springvirus 发表于 2019-2-1 13:42
RiotBoard之把玩系列(1)
各种刷脸的实际应用日益进入日常生活,便激发了自己搞个系统玩玩的想法,手头有块RiotBoard,主控是IMX6Solo系列Cortex-A9片子,型号是MCIMX6S5DVM10AB,1GB DDR3 800MHz, 4GB eMMC,出厂时自带的android4.3 jelly bean,默认使能HDMI的输出,性能还是不错的,计划先通过各种方式,串口,telnet,ssh,ftp等等,连接板子,后续再说
先从serial port,看到系统启动时的打印信息:
U-Boot 2009.08-00694-g632a6e0-dirty (Dec 24 2013 - 17:03:32)
CPU: Freescale i.MX6 family TO1.1 at 792 MHz
Thermal sensor with ratio = 191
Temperature:   32 C, calibration data 0x5bb5345f
mx6q pll1: 792MHz
mx6q pll2: 528MHz
mx6q pll3: 480MHz
mx6q pll8: 50MHz
ipg clock   : 66000000Hz
ipg per clock : 66000000Hz
uart clock    : 80000000Hz
cspi clock    : 60000000Hz
ahb clock   : 132000000Hz
axi clock   : 198000000Hz
emi_slow clock: 99000000Hz
ddr clock   : 396000000Hz
usdhc1 clock: 198000000Hz
usdhc2 clock: 198000000Hz
usdhc3 clock: 198000000Hz
usdhc4 clock: 198000000Hz
nfc clock   : 24000000Hz
Board: i.MX6DL/Solo-SABRESD: unknown-board Board: 0x61011
Boot Device: MMC
I2C:   ready
DRAM:   1 GB
MMC:   FSL_USDHC: 0,FSL_USDHC: 1,FSL_USDHC: 2,FSL_USDHC: 3
*** Warning - bad CRC or MMC, using default environment
In:    serial
Out:   serial
Err:   serial
Net:   got MAC address from IIM: 00:00:00:00:00:00
----enet_board_init: phy reset
FEC0
Hit any key to stop autoboot:0
kernel   @ 10808000 (4738952)
ramdisk@ 11800000 (233818)
kernel cmdline:
      use uboot command line:
      console=ttymxc1,115200 init=/init nosmp video=mxcfb0:dev=hdmi,1280x720M@60,bpp=32 video=mxcfb1:off fbmem=10M vmalloc=400M androidboot.console=ttymxc1 androidboot.hardware=freescale
Starting kernel ...
Initializing cgroup subsys cpu
Linux version 3.0.35-06429-g55e239f (android@embest-tech) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #3 SMP PREEMPT Fri Dec 20 10:31:44 CST 2013
CPU: ARMv7 Processor revision 10 (ARMv7), cr=10c53c7d
CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: Freescale i.MX 6Solo RIOT Board
Ignoring unrecognised tag 0x54410008
Memory policy: ECC disabled, Data cache writealloc
CPU identified as i.MX6DL/SOLO, silicon rev 1.1
PERCPU: Embedded 7 pages/cpu @c1307000 s6592 r8192 d13888 u32768
Built 1 zonelists in Zone order, mobility grouping on.Total pages: 208128
Kernel command line: console=ttymxc1,115200 init=/init nosmp video=mxcfb0:dev=hdmi,1280x720M@60,bpp=32 video=mxcfb1:off fbmem=10M vmalloc=400M androidboot.console=ttymxc1 androidboot.hardware=freescale
PID hash table entries: 2048 (order: 1, 8192 bytes)
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Memory: 767MB 54MB = 821MB total
Memory: 820560k/820560k available, 228016k reserved, 431104K highmem
Virtual kernel memory layout:
    vector: 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap: 0xfff00000 - 0xfffe0000   ( 896 kB)
    DMA   : 0xfbe00000 - 0xffe00000   (64 MB)
    vmalloc : 0xd9800000 - 0xf2000000   ( 392 MB)
    lowmem: 0xc0000000 - 0xd9000000   ( 400 MB)
    pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
    modules : 0xbf000000 - 0xbfe00000   (14 MB)
      .init : 0xc0008000 - 0xc0046000   ( 248 kB)
      .text : 0xc0046000 - 0xc08d3f94   (8760 kB)
      .data : 0xc08d4000 - 0xc0975de0   ( 648 kB)
       .bss : 0xc0975e04 - 0xc0afdb48   (1568 kB)
Preemptible hierarchical RCU implementation.
NR_IRQS:624
MXC GPIO hardware
sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 1431655ms
Set periph_clk's parent to pll2_pfd_400M!
arm_max_freq=1GHz
MXC_Early serial console at MMIO 0x21e8000 (options '115200')
bootconsole enabled
Calibrating delay loop... 1581.05 BogoMIPS (lpj=7905280)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
Initializing cgroup subsys debug
Initializing cgroup subsys cpuacct
Initializing cgroup subsys freezer
CPU: Testing write buffer coherency: ok
hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available
Brought up 1 CPUs
SMP: Total of 1 processors activated (1581.05 BogoMIPS).
print_constraints: dummy:
NET: Registered protocol family 16
print_constraints: vddpu: 725 <--> 1300 mV at 700 mV fast normal
print_constraints: vddcore: 725 <--> 1300 mV at 1150 mV fast normal
print_constraints: vddsoc: 725 <--> 1300 mV at 1200 mV fast normal
print_constraints: vdd2p5: 2000 <--> 2775 mV at 2400 mV fast normal
print_constraints: vdd1p1: 800 <--> 1400 mV at 1100 mV fast normal
print_constraints: vdd3p0: 2625 <--> 3400 mV at 3000 mV fast normal
ram_console: got buffer at 3ff00000, size 100000
ram_console: uncorrectable error in header
ram_console: no valid data in buffer (sig = 0x458078cc)
console enabled
----ldb_init
hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
hw-breakpoint: 1 breakpoint(s) reserved for watchpoint single-step.
hw-breakpoint: maximum watchpoint size is 4 bytes.
L310 cache controller enabled
l2x0: 16 ways, CACHE_ID 0x410000c8, AUX_CTRL 0x32050000, Cache size: 524288 B
bio: create slab <bio-0> at 0
mxs-dma mxs-dma-apbh: initialized
print_constraints: VDDA: 2500 mV
print_constraints: VDDIO: 3300 mV
machine_constraints_voltage: VDDD: unsupportable voltage constraints
reg-fixed-voltage reg-fixed-voltage.2: Failed to register regulator: -22
reg-fixed-voltage: probe of reg-fixed-voltage.2 failed with error -22
print_constraints: vmmc: 3300 mV
vgaarb: loaded
SCSI subsystem initialized
spi_imx imx6q-ecspi.0: probed
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
Freescale USB OTG Driver loaded, $Revision: 1.55 $
mc_pfuze 1-0008: recv failed!:-5,0
mc_pfuze: probe of 1-0008 failed with error -1
imx-ipuv3 imx-ipuv3.0: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
mxc_mipi_csi2 mxc_mipi_csi2: i.MX MIPI CSI2 driver probed
mxc_mipi_csi2 mxc_mipi_csi2: i.MX MIPI CSI2 dphy version is 0x3130302a
MIPI CSI2 driver module loaded
Advanced Linux Sound Architecture Driver Version 1.0.24.
Bluetooth: Core ver 2.16
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
Bluetooth: L2CAP socket layer initialized
Bluetooth: SCO socket layer initialized
i2c-core: driver using legacy suspend method
i2c-core: driver using legacy resume method
Switching to clocksource mxc_timer1
NET: Registered protocol family 2
IP route cache hash table entries: 16384 (order: 4, 65536 bytes)
TCP established hash table entries: 65536 (order: 7, 524288 bytes)
TCP bind hash table entries: 65536 (order: 7, 786432 bytes)
TCP: Hash tables configured (established 65536 bind 65536)
TCP reno registered
UDP hash table entries: 256 (order: 1, 8192 bytes)
UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
PCI: CLS 0 bytes, default 32
Unpacking initramfs...
Freeing initrd memory: 228K
PMU: registered new PMU device of type 0
Static Power Management for Freescale i.MX6
wait mode is enabled for i.MX6
cpaddr = d9820000 suspend_iram_base=d98b8000
PM driver module loaded
IMX usb wakeup probe
the wakeup pdata is 0xd63fbb20
add wake up source irq 75
the wakeup pdata is 0xd63fb8e0
cpu regulator mode:ldo_enable
i.MXC CPU frequency driver
highmem bounce pool size: 64 pages
ashmem: initialized
NTFS driver 2.1.30 .
JFFS2 version 2.2. (NAND) 漏 2001-2006 Red Hat, Inc.
fuse init (API version 7.16)
msgmni has been set to 761
NET: Registered protocol family 38
cryptodev: driver loaded.
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
mxc_mipi_dsi mxc_mipi_dsi: i.MX MIPI DSI driver probed
MIPI DSI driver module loaded
mxc_sdc_fb mxc_sdc_fb.0: register mxc display driver hdmi
mxc_hdmi mxc_hdmi: Detected HDMI controller 0x13:0x1a:0xa0:0xc1
fbcvt: 1280x720@60: CVT Name - .921M9
imx-ipuv3 imx-ipuv3.0: IPU DMFC DP HIGH RESOLUTION: 1(0,1), 5B(2~5), 5F(6,7)
mxc_sdc_fb mxc_sdc_fb.1: Can't get fb option for mxcfb1!
imx-sdma imx-sdma: loaded firmware 1.1
imx-sdma imx-sdma: initialized
Serial: IMX driver
imx-uart.2: ttymxc2 at MMIO 0x21ec000 (irq = 60) is a IMX
imx-uart.1: ttymxc1 at MMIO 0x21e8000 (irq = 59) is a IMX
console enabled, bootconsole disabled
imx-uart.0: ttymxc0 at MMIO 0x2020000 (irq = 58) is a IMX
loop: module loaded
m25p80 spi0.0: unrecognized JEDEC id ffffff
GPMI NAND driver registered. (IMX)
vcan: Virtual CAN interface driver
CAN device driver interface
flexcan netdevice driver
FEC Ethernet Driver
fec_enet_mii_bus: probed
PPP generic driver version 2.4.2
PPP Deflate Compression module registered
PPP BSD Compression module registered
PPP MPPE Compression module registered
NET: Registered protocol family 24
PPTP driver version 0.8.5
tun: Universal TUN/TAP device driver, 1.6
tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
fsl-ehci fsl-ehci.0: Freescale On-Chip EHCI Host Controller
fsl-ehci fsl-ehci.0: new USB bus registered, assigned bus number 1
fsl-ehci fsl-ehci.0: irq 75, io base 0x02184000
fsl-ehci fsl-ehci.0: USB 2.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
add wake up source irq 72
fsl-ehci fsl-ehci.1: Freescale On-Chip EHCI Host Controller
fsl-ehci fsl-ehci.1: new USB bus registered, assigned bus number 2
fsl-ehci fsl-ehci.1: irq 72, io base 0x02184200
fsl-ehci fsl-ehci.1: USB 2.0 started, EHCI 1.00
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
usbcore: registered new interface driver cdc_acm
cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
usbcore: registered new interface driver usbserial
usbserial: USB Serial Driver core
USB Serial support registered for GSM modem (1-port)
usbcore: registered new interface driver option
option: v0.7.2:USB Driver for GSM modems
USB Serial support registered for Qualcomm USB modem
usbcore: registered new interface driver qcserial
ARC USBOTG Device Controller driver (1 August 2005)
android_usb gadget: Mass Storage Function, version: 2009/09/11
android_usb gadget: Number of LUNs=1
lun0: LUN: removable file: (no medium)
Gadget Android: controller 'fsl-usb2-udc' not recognized
android_usb gadget: android_usb ready
Suspend udc for OTG auto detect
USB Host suspend begins
will suspend roothub and its children
ehci_fsl_bus_suspend begins, DR
ehci_fsl_bus_suspend ends, DR
host suspend ends
USB Gadget resume begins
fsl_udc_resume, Wait for wakeup thread finishes
dr_controller_run: udc enter low power mode
USB Gadget resume ends
fsl-usb2-udc: bind to driver android_usb
mousedev: PS/2 mouse device common for all mice
generic touchscreen driver, <@>.
usb 2-1: new high speed USB device number 2 using fsl-ehci
hub 2-1:1.0: USB hub found
hub 2-1:1.0: 4 ports detected
>>>>> ct365_get_vendor() called <<<<<
Chip ID: 0x0
Chip data allocation failed: 0x0
using rtc device, snvs_rtc, for alarms
snvs_rtc snvs_rtc.0: rtc core: registered snvs_rtc as rtc0
i2c /dev entries driver
Linux video capture interface: v2.00
mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video16
mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video17
usbcore: registered new interface driver uvcvideo
USB Video Class driver (v1.1.0)
imx2-wdt imx2-wdt.0: IMX2+ Watchdog Timer enabled. timeout=60s (nowayout=1)
device-mapper: uevent: version 1.0.3
device-mapper: ioctl: 4.20.0-ioctl (2011-02-02) initialised: dm-devel@redhat.com
Bluetooth: Virtual HCI driver ver 1.3
Bluetooth: HCI UART driver ver 2.2
Bluetooth: HCIATH3K protocol initialized
Bluetooth: Generic Bluetooth USB driver ver 0.6
usbcore: registered new interface driver btusb
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
mmc0: SDHCI controller on platform using ADMA
mmc1: SDHCI controller on platform using ADMA
mmc2: SDHCI controller on platform using ADMA
mxc_vdoa mxc_vdoa: i.MX Video Data Order Adapter(VDOA) driver probed
VPU initialized
mxc_asrc registered
Galcore version 4.6.9.6622
revserved_memory_account:viv_gpu registerd
Thermal calibration data is 0x5bb5345f
Anatop Thermal registered as thermal_zone0
anatop_thermal_probe: default cooling device is cpufreq!
Registered led device: sys_led
Registered led device: user_led
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
mmc0: new high speed DDR MMC card at address 0001
logger: created 256K log 'log_main'
mmcblk0: mmc0:0001 MMC04G 3.57 GiB
logger: created 256K log 'log_events'
mmcblk0boot0: mmc0:0001 MMC04G partition 1 2.00 MiB
logger: created 256K log 'log_radio'
mmcblk0boot1: mmc0:0001 MMC04G partition 2 2.00 MiB
logger: created 256K log 'log_system'
usbcore: registered new interface driver snd-usb-audio
mxc_hdmi_soc mxc_hdmi_soc.0: MXC HDMI Audio
Cirrus Logic CS42888 ALSA SoC Codec Driver
mmcblk0: p1 p2 p3 < p5 p6 p7 p8 > p4
mmcblk0: p4 size 5324800 extends beyond EOD, truncated
----sab_sgtl5000_init
----enable clko_clk.
sgtl5000 0-000a: Failed to get supply 'VDDD': -19
print_constraints: 0-000a: 850 <--> 1600 mV at 1200 mV normal
mmcblk0boot1: unknown partition table
mmcblk0boot0: unknown partition table
sgtl5000 0-000a: sgtl5000 revision 17
asoc: sgtl5000 <-> imx-ssi.1 mapping ok
imx_3stack asoc driver
asoc: mxc-hdmi-soc <-> imx-hdmi-soc-dai.0 mapping ok
ALSA device list:
#0: sgtl5000-audio
#1: imx-hdmi-soc
oprofile: using arm/armv7-ca9
GACT probability NOT on
Mirror/redirect action on
u32 classifier
    Actions configured
Netfilter messages via NETLINK v0.30.
nf_conntrack version 0.5.0 (12824 buckets, 51296 max)
ctnetlink v0.93: registering with nfnetlink.
NF_TPROXY: Transparent proxy support initialized, version 4.1.0
NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
xt_time: kernel timezone is -0000
IPv4 over IPv4 tunneling driver
GRE over IPv4 demultiplexor driver
ip_tables: (C) 2000-2006 Netfilter Core Team
arp_tables: (C) 2002 David S. Miller
TCP cubic registered
NET: Registered protocol family 10
Mobile IPv6
ip6_tables: (C) 2000-2006 Netfilter Core Team
IPv6 over IPv4 tunneling driver
NET: Registered protocol family 17
NET: Registered protocol family 15
can: controller area network core (rev 20090105 abi 8)
NET: Registered protocol family 29
can: raw protocol (rev 20090105)
can: broadcast manager protocol (rev 20090105 t)
Bluetooth: RFCOMM TTY layer initialized
Bluetooth: RFCOMM socket layer initialized
Bluetooth: RFCOMM ver 1.11
Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Bluetooth: BNEP filters: protocol multicast
Bluetooth: HIDP (Human Interface Emulation) ver 1.2
L2TP core driver, V2.0
PPPoL2TP kernel driver, V2.0
L2TP IP encapsulation support (L2TPv3)
L2TP netlink interface
L2TP ethernet pseudowire support (L2TPv3)
lib80211: common routines for IEEE802.11 drivers
lib80211_crypt: registered algorithm 'NULL'
lib80211_crypt: registered algorithm 'WEP'
lib80211_crypt: registered algorithm 'CCMP'
lib80211_crypt: registered algorithm 'TKIP'
VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
Bus freq driver module loaded
Bus freq driver Enabled
mxc_dvfs_core_probe
DVFS driver module loaded
snvs_rtc snvs_rtc.0: setting system clock to 1970-01-01 00:00:00 UTC (0)
Freeing init memory: 248K
android_usb: already disabled
mtp_bind_config
adb_bind_config
adb_open
ehci_fsl_bus_suspend begins, Host 1
ehci_fsl_bus_suspend ends, Host 1
root@riot_6solo:/ # _pages_prepare+0x100/0x188) from [<c00ffe04>] (free_hot_cold_page+0x20/0x1b4)
[<c00ffe04>] (free_hot_cold_page+0x20/0x1b4) from [<c0057714>] (dma_free_coherent+0x13c/0x1c4)
[<c0057714>] (dma_free_coherent+0x13c/0x1c4) from [<c02e6b5c>] (mxcfb_set_par+0x558/0x834)
[<c02e6b5c>] (mxcfb_set_par+0x558/0x834) from [<c02d4d88>] (fb_set_var+0x124/0x290)
[<c02d4d88>] (fb_set_var+0x124/0x290) from [<c02d5200>] (do_fb_ioctl+0x30c/0x5d0)
[<c02d5200>] (do_fb_ioctl+0x30c/0x5d0) from [<c01405c0>] (do_vfs_ioctl+0x80/0x54c)
[<c01405c0>] (do_vfs_ioctl+0x80/0x54c) from [<c0140ac4>] (sys_ioctl+0x38/0x5c)
[<c0140ac4>] (sys_ioctl+0x38/0x5c) from [<c004c900>] (ret_fast_syscall+0x0/0x30)
BUG: Bad page state in process SurfaceFlingerpfn:4f62d
page:c12ea5a0 count:0 mapcount:0 mapping:(null) index:0x0
page flags: 0x40000400(reserved)
[<c0053fc4>] (unwind_backtrace+0x0/0x138) from [<c00fe2b0>] (bad_page+0x9c/0xf8)
[<c00fe2b0>] (bad_page+0x9c/0xf8) from [<c00fe40c>] (free_pages_prepare+0x100/0x188)
[<c00fe40c>] (free_pages_prepare+0x100/0x188) from [<c00ffe04>] (free_hot_cold_page+0x20/0x1b4)
BUG: Bad page state in process SurfaceFlingerpfn:4f62e
page:c12ea5c0 count:0 mapcount:0 mapping:(null) index:0x0
BUG: Bad page state in process SurfaceFlingerpfn:4f62f
page:c12ea5e0 count:0 mapcount:0 mapping:(null) index:0x0
BUG: Bad page state in process SurfaceFlingerpfn:4f630
page:c12ea600 count:0 mapcount:0 mapping:(null) index:0x0
BUG: Bad page state in process SurfaceFlingerpfn:4f631
page:c12ea620 count:0 mapcount:0 mapping:(null) index:0x0
BUG: Bad page state in process SurfaceFlingerpfn:4f632
page:c12ea640 count:0 mapcount:0 mapping:(null) index:0x0
BUG: Bad page state in process SurfaceFlingerpfn:4f633
page:c12ea660 count:0 mapcount:0 mapping:(null) index:0x0
BUG: Bad page state in process SurfaceFlingerpfn:4f634
page:c12ea680 count:0 mapcount:0 mapping:(null) index:0x0
BUG: Bad page state in process SurfaceFlingerpfn:4f635
page:c12ea6a0 count:0 mapcount:0 mapping:(null) index:0x0
BUG: Bad page state in process SurfaceFlingerpfn:4f636
page:c12ea6c0 count:0 mapcount:0 mapping:(null) index:0x0
BUG: Bad page state in process SurfaceFlingerpfn:4f637
page:c12ea6e0 count:0 mapcount:0 mapping:(null) index:0x0
BUG: Bad page state in process SurfaceFlingerpfn:4f638
page:c12ea700 count:0 mapcount:0 mapping:(null) index:0x0
BUG: Bad page state in process SurfaceFlingerpfn:4f639
page:c12ea720 count:0 mapcount:0 mapping:(null) index:0x0
BUG: Bad page state in process SurfaceFlingerpfn:4f63a
page:c12ea740 count:0 mapcount:0 mapping:(null) index:0x0
BUG: Bad page state in process SurfaceFlingerpfn:4f63b
page:c12ea760 count:0 mapcount:0 mapping:(null) index:0x0
ERROR: v4l2 capture: slave not found!
ERROR: HDMI is not ready!
asoc: can't open platform imx-hdmi-soc-audio.0
warning: `zygote' uses 32-bit capabilities (legacy support in use)
request_suspend_state: wakeup (3->0) at 18384322672 (1970-01-02 00:00:03.614784001 UTC)
eth0: Freescale FEC PHY driver (mii_bus:phy_addr=1:04, irq=-1)
ADDRCONF(NETDEV_UP): eth0: link is not ready
acc_open
acc_release
ehci_fsl_bus_resume begins, Host 1
ehci_fsl_bus_resume ends, Host 1
ehci_fsl_bus_resume begins, DR
init: sys_prop: permission denied uid:1003name:service.bootanim.exit
init: untracked pid 3271 exited
huazai1995 发表于 2019-12-13 15:54
页: [1]
查看完整版本: RiotBoard之把玩系列(1)
