aa911 发表于 2019-6-6 19:33
关于STM32F072启动的问题
由于所用的DEMO版需要,我把第7行改为第8行 ,程序一直在第10行到第14行的地方循环执行,MCU无法正常工作,请问各位问题出在哪?static void SetSysClock(void)
__IO uint32_t StartUpCounter = 0, HSEStatus = 0;
/* SYSCLK, HCLK, PCLK configuration ----------------------------------------*/
/* Enable HSE */
//RCC->CR |= ((uint32_t)RCC_CR_HSEON);
         RCC->CR &= ~((uint32_t)RCC_CR_HSEON);
/* Wait till HSE is ready and if Time out is reached exit */
do
    HSEStatus = RCC->CR & RCC_CR_HSERDY;
    StartUpCounter++;
} while((HSEStatus == 0) && (StartUpCounter != HSE_STARTUP_TIMEOUT));
if ((RCC->CR & RCC_CR_HSERDY) != RESET)
    HSEStatus = (uint32_t)0x01;
else
    HSEStatus = (uint32_t)0x00;
if (HSEStatus == (uint32_t)0x01)
    /* Enable Prefetch Buffer and set Flash Latency */
    FLASH->ACR = FLASH_ACR_PRFTBE | FLASH_ACR_LATENCY;
    /* HCLK = SYSCLK */
    RCC->CFGR |= (uint32_t)RCC_CFGR_HPRE_DIV1;
    /* PCLK = HCLK */
    RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE_DIV1;
    /* PLL configuration = HSI * 6 = 48 MHz */
    RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_PLLSRC | RCC_CFGR_PLLXTPRE | RCC_CFGR_PLLMULL));
    RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_PREDIV1 | RCC_CFGR_PLLXTPRE_PREDIV1 | RCC_CFGR_PLLMULL6);
    /* Enable PLL */
    RCC->CR |= RCC_CR_PLLON;
    /* Wait till PLL is ready */
    while((RCC->CR & RCC_CR_PLLRDY) == 0)
    /* Select PLL as system clock source */
    RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_SW));
    RCC->CFGR |= (uint32_t)RCC_CFGR_SW_PLL;
    /* Wait till PLL is used as system clock source */
    while ((RCC->CFGR & (uint32_t)RCC_CFGR_SWS) != (uint32_t)RCC_CFGR_SWS_PLL)
else
{ /* If HSE fails to start-up, the application will have wrong clock
         configuration. User can add here some code to deal with this error */
airwill 发表于 2019-6-7 22:27
这是在等待时钟就绪, 说明时钟电路有问题
使用的是内部时钟,没有外部时钟。
使用的是内部时钟,没有外部时钟。
那就把这段代码注释掉,没有放晶振,HSE初始化肯定失败啊
已经解决,谢谢哈
已经解决,谢谢哈
小事情,不客气
页: [1]
查看完整版本: 关于STM32F072启动的问题
