOAD
/* Allocate DMA-accessible RAM sections: */
DMARAML4 : > RAML4, PAGE = 1
DMARAML5 : > RAML5, PAGE = 1
DMARAML6 : > RAML6, PAGE = 1
DMARAML7 : > RAML7, PAGE = 1
/* Allocate 0x400 of XINTF Zone 7 to storing data */
ZONE7DATA : > ZONE7B, PAGE = 1
FFTBUF :> RAML6,PAGE = 1
.reset : > RESET, PAGE = 0, TYPE = DSECT
vectors : > VECTORS PAGE = 0, TYPE = DSECT
/* Allocate ADC_cal function (pre-programmed by factory into TI reserved memory) */
.adc_cal : load = ADC_CAL, PAGE = 0, TYPE = NOLOAD
} 以下是 FILE: 28335_RAM_lnk.cmd
// TITLE: Linker Command File For 28335 examples that run out of RAM
// This ONLY includes all SARAM blocks on the 28335 device.
// This does not include flash or OTP.
// Keep in mind that L0 and L1 are protected by the code
// security module.
// What this means is in most cases you will want to move to
// another memory map file which has more memory defined.
// $TI Release: DSP2833x Header Files V1.10 $
// $Release Date: February 15, 2008 $
// For Code Composer Studio V2.2 and later
// In addition to this memory linker command file,
// add the header linker command file directly to the project.
// The header linker command file is required to link the
// peripheral structures to the proper locations within
// the memory map.
// The header linker files are found in <base>\DSP2833x_Headers\cmd
// For BIOS applications add: DSP2833x_Headers_BIOS.cmd
// For nonBIOS applications add: DSP2833x_Headers_nonBIOS.cmd
// For Code Composer Studio prior to V2.2
// 1) Use one of the following -l statements to include the
// header linker command file in the project. The header linker
// file is required to link the peripheral structures to the proper
// locations within the memory map */
/* Uncomment this line to include file only for non-BIOS applications */
/* -l DSP2833x_Headers_nonBIOS.cmd */
/* Uncomment this line to include file only for BIOS applications */
/* -l DSP2833x_Headers_BIOS.cmd */
/* 2) In your project add the path to <base>\DSP2833x_headers\cmd to the
library search path under project->build options, linker tab,
library search path (-i).
/* Define the memory block start/length for the F28335
PAGE 0 will be used to organize program sections
PAGE 1 will be used to organize data sections
Notes:
Memory blocks on F28335 are uniform (ie same
physical memory) in both PAGE 0 and PAGE 1.
That is the same memory region should not be
defined for both PAGE 0 and PAGE 1.
Doing so will result in corruption of program
and/or data.
L0/L1/L2 and L3 memory blocks are mirrored - that is
they can be accessed in high memory or low memory.
For simplicity only one instance is used in this
linker file.
Contiguous SARAM memory blocks can be combined
if required to create a larger memory block.
MEMORY
PAGE 0 :
/* BEGIN is used for the "boot to SARAM" bootloader mode */
/* BOOT_RSVD is used by the boot ROM for stack. */
/* This section is only reserved to keep the BOOT ROM from */
/* corrupting this area during the debug process */
BEGIN : origin = 0x000000, length = 0x000002 /* Boot to M0 will go here */
BOOT_RSVD: origin = 0x000002, length = 0x00004E /* Part of M0, BOOT rom will use this for stack */
RAML0 : origin = 0x008000, length = 0x001000
RAML1 : origin = 0x009000, length = 0x001500
/*ZONE7A : origin = 0x200000, length = 0x00FC00*/ /* XINTF zone 7 - program space */
ZONE7A : origin = 0x200000, length = 0x080000 /* XINTF zone 7 - program space */
IQTABLES2: origin = 0x3FEB50, length = 0x00008c
FPUTABLES: origin = 0x3FEBDC, length = 0x0006A0
BOOTROM : origin = 0x3FF27C, length = 0x000D44
PAGE 1 :
RAML6 : origin = 0x00E000, length = 0x001000
RAML7 : origin = 0x00F000, length = 0x001000
ZONE7B : origin = 0x280000, length = 0x80000 /* XINTF zone 7 - data space */
SECTIONS
/* Setup for "boot to SARAM" mode:
The codestart section (found in DSP28_CodeStartBranch.asm)
re-directs execution to the start of user code.*/
codestart : > BEGIN, PAGE = 0
Xintffuncs : LOAD = RAML1,
RUN = ZONE7A,
LOAD_START(_XintffuncsLoadStart),
LOAD_END(_XintffuncsLoadEnd),
RUN_START(_XintffuncsRunStart),
PAGE = 0
ramfuncs : > RAML0, PAGE = 0
.text : > RAML1, PAGE = 0
.cinit : > RAML0, PAGE = 0
.pinit : > RAML0, PAGE = 0
.switch : > RAML0, PAGE = 0
.stack : > RAMM1, PAGE = 1
/*.ebss : > RAML4, PAGE = 1*/
.econst : > RAML5, PAGE = 1
.esysmem : > RAMM1, PAGE = 1
firfilt : > RAML4, PAGE = 1
firdb : > RAML6, PAGE = 1
//coefffilt : > RAML7, PAGE = 1
sigIn : > RAML7, PAGE = 1
sigOut : > RAML5, PAGE = 1
IQmath : > RAML1, PAGE = 0
.reset : > RESET, PAGE = 0, TYPE = DSECT /* not used */
csm_rsvd : > CSM_RSVD PAGE = 0, TYPE = DSECT /* not used for SARAM examples */
csmpasswds : > CSM_PWL PAGE = 0, TYPE = DSECT /* not used for SARAM examples */
FFTBUF ALIGN( 512 ) : { } > RAML6PAGE 1
希望大家帮忙看看!!
谢谢!! :(没人遇到这样的问题吗? 兄弟我遇到了类似的问题 但是我也没有解决不知道怎么回事 程序在RAM里和FLASH里运行速度不一样。
页:
[1]
