hanxing002 发表于 2019-4-18 10:16
超高压陶瓷电容器
发布时间:2019-04-18 09:58:29
截止时间:2019-05-18 09:58:29
项目周期:30天以上
现居地址:广东省东莞市东莞市
项目描述:
        Specification of High Voltage Ceramic Disc Capacitor
        Model
        型号
        CT82-6KV-D12-F9.5-102K
        Color
        颜色
        Dark Blue
        深蓝
        Condition of Testing
        试验条件
        Frequency
        频率
        Temperature
        温度
        Humidity
        湿度
        1KHZ
        22℃
        70%
        Static Capacitance
        容量
        1000PF
        Outline Size
        https://bbs.21ic.com/api/file://C:/Users/ADMINI~1/AppData/Local/Temp/ksohtml1552/wps2.png
        Withstand Voltage
        耐压
        ≥9KV
        Capacitance Range
        容量范围
        ±10%
        Dissipation
        损耗角
        ≤1%
        Insulation Resistance
        绝缘电阻
        ≥100000MΩ
        Temperature
        Characteristics
        温度特性
        Y5T
        Operating Temperature
        工作温度
        -25℃~+85℃
        Pitch (F)
        脚距
        9.5±0.3mm
        Diameter× Thickness
        (MAX)直径厚度
        12×6mm
        Diameter of Lead Wire
        引出线直径
        0.6±0.02mm
        Length of Encapsulated Lead Wire (MAX)
        包封脚长
        3 mm
        Length of Lead Wire
        引线长度
        25+/- 2 mm
        Application
        应用
        Indispensable components for high voltage or the UHF instruments, machinery, X-ray machine, precision type instrument, medical equipment, aerospace, high voltage generator, anion generator, voltage regulator, electric power equipment, meters, home appliances, electrostatic paint spray equipment, military equipment, detector equipment, many other products and industrial applications.
去竞标
页: [1]
查看完整版本: 超高压陶瓷电容器
