shanxin2012 发表于 2019-5-20 10:33
Realtek RTL8380M-VB-CG
RTL8380M-VB-CG
MULTI-LAYER MANAGED 10*10/100/1000M-PORT SWITCH CONTROLLER
General Description
The RTL8380M-VB-CG is a new generation Gigabit switches supporting Energy Efficient Ethernet (EEE).
The RTL8380M-VB is an 10-port 10/100/1000M switch controller
The RTL8380M-VB supports two-pairs of SGMII/1000Base-X.
Features
10-port Gigabit wire speed forwarding capability
Embedded 8-port 10/100/1000M Ethernet PHY
Supports two pairs of SGMII/1000Base-X
Flexible Interfaces for Internal or External CPU
Serial/Dual I/O mode 32MB SPI Flash
Up to 128MB DDR1/DDR2 and 256MB DDR3 for internal MIPS-4KEc
Embedded MIPS-4KEc with MMU
Applications
Managed 8*1000M UTP + 2*1000Base-X
页: [1]
查看完整版本: Realtek RTL8380M-VB-CG
