Anxyuuu 发表于 2019-5-13 10:30
MY-IMX6-A9 Linux-3.0.35 编译参考手册 v3.0(2)
【接上一章节MY-IMX6-A9 Linux-3.0.35 编译参考手册 v3.0(1)】
4内核编译
4.1编译前的准备创建编译工作目录=====> Input:mkdir ~/my-work/02_source/ -p解压源码包到工作目录=====> Input:tar xf linux-3.0.35-svn*.tar.bz2 -C ~/my-work/02_source/
4.2编译内核目标文件进入源码目录=====> Input:cd ~/my-work/02_source/linux-3.0.35生成目标平台的 .config 文件=====> Input:make myimx6a9_defconfig
=====> Output: HOSTCCscripts/basic/fixdepHOSTCCscripts/kconfig/conf.oSHIPPED scripts/kconfig/zconf.tab.cSHIPPED scripts/kconfig/lex.zconf.cSHIPPED scripts/kconfig/zconf.hash.cHOSTCCscripts/kconfig/zconf.tab.oHOSTLDscripts/kconfig/conf## configuration written to .config#Note: 如果有“Can't find default configuration "arch/x86/configs” 的错误,是因为交叉编译工具链的配置没有生效,可以按前面 “交叉编译工具链安装” 中的 “source 工具链配置文件” 操作一次后再执行此步骤编译内核目标文件=====> Input:make zImage
=====> Output: scripts/kconfig/conf --silentoldconfig KconfigCHK   include/linux/version.hUPD   include/linux/version.hCHK   include/generated/utsrelease.hUPD   include/generated/utsrelease.hGenerating include/generated/mach-types.hCC      kernel/bounds.s......AS      arch/arm/boot/compressed/piggy.gzip.oLD      arch/arm/boot/compressed/vmlinuxOBJCOPY arch/arm/boot/zImageKernel: arch/arm/boot/zImage is ready内核目标文件
arch/arm/boot/zImage 即内核目标文件
4.4编译内核模块包执行编译=====> Input:make modules
=====> Output: CHK   include/linux/version.hCHK   include/generated/utsrelease.hmake: “include/generated/mach-types.h”是最新的。CALL    scripts/checksyscalls.shCC fs/autofs4/init.o......LD drivers/usb/gadget/g_serial.koLD fs/nls/nls_ascii.koLD fs/autofs4/autofs4.koLD fs/nls/nls_utf8.ko创建内核模块的保存目录=====> Input:mkdir modules安装内核模块到指定目录=====> Input:make modules_install INSTALL_MOD_PATH=./modules
=====> Output: INSTALL crypto/tcrypt.koINSTALL drivers/gpu/drm/drm.koINSTALL drivers/gpu/drm/vivante/vivante.ko......INSTALL fs/autofs4/autofs4.koINSTALL fs/nls/nls_ascii.koINSTALL fs/nls/nls_utf8.koDEPMOD3.0.35-myimx6a9-svn42打包内核模块文件=====> Input:tar cjf kernel-modules.tar.bz2 -C modules lib
4.5目标文件zImage 和 kernel-modules.tar.bz2 即编译得到的目标文件,保存这两个文件
5Linux C程序编译5.1准备源码打开网盘到 5_MY-Demo -> MY-Linux-C-Demo,下载 hello.c 文件,并复制到虚拟机。
5.2编译目标文件=====> Input:${CROSS_COMPILE}gcc hello.c -o hello.outNote: 如果有“未找到命令”的信息,是因为交叉编译工具链的配置没有生效,可以按前面 “交叉编译工具链安装” 中的 “source 工具链配置文件” 操作一次后再执行此步骤
5.3运行Linux C目标程序把编译得到的 hello.out 复制到开发板上在开发板上运行Linux C目标程序=====> Input:chmod +x ./hello.out./hello.out
=====> Output:MYZR Technology Co.,Ltd.
Web:http://www.myzr.com.cn/Wiki: http://wiki.myzr.com.cn/BBS:http://bbs.myzr.com.cn/
Tel: 0756-3628023/3628021E-mail: service@myzr.com.cn
6Linux QT5程序编译
6.1准备源码打开网盘到 5_MY-Demo,下载 MY-Linux-QT5-Demo-AboutUs-svn*.tar.bz2 文件,并复制到虚拟机。解压源码包到工作目录=====> Input:tar xf MY-Linux-QT5-Demo-AboutUs-svn*.tar.bz2 -C ~/my-work/02_source/
6.2QT程序编译进入源码目录=====> Input:cd ~/my-work/02_source/AboutUs/生成Makefile文件=====> Input:qmakeNote: 如果有“未找到 'qamke' 命令”的信息,是因为交叉编译工具链的配置没有生效,可以按前面 “交叉编译工具链安装” 中的 “source 工具链配置文件” 操作一次后再执行此步骤编译目标文件=====> Input:make
=====> Output: /home/myzr/my-work/03_toolchain/fsl-imx-fb-glibc-x86_64-meta-toolchain-qt5-cortexa9hf-vfp-neon-toolchain-3.14.52-1.1.1/sysroots/x86_64-pokysdk-linux/usr/bin/qt5/uic widget.ui -o ui_widget.h......arm-poky-linux-gnueabi-g++-march=armv7-a -mfloat-abi=hard -mfpu=neon -mtune=cortex-a9 --sysroot=/home/myzr/my-work/03_toolchain/fsl-imx-fb-glibc-x86_64-meta-toolchain-qt5-cortexa9hf-vfp-neon-toolchain-3.14.52-1.1.1/sysroots/cortexa9hf-vfp-neon-poky-linux-gnueabi -Wl,-O1 -Wl,--hash-style=gnu -Wl,--as-needed -Wl,-O1 -o AboutUs main.o widget.o qrc_source.o moc_widget.o   -lQt5Widgets -lQt5Gui -lQt5Core -lGLESv2 -lEGL -lpthread
6.3在 MY-IMX6-A9 设备上运行把编译得到的 AboutUs 复制到开发板上在开发板上运行QT5目标程序=====> Input:chmod +x ./AboutUs./AboutUs -platform eglfs
6.4运行结果可以看到开发板显示屏上输出了 MYZR 的 ** 和一些信息。
页: [1]
查看完整版本: MY-IMX6-A9 Linux-3.0.35 编译参考手册 v3.0(2)
