紫气东升 发表于 2018-12-27 17:08
STM8S105K4跟ES8323S的I2C通信,接收多字节有错误
最近在做STM8S105K4跟ES8323S的I2C通信遇到了一个问题。当我发送的数据在6个以内时,接收的数据全都正确,但是当6<发送的数据<24的时候,接收的数据总是第七个错误,而当发送的数据>24个的时候,接收的数据除了第七个错误的,连第一个也错误了。实在是不知道哪里出了问题,求各位帮帮忙,给点指导。下面是相关的代码
//发送单个字节
void SendByte(GPIO_TypeDef* GPIOx, GPIO_Pin_TypeDef GPIO_Pin_SDA,GPIO_Pin_TypeDef GPIO_Pin_SCL,uchar c)
uchar BitCnt;
for(BitCnt=0;BitCnt<8;BitCnt++)/*要传送的数据长度为8位*/
      GPIOx->ODR &= (uint8_t)(~GPIO_Pin_SCL);         //scl 0
      Delay(delay_count2);
      if( c&0x80 )
         GPIOx->ODR |= (uint8_t)GPIO_Pin_SDA;          //sda 1
      else
      GPIOx->ODR &= (uint8_t)(~GPIO_Pin_SDA);      //sda0
      c=c<<1;
   GPIOx->ODR |= (uint8_t)GPIO_Pin_SCL;            //scl 1
   /*置时钟线为高,通知被控器开始接收数据位*/
   __no_operation();   /*保证时钟高电平周期大于4μs*/
   Delay(delay_count);
      //从机应答,可以用应答和非应答信号代替
   __no_operation();                               //maybe cancel this line
   GPIOx->ODR &= (uint8_t)(~GPIO_Pin_SCL);         //first scl 0
   Delay(delay_count);
   // Set Input mode
   GPIOx->CR1 &= (uint8_t)(~(GPIO_Pin_SDA));   /* no pull_up Register 1 */
   GPIOx->DDR &= (uint8_t)(~(GPIO_Pin_SDA));
   Delay(delay_count);
   GPIOx->ODR |= (uint8_t)GPIO_Pin_SCL;            //scl 1;the receive side will send out the acknowledge signal
   __no_operation();
   Delay(delay_count);
   if((GPIOx->IDR & (uint8_t)GPIO_Pin_SDA))      //normal low
      ack=FALSE; /*判断是否接收到应答信号*/
      else
      ack=TRUE;
      GPIOx->DDR |= (uint8_t)GPIO_Pin_SDA;            // must be set output mode
      Delay(delay_count);
//发送多个字节
bool ISendStr(GPIO_TypeDef* GPIOx, GPIO_Pin_TypeDef GPIO_Pin_SDA,GPIO_Pin_TypeDef GPIO_Pin_SCL,uchar *s,uchar no)
uchar i;
Start_I2c(GPIOx,GPIO_Pin_SDA,GPIO_Pin_SCL);               /*启动总线*/
for(i=0;i<no;i++)
    SendByte(GPIOx,GPIO_Pin_SDA,GPIO_Pin_SCL,*s);               /*发送数据*/
    s++;
Stop_I2c(GPIOx,GPIO_Pin_SDA,GPIO_Pin_SCL);   /*结束总线*/
return(TRUE);
//I2C发送数据
void Write_BQREC(void)
      Array_Write_I2C_TI = 0x02;
      Array_Write_I2C_TI = BQreq;
      while (!Rx)
                IWDG->KR = 0xAA;
                Rx = ISendStr(GPIOC, POW_SDA, POW_SCL, Array_Write_I2C_TI, 3);
      Rx = 0;
      Array_Write_I2C_TI = 0x2d;
      while (!Rx)
                IWDG->KR = 0xAA;
      Rx = 0;
      Array_Write_I2C_TI = 0x00;
      while (!Rx)
                IWDG->KR = 0xAA;
      Rx = 0;
      Array_Write_I2C_TI = 0x07;
      while (!Rx)
                IWDG->KR = 0xAA;
      Rx = 0;
      Array_Write_I2C_TI = 0x2b;
      while (!Rx)
                IWDG->KR = 0xAA;
      Rx = 0;
      Array_Write_I2C_TI = 0x08;
      while (!Rx)
                IWDG->KR = 0xAA;
      Rx = 0;
      Delayms(5);
      Array_Write_I2C_TI = 0x01;
      while (!Rx)
                IWDG->KR = 0xAA;
      Rx = 0;
      Delayms(5);
      Array_Write_I2C_TI = 0x03;
      while (!Rx)
                IWDG->KR = 0xAA;
      Rx = 0;
      Delayms(5);
      Array_Write_I2C_TI = 0x04;
      while (!Rx)
                IWDG->KR = 0xAA;
      Rx = 0;
      Delayms(5);
      Array_Write_I2C_TI = 0x05;
      while (!Rx)
                IWDG->KR = 0xAA;
      Rx = 0;
      Delayms(5);
      Array_Write_I2C_TI = 0x06;
      while (!Rx)
                IWDG->KR = 0xAA;
      Rx = 0;
      Delayms(5);
      Array_Write_I2C_TI = 0x19;
      while (!Rx)
                IWDG->KR = 0xAA;
      Rx = 0;
      Delayms(5);
      Array_Write_I2C_TI = 0x0a;
      while (!Rx)
                IWDG->KR = 0xAA;
      Rx = 0;
      Delayms(5);
      Array_Write_I2C_TI = 0x0b;
      while (!Rx)
                IWDG->KR = 0xAA;
      Rx = 0;
      Delayms(5);
      Array_Write_I2C_TI = 0x0c;
      while (!Rx)
                IWDG->KR = 0xAA;
      Rx = 0;
      Delayms(5);
      Array_Write_I2C_TI = 0x0d;
      while (!Rx)
                IWDG->KR = 0xAA;
      Rx = 0;
      Delayms(5);
      Array_Write_I2C_TI = 0x10;
      while (!Rx)
                IWDG->KR = 0xAA;
      Rx = 0;
      Delayms(5);
      Array_Write_I2C_TI = 0x17;
      while (!Rx)
                IWDG->KR = 0xAA;
      Rx = 0;
      Delayms(5);
      Array_Write_I2C_TI = 0x18;
      while (!Rx)
                IWDG->KR = 0xAA;
      Rx = 0;
      Delayms(5);
      Array_Write_I2C_TI = 0x1A;
      while (!Rx)
                IWDG->KR = 0xAA;
      Rx = 0;
      Delayms(5);
      Array_Write_I2C_TI = 0x1B;
      while (!Rx)
                IWDG->KR = 0xAA;
      Rx = 0;
      Delayms(5);
      Array_Write_I2C_TI = 0x27;
      while (!Rx)
                IWDG->KR = 0xAA;
      Rx = 0;
      Delayms(5);
      Array_Write_I2C_TI = 0x2A;
      while (!Rx)
                IWDG->KR = 0xAA;
      Rx = 0;
      Delayms(5);
      while (!Rx)
                IWDG->KR = 0xAA;
      Rx = 0;
      Delayms(5);
      while (!Rx)
                IWDG->KR = 0xAA;
      Rx = 0;
      Delayms(5);
      Array_Write_I2C_TI = 0x30;
      while (!Rx)
                IWDG->KR = 0xAA;
      Rx = 0;
      Delayms(5);
      Array_Write_I2C_TI = 0x31;
      while (!Rx)
                IWDG->KR = 0xAA;
      Rx = 0;
      Delayms(5);
      while (!Rx)
                IWDG->KR = 0xAA;
      Rx = 0;
      Delayms(5);
      while (!Rx)
                IWDG->KR = 0xAA;
      Rx = 0;
      Delayms(5);
      while (!Rx)
                IWDG->KR = 0xAA;
      Rx = 0;
      Delayms(5);
      while (!Rx)
                IWDG->KR = 0xAA;
      Rx = 0;
      Delayms(5);
//接收单字节
uchar RcvByte(GPIO_TypeDef* GPIOx, GPIO_Pin_TypeDef GPIO_Pin_SDA,GPIO_Pin_TypeDef GPIO_Pin_SCL)
uchar retc;
uchar BitCnt;
GPIOx->DDR &= (uint8_t)(~(GPIO_Pin_SDA));      // it 's need to set input mode ,very important
   Delay(delay_count);
   retc=0;
   __no_operation();
   retc<<=1;
   if((GPIOx->IDR & (uint8_t)GPIO_Pin_SDA)) retc+=1; /*读数据位,接收的数据位放入retc中 */
   GPIOx->ODR &= (uint8_t)(~GPIO_Pin_SCL);         //scl 0the last status of the scl must be"0"
return(retc);
//接收多字节
bool IRcvStr(GPIO_TypeDef* GPIOx, GPIO_Pin_TypeDef GPIO_Pin_SDA,GPIO_Pin_TypeDef GPIO_Pin_SCL,uchar sla,uchar suba,uchar *s,uchar no)
SendByte(GPIOx,GPIO_Pin_SDA,GPIO_Pin_SCL,sla);            /*发送器件地址*/
if(ack==FALSE)return(FALSE);
SendByte(GPIOx,GPIO_Pin_SDA,GPIO_Pin_SCL,suba);            /*发送器件子地址*/
Start_I2c(GPIOx,GPIO_Pin_SDA,GPIO_Pin_SCL);                //start again
SendByte(GPIOx,GPIO_Pin_SDA,GPIO_Pin_SCL,sla+1);         //read mode
while(no!=1)
   *s=RcvByte(GPIOx,GPIO_Pin_SDA,GPIO_Pin_SCL);             /*receive数据*/
   Ack_I2c(GPIOx,GPIO_Pin_SDA,GPIO_Pin_SCL);                /*发送就答位*/
    s++;
   no--;
*s=RcvByte(GPIOx,GPIO_Pin_SDA,GPIO_Pin_SCL);            //read last byte
NoAck_I2c(GPIOx,GPIO_Pin_SDA,GPIO_Pin_SCL);            /*发送非应位*/
return(TRUE);
//读取BQ寄存器数据
void Read_BQREC(void)
      while (!Rx)
                IWDG->KR = 0xAA;
                Rx = IRcvStr(BQ24168_IIC_PORT, POW_SDA, POW_SCL, 0x20, 0x02, BQREC, 3);
      Rx = 0;
      while (!Rx)
                IWDG->KR = 0xAA;
                Rx = IRcvStr(BQ24168_IIC_PORT, POW_SDA, POW_SCL, 0x20, 0x2d, BQREC, 3);
      Rx = 0;
      while (!Rx)
                IWDG->KR = 0xAA;
                Rx = IRcvStr(BQ24168_IIC_PORT, POW_SDA, POW_SCL, 0x20, 0x00, BQREC, 3);
      Rx = 0;
      while (!Rx)
                IWDG->KR = 0xAA;
                Rx = IRcvStr(BQ24168_IIC_PORT, POW_SDA, POW_SCL, 0x20, 0x07, BQREC, 3);
      Rx = 0;
      while (!Rx)
                IWDG->KR = 0xAA;
                Rx = IRcvStr(BQ24168_IIC_PORT, POW_SDA, POW_SCL, 0x20, 0x2b, BQREC, 3);
      Rx = 0;
      while (!Rx)
                IWDG->KR = 0xAA;
                Rx = IRcvStr(BQ24168_IIC_PORT, POW_SDA, POW_SCL, 0x20, 0x08, BQREC, 3);
      Rx = 0;
      while (!Rx)
                IWDG->KR = 0xAA;
                Rx = IRcvStr(BQ24168_IIC_PORT, POW_SDA, POW_SCL, 0x20, 0x01, BQREC, 3);
      Rx = 0;
      while (!Rx)
                IWDG->KR = 0xAA;
                Rx = IRcvStr(BQ24168_IIC_PORT, POW_SDA, POW_SCL, 0x20, 0x03, BQREC, 1);
      Rx = 0;
      while (!Rx)
                IWDG->KR = 0xAA;
                Rx = IRcvStr(BQ24168_IIC_PORT, POW_SDA, POW_SCL, 0x20, 0x04, BQREC, 1);
      Rx = 0;
      while (!Rx)
                IWDG->KR = 0xAA;
                Rx = IRcvStr(BQ24168_IIC_PORT, POW_SDA, POW_SCL, 0x20, 0x05, BQREC, 1);
      Rx = 0;
      while (!Rx)
                IWDG->KR = 0xAA;
                Rx = IRcvStr(BQ24168_IIC_PORT, POW_SDA, POW_SCL, 0x20, 0x06, BQREC, 1);
      Rx = 0;
      while (!Rx)
                IWDG->KR = 0xAA;
                Rx = IRcvStr(BQ24168_IIC_PORT, POW_SDA, POW_SCL, 0x20, 0x19, BQREC, 1);
      Rx = 0;
      while (!Rx)
                IWDG->KR = 0xAA;
                Rx = IRcvStr(BQ24168_IIC_PORT, POW_SDA, POW_SCL, 0x20, 0x0a, BQREC, 1);
      Rx = 0;
      while (!Rx)
                IWDG->KR = 0xAA;
                Rx = IRcvStr(BQ24168_IIC_PORT, POW_SDA, POW_SCL, 0x20, 0x0b, BQREC, 1);
      Rx = 0;
      while (!Rx)
                IWDG->KR = 0xAA;
                Rx = IRcvStr(BQ24168_IIC_PORT, POW_SDA, POW_SCL, 0x20, 0x0c, BQREC, 1);
      Rx = 0;
      while (!Rx)
                IWDG->KR = 0xAA;
                Rx = IRcvStr(BQ24168_IIC_PORT, POW_SDA, POW_SCL, 0x20, 0x0d, BQREC, 1);
      Rx = 0;
      while (!Rx)
                IWDG->KR = 0xAA;
                Rx = IRcvStr(BQ24168_IIC_PORT, POW_SDA, POW_SCL, 0x20, 0x10, BQREC, 1);
      Rx = 0;
      while (!Rx)
                IWDG->KR = 0xAA;
                Rx = IRcvStr(BQ24168_IIC_PORT, POW_SDA, POW_SCL, 0x20, 0x17, BQREC, 1);
      Rx = 0;
      while (!Rx)
                IWDG->KR = 0xAA;
                Rx = IRcvStr(BQ24168_IIC_PORT, POW_SDA, POW_SCL, 0x20, 0x18, BQREC, 1);
      Rx = 0;
      while (!Rx)
                IWDG->KR = 0xAA;
                Rx = IRcvStr(BQ24168_IIC_PORT, POW_SDA, POW_SCL, 0x20, 0x1A, BQREC, 1);
      Rx = 0;
      while (!Rx)
                IWDG->KR = 0xAA;
                Rx = IRcvStr(BQ24168_IIC_PORT, POW_SDA, POW_SCL, 0x20, 0x1B, BQREC, 1);
      Rx = 0;
      while (!Rx)
                IWDG->KR = 0xAA;
                Rx = IRcvStr(BQ24168_IIC_PORT, POW_SDA, POW_SCL, 0x20, 0x27, BQREC, 1);
      Rx = 0;
      while (!Rx)
                IWDG->KR = 0xAA;
                Rx = IRcvStr(BQ24168_IIC_PORT, POW_SDA, POW_SCL, 0x20, 0x2A, BQREC, 1);
      Rx = 0;
      while (!Rx)
                IWDG->KR = 0xAA;
                Rx = IRcvStr(BQ24168_IIC_PORT, POW_SDA, POW_SCL, 0x20, 0x02, BQREC, 1);
      Rx = 0;
      while (!Rx)
                IWDG->KR = 0xAA;
      Rx = 0;
      while (!Rx)
                IWDG->KR = 0xAA;
                Rx = IRcvStr(BQ24168_IIC_PORT, POW_SDA, POW_SCL, 0x20, 0x30, BQREC, 1);
      Rx = 0;
      while (!Rx)
                IWDG->KR = 0xAA;
                Rx = IRcvStr(BQ24168_IIC_PORT, POW_SDA, POW_SCL, 0x20, 0x31, BQREC, 1);
      Rx = 0;
      while (!Rx)
                IWDG->KR = 0xAA;
      Rx = 0;
      while (!Rx)
                IWDG->KR = 0xAA;
      Rx = 0;
      while (!Rx)
                IWDG->KR = 0xAA;
      Rx = 0;
      while (!Rx)
                IWDG->KR = 0xAA;
      Rx = 0;
紫气东升 发表于 2018-12-29 09:07
昨天我稍稍改变了读写,就是写一个读一个,然后再写一个再读一个.......。发现当我写读的数据超过24个后,都只有第七个数据出错,其他读写都正确。而且我发现第七个数据的高位最大数值只能是3,超过3它会返回去从0开始。比如,如果第七个数据我写0x02(或者0x12/0x22/0x32),读出来的都正确。但是当我写0x42,读出来的是0x02,写0x52,读0x12,写0x62,读0x22......就这样不断的循环往复。以下是稍稍改变后的代码
u8 BQreq = {0xf3, 0x00, 0x36, 0x7c, 0x80, 0x00, 0x72, 0x00, 0x0c, 0x00, 0x00, 0x24, 0xC0, 0x82, 0x0C, 0x04, 0x00, 0x18, 0x04, 0x00, 0x00, 0xB8, 0xB8, 0x03, 0x00, 0x0C, 0x0C, 0x21, 0x21, 0x00, 0x00};
while (!Rx)
Rx = 0;
while (!Rx)
Rx = 0;
Delayms(1);
while (!Rx)
Rx = 0;
while (!Rx)
      Rx = IRcvStr(BQ24168_IIC_PORT, POW_SDA, POW_SCL, 0x20, 0x2d, BQREC, 1);
Rx = 0;
Delayms(1);
while (!Rx)
Rx = 0;
while (!Rx)
      Rx = IRcvStr(BQ24168_IIC_PORT, POW_SDA, POW_SCL, 0x20, 0x00, BQREC, 1);
Rx = 0;
Delayms(1);
while (!Rx)
Rx = 0;
while (!Rx)
      Rx = IRcvStr(BQ24168_IIC_PORT, POW_SDA, POW_SCL, 0x20, 0x07, BQREC, 1);
Rx = 0;
Delayms(1);
while (!Rx)
Rx = 0;
while (!Rx)
      Rx = IRcvStr(BQ24168_IIC_PORT, POW_SDA, POW_SCL, 0x20, 0x2b, BQREC, 1);
Rx = 0;
Delayms(1);
while (!Rx)
Rx = 0;
while (!Rx)
      Rx = IRcvStr(BQ24168_IIC_PORT, POW_SDA, POW_SCL, 0x20, 0x08, BQREC, 1);
Rx = 0;
Delayms(1);
while (!Rx)
Rx = 0;
while (!Rx)
      Rx = IRcvStr(BQ24168_IIC_PORT, POW_SDA, POW_SCL, 0x20, 0x01, BQREC, 1);
Rx = 0;
Delayms(1);
while (!Rx)
Rx = 0;
while (!Rx)
Rx = 0;
Delayms(1);
while (!Rx)
Rx = 0;
while (!Rx)
Rx = 0;
Delayms(1);
while (!Rx)
Rx = 0;
while (!Rx)
Rx = 0;
Delayms(1);
while (!Rx)
Rx = 0;
while (!Rx)
Rx = 0;
Delayms(1);
while (!Rx)
Rx = 0;
while (!Rx)
Rx = 0;
Delayms(1);
while (!Rx)
Rx = 0;
while (!Rx)
Rx = 0;
Delayms(1);
while (!Rx)
Rx = 0;
while (!Rx)
Rx = 0;
Delayms(1);
while (!Rx)
Rx = 0;
while (!Rx)
Rx = 0;
Delayms(1);
while (!Rx)
Rx = 0;
while (!Rx)
Rx = 0;
Delayms(1);
while (!Rx)
Rx = 0;
while (!Rx)
Rx = 0;
Delayms(1);
while (!Rx)
Rx = 0;
while (!Rx)
Rx = 0;
Delayms(1);
while (!Rx)
Rx = 0;
while (!Rx)
Rx = 0;
Delayms(1);
while (!Rx)
Rx = 0;
while (!Rx)
Rx = 0;
Delayms(1);
while (!Rx)
Rx = 0;
while (!Rx)
Rx = 0;
Delayms(1);
while (!Rx)
Rx = 0;
while (!Rx)
Rx = 0;
Delayms(1);
while (!Rx)
Rx = 0;
while (!Rx)
Rx = 0;
Delayms(1);
while (!Rx)
Rx = 0;
while (!Rx)
Rx = 0;
Delayms(1);
while (!Rx)
Rx = 0;
while (!Rx)
Rx = 0;
Delayms(1);
while (!Rx)
Rx = 0;
while (!Rx)
Rx = 0;
Delayms(1);
while (!Rx)
Rx = 0;
while (!Rx)
Rx = 0;
Delayms(1);
while (!Rx)
Rx = 0;
while (!Rx)
Rx = 0;
Delayms(1);
while (!Rx)
Rx = 0;
while (!Rx)
Rx = 0;
Delayms(1);
while (!Rx)
Rx = 0;
while (!Rx)
Rx = 0;
Delayms(1);
while (!Rx)
Rx = 0;
while (!Rx)
Rx = 0;
Delayms(1);
页: [1]
查看完整版本: STM8S105K4跟ES8323S的I2C通信,接收多字节有错误
