linux/windows兼容串口代码 serial.py
本帖最后由 sinanjj 于 2011-8-18 14:41 编辑今天整理资料. 一些存了的代码发上来吧.
估计以后不会再用了.#! /usr/bin/python
# apt-get install python-serial
import sys
import serial
import time
for i in range(256): #scan for available ports
try:
#ser = serial.Serial(i, 115200, timeout=1)
ser = serial.Serial(i, 115200)
break
except:
if i == 255:
print 'there is no serial port exist'
sys.exit(0)
pass
print ser.portstr
ser.setRTS(0)
ser.setDTR(0)
file_ir = open('ir_data.txt', 'w')
cmd_len = 0 # one cmd length 1s == 20000/8 == 2500
while 1:
buf_ser = ser.read(20)
if buf_ser == "\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00":
if (cmd_len >0) and (cmd_len < 2500):
pass
elif cmd_len == 2500:
cmd_len = 0
continue
else:
continue
print " ".join(map(lambda c: "%02X" %ord(c), buf_ser))
file_ir.write(",".join(map(lambda c: "0x%02X" %ord(c), buf_ser)) + ",")
file_ir.flush()
cmd_len = cmd_len + 20
看得懂的朋友自己拿走. 看不懂的朋友自己查. 实在看不懂我也没办法. 不解释. accessing serial ports
check the system's serial port
$ dmesg | grep tty
Serial Port Files
| Port 1 | Port 2 | usb2serial |
| /dev/ttyS0 | /dev/ttyS1 | /dev/ttyUSB0 |
To access a serial port you simply open the corresponding device file.
# chmod a+rw /dev/ttyS0
codes for a serial port
#! /usr/bin/python
# -*- coding: utf-8 -*-
import sys
import serial
try:
break
except:
if i == 255:
sys.exit(0)
pass
print ser.portstr
ser.setRTS(0)
ser.setDTR(0)
file_ser = open('ser_data.txt', 'w')
while 1:
ser.write("\x00\x01\x02\x03\x04\x05")
buf_ser = ser.read(11)
file_ser.write(",".join(map(lambda c: "0x%02X" %ord(c), buf_ser)) + ",")
file_ser.flush() 学习 学习
页:
[1]
