使用Mfgtool烧写MYS-6ULX开发板报错
根据《MYS-6ULX-LinuxDevelopmentGuide_zh.pdf》使用手册,装好了yocto工具链,编译了uboot、内核及基于fsl-image-qt5的文件系统。能够正常实现交叉编译。现在要使用编译好的文件更新Mfgtool,我在/MYS6ULx-devel/fsl-release-yocto/build/tmp/deploy/images/mys6ul14x14目录下找的相关文件(uboot、内核、设备树、文件系统),并改名。
将这四个文件覆盖掉files下的文件后,运行
报错:
MfgTool.log:
DLL version: 2.7.0
Tuesday, September 04, 2018 10:06:22 Start new logging
ModuleID LevelID: CMyExceptionHandler thread is running
ModuleID LevelID: new MxHidDeviceClass
ModuleID LevelID: Device Manager thread is running
ModuleID LevelID: Can't set m_hStopEvent before it initialized or it already stop
ModuleID LevelID: CmdOperation device chagned and reset to state 0
ModuleID LevelID: ExecuteCommand--Boot, File is F:\MYS-6ULX-mfgtools-20180605\Profiles\linux\OS Firmware\firmware\u-boot-imx6ul14x14evk-ddr256_nand.imx
ModuleID LevelID: CmdOperation, skip current command, so SetEvent(hDevCanDeleteEvent)
ModuleID LevelID: ExecuteCommand--Load, File is F:\MYS-6ULX-mfgtools-20180605\Profiles\linux\OS Firmware\firmware\zImage, address is 0x80800000
ModuleID LevelID: PortMgrDlg(0)--Command Load excute successfully, retry count: 0
ModuleID LevelID: ExecuteCommand--Load, File is F:\MYS-6ULX-mfgtools-20180605\Profiles\linux\OS Firmware\firmware\fsl-image-mfgtool-initramfs-imx_mfgtools.cpio.gz.u-boot, address is 0x83800000
ModuleID LevelID: ExecuteCommand--Load, File is F:\MYS-6ULX-mfgtools-20180605\Profiles\linux\OS Firmware\firmware\zImage-imx6ul-14x14-evk-gpmi-weim.dtb, address is 0x83000000
ModuleID LevelID: ExecuteCommand--Jump
ModuleID LevelID: *********MxHidDevice Jump to Ramkernel successfully!**********
ModuleID LevelID: CmdOperation, current state command has been finished and the last command is successful, so SetEvent(hDevCanDeleteEvent)
ModuleID LevelID: DeviceManager::DevChangeWnd::OnDeviceChange() - DEVICE_REMOVAL_EVT(\\?\USB#VID_15A2&PID_007D#5&3b0d2cff&0&6#{a5dcbf10-6530-11d2-901f-00c04fb951ed})
ModuleID LevelID: DeviceManager::DevChangeWnd::OnDeviceChange() - end
ModuleID LevelID: DeviceManager::OnMsgDeviceEvent() - DEVICE_REMOVAL_EVT(\\?\USB#VID_15A2&PID_007D#5&3b0d2cff&0&6#{a5dcbf10-6530-11d2-901f-00c04fb951ed})
ModuleID LevelID: DeviceClass::FindDeviceByUsbPath--DeviceListType_Current, _devices.size: 1
ModuleID LevelID: DeviceClass::FindDeviceByUsbPath--DeviceListType_Current, devInstPathToFind: USB\VID_15A2&PID_007D\5&3B0D2CFF&0&6, _deviceInstanceID: USB\VID_15A2&PID_007D\5&3B0D2CFF&0&6
ModuleID LevelID: DeviceClass::FindDeviceByUsbPath--DeviceListType_Current, Find the device
ModuleID LevelID: DeviceManager::OnMsgDeviceEvent() - DEVICE_REMOVAL_EVT, vid_15a2&pid_007d, Hub:1-Port:6
ModuleID LevelID: DeviceManager::OnMsgDeviceEvent() - DEVICE_REMOVAL_EVT, Notify
ModuleID LevelID: CmdOpreation--OnDeviceChangeNotify, Volume Arrive/Remove or Device Arrive/Remove
ModuleID LevelID: CmdOpreation--OnDeviceChangeNotify, m_p_usb_port is not NULL, so only refresh
ModuleID LevelID: CmdOpreation--OnDeviceChangeNotify, Volume/Device Remove
ModuleID LevelID: CmdOpreation--set m_hDeviceRemoveEvent.
ModuleID LevelID: CmdOpreation--WaitforEvents device remove1
ModuleID LevelID: DeviceManager::OnMsgDeviceEvent()-DEVICE_REMOVAL_EVT, hDevCanDeleteEvent has been set
ModuleID LevelID: delete MxHidDevice
ModuleID LevelID: DeviceManager::DevChangeWnd::OnDeviceChange() - DEVICE_ARRIVAL_EVT(\\?\USB#VID_066F&PID_37FF#5&3b0d2cff&0&6#{a5dcbf10-6530-11d2-901f-00c04fb951ed})
ModuleID LevelID: DeviceManager::OnMsgDeviceEvent() - DEVICE_ARRIVAL_EVT(\\?\USB#VID_066F&PID_37FF#5&3b0d2cff&0&6#{a5dcbf10-6530-11d2-901f-00c04fb951ed})
ModuleID LevelID: DeviceManager::OnMsgDeviceEvent() - DEVICE_ARRIVAL_EVT, vid_066f&pid_37ff, not handled
ModuleID LevelID: DeviceManager::DevChangeWnd::OnDeviceChange() - VOLUME_ARRIVAL_EVT(G)
ModuleID LevelID: DeviceManager::OnMsgDeviceEvent() - VOLUME_ARRIVAL_EVT(G)
ModuleID LevelID: VolumeDeviceClass::AddUsbDevice()G
ModuleID LevelID: DeviceTypeDisk--_devices size: 1
ModuleID LevelID: Volume--StorageDisk, Disk->_driveNumber:1, Volume->_diskNumber:1
ModuleID LevelID: DeviceTypeDisk--find Disk device: 0449DBF0
ModuleID LevelID: Device::hubIndex::getmsc, return the port index is: 6
ModuleID LevelID: VolumeDeviceClass::AddUsbDevice() successful G add to current list, retrycount: 0
ModuleID LevelID: DeviceManager::OnMsgDeviceEvent() - VOLUME_ARRIVAL_EVT-Disk(G), Hub:1-Port:6
ModuleID LevelID: DeviceManager::OnMsgDeviceEvent() - VOLUME_ARRIVAL_EVT, Notify
ModuleID LevelID: CmdOpreation--OnDeviceChangeNotify, Volume/Device Arrive
ModuleID LevelID: CmdOpreation--set m_hDeviceArriveEvent.
ModuleID LevelID: CmdOpreation--WaitforEvents device arrive1
ModuleID LevelID: CmdOperation device chagned and reset to state 1
ModuleID LevelID: ExecuteCommand--Push, Body is $ mount -t debugfs debugfs /sys/kernel/debug
ModuleID LevelID: ExecuteCommand--Push, Body is $ flash_erase /dev/mtd0 0 0
ModuleID LevelID: ExecuteCommand--Push, Body is send
ModuleID LevelID: ExecuteCommand--Push, Body is $ kobs-ng init -x -v --chip_0_device_path=/dev/mtd0 $FILE
ModuleID LevelID: ExecuteCommand--Push, Body is $ flash_erase /dev/mtd1 0 0
ModuleID LevelID: ExecuteCommand--Push, Body is $ nandwrite -p /dev/mtd1 -p $FILE
ModuleID LevelID: ExecuteCommand--Push, Body is $ flash_erase /dev/mtd2 0 0
ModuleID LevelID: ExecuteCommand--Push, Body is $ nandwrite -p /dev/mtd2 -p $FILE
ModuleID LevelID: ExecuteCommand--Push, Body is $ flash_erase /dev/mtd3 0 0
ModuleID LevelID: ExecuteCommand--Push, Body is $ ubiformat /dev/mtd3
ModuleID LevelID: ExecuteCommand--Push, Body is $ ubiattach /dev/ubi_ctrl -m 3
ModuleID LevelID: ExecuteCommand--Push, Body is $ ubimkvol /dev/ubi0 -Nrootfs -m
ModuleID LevelID: ExecuteCommand--Push, Body is $ mkdir -p /mnt/mtd3
ModuleID LevelID: ExecuteCommand--Push, Body is $ mount -t ubifs ubi0:rootfs /mnt/mtd3
ModuleID LevelID: ExecuteCommand--Push, Body is pipe tar -jxv -C /mnt/mtd3
ModuleID LevelID: PortMgrDlg(0)--MSCDevice--Command Push(file) excute failed
ModuleID LevelID: CmdOperation, current command executed failed, so SetEvent(hDevCanDeleteEvent)
新手飘过~~求大牛解答
页:
[1]
