思电lq 发表于 2011-9-29 16:31
大家来看看这个程序
#include<AT89X51.H>
unsigned charcode dispcode[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x00};
unsigned charcode dispbitcode[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};
unsigned chardispbuf[]={10,10,10,10,0,0,0,0};
unsignedinttemp ;
unsignedchar   i;
unsigned char dispcount=0;
unsigned char getdata;
sbit ST=P3^0;
sbit OE=P3^1;
sbit EOC=P3^2;
sbit CLK=P3^3;
voidmain(void)
ST=0;
OE=0;
ET0=1;
ET1=1;
EA=1;
TMOD=0x12;
TH0=216;
TL0=216;
TH1=(65535-4000)/256;
TL1=(65535-4000)%256;
TR0=1;
TR1=1;
ST=1;
ST=0;
while(1)
   if(EOC==1)
    OE=1;
    getdata=P0;
OE=0;
    temp=getdata*235;
    temp=temp/128;
    i=0;
    dispbuf=0;
    dispbuf=0;
dispbuf=0;
dispbuf=10;
dispbuf=10;
dispbuf=10;
   dispbuf=10;
dispbuf=10;
while(temp/10)
   dispbuf=temp%10;
   temp=temp/10;
   i++;
dispbuf=temp;
      ST=1;
   ST=0;
void t0(void) interrupt 1 using 0
CLK=~CLK;
   void t1(void) interrupt 3 using 0
P1=dispcode];
P2=dispbitcode;
if(dispcount==1)
   P1=P1|0x80;
dispcount++;
if(dispcount==8)
dispcount==0 ;
数码管显示0000没有显示电压值,还望高手指点一下``
思电lq 发表于 2011-9-29 16:40
外加说明`这是一个数摸转换实验并用数码管显示
airwill 发表于 2011-9-29 20:04
楼主的程序什么说明都没有, 连硬件说明都没有, 什么芯片, 怎么连接, 如何驱动数码管, 看起来比较吃力啊!
页: [1]
查看完整版本: 大家来看看这个程序
