phdwong 发表于 2019-7-17 12:32
AP6212不能收发信号
大家有没有碰到过,驱动加载正常,作为AP或者STA的时候不能收发信号
hostapd log如下
addr:192.168.8.100Bcast:192.168.8.255Mask:255.255.255.0
Dongle Host Driver, version 1.363.59.144.2 (r)
       UP BROADCAST RUNNING MULTICASTMTU:1500Metric:1
   wl_android_wifi_on in 1
   RX packets:0 errors:0 dropped:0 overruns:0 frame:0
       wl_android_wifi_on in 2: g_wifi_on=0
   TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
       wifi_platform_set_power = 1
   collisions:0 txqueuelen:1000
          RX bytes:0 (0.0 B)======== PULL WL_REG_ON HIGH! 146 ========
TX bytes:0 (0.0 B)
          Interrupt:54 Base address:0xb000
lo      Link encap:Local Loopback
          inet addr:127.0.0.1Mask:255.0.0.0
          UP LOOPBACK RUNNINGMTU:65536Metric:1
          collisions:0 txqueuelen:0
          RX bytes:0 (0.0 B)TX bytes:0 (0.0 B)
wlan0   Link encap:EthernetHWaddr 8C:F7:10:E2:DF:DE
          BROADCAST MULTICASTMTU:1500Metric:1
sdio_reset_comm():
mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
mmc1: queuing unknown CIS tuple 0x81 (9 bytes)
sdioh_start: set sd_f2_blocksize 128
dhd_bus_devreset: == WLAN ON ==
F1 signature read @0x18000000=0x1541a9a6
F1 signature OK, socitype:0x1 chip:0xa9a6 rev:0x1 pkg:0x4
DHD: dongle ram size is set to 524288(orig 524288) at 0x0
dhd_conf_read_config: Ignore config file /etc/firmware/config.txt
dhd_conf_set_fw_name_by_chip: firmware_path=/etc/firmware/fw_bcm43438a1.bin
dhdsdio_download_firmware: set use_rxchain 0
dhdsdio_download_firmware: set txglomsize 40
Final fw_path=/etc/firmware/fw_bcm43438a1.bin
Final nv_path=/etc/firmware/RichyTek_NV.txt
Final conf_path=/etc/firmware/config.txt
dhd_os_open_image: /etc/firmware/fw_bcm43438a1.bin (374608 bytes) open success
dhd_os_open_image: /etc/firmware/RichyTek_NV.txt (979 bytes) open success
NVRAM version: AP6212_NVRAM_V1.0.1_20160606
dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded.
dhd_bus_init: enable 0x06, ready 0x06 (waited 0us)
bcmsdh_oob_intr_register: Enter
bcmsdh_oob_intr_register: HW_OOB enabled
bcmsdh_oob_intr_register OOB irq=105 flags=414
bcmsdh_oob_intr_register: enable_irq_wake
Disable tdls_auto_op failed. -1
dhd_conf_set_fw_int_cmd: set WLC_SET_BAND 142 0
dhd_preinit_ioctls: Set tcpack_sup_mode 0
Firmware up: op_mode=0x0005, MAC=8c:f7:10:e2:df:de
dhd_conf_set_country: set country CN, revision 0
Country code: CN (CN/0)
dhd_conf_set_fw_string_cmd: set roam_off 1
Firmware version = wl0: Oct8 2016 15:31:47 version 7.46.57.4.ap.r4 (A1 Station/P2P) FWID 01-3621395e es6.c5.n4.a3
Driver: 1.363.59.144.2 (r)
Firmware: wl0: Oct8 2016 15:31:47 version 7.46.57.4.ap.r4 (A1 Station/P2P) FWID 01-3621395e es6.c5.n4.a3
dhd_txglom_enable: enable 1
dhd_conf_set_txglom_params: swtxglom=0, txglom_ext=0
dhd_conf_set_txglom_params: txglom_bucket_size=0
dhd_conf_set_txglom_params: txglomsize=40, deferred_tx_len=40, bus_txglom=-1
dhd_conf_set_txglom_params: tx_in_rx=1, tx_max_offset=0
sdioh_set_mode: set txglom_mode to multi-desc
dhd_conf_set_disable_proptx: set disable_proptx 0
dhd_wlfc_hostreorder_init(): successful bdcv2 tlv signaling, 64
dhd_pno_init: Support Android Location Service
wl_android_wifi_on: Success
wl_create_event_handler(): thread:wl_event_handler:29f started
tsk Enter, tsk = 0x41dc14a8
CFG80211-ERROR) wl_update_wiphybands : error reading vhtmode (-23)
dhd_open: Exit ret=0
Internet Systems Consortium DHCP Server 4.2.5-P1
Copyright 2004-2013 Internet Systems Consortium.
All rights reserved.
For info, please visit https://www.isc.org/software/dhcp/
Wrote 0 leases to leases file.
Listening on LPF/wlan0/8c:f7:10:e2:df:de/198.168.8.0/24
Sending on   LPF/wlan0/8c:f7:10:e2:df:de/198.168.8.0/24
Sending on   Socket/fallback/fallback-net
rcS Complete
There's already a DHCP server running.
If you did not get this software from ftp.isc.org, please
get the latest from ftp.isc.org and install that before
requesting help.
If you did get this software from ftp.isc.org and have not
yet read the README, please read it before requesting help.
If you intend to request help from the dhcp-server@isc.org
mailing list, please read the section on the README about
submitting bug reports and requests for help.
Please do not under any circumstances send requests for
help directly to the authors of this software - please
send them to the appropriate mailing list as described in
the README file.
exiting.
-/bin/ash: syntax error: unterminated quoted string
/ # Configuration file: /etc/hostapd_cfg.conf
rfkill: Cannot open RFKILL control device
random: nonblocking pool is initialized
CFG80211-ERROR) wl_cfg80211_del_station : Disconnect STA : ff:ff:ff:ff:ff:ff scb_val.val 3
Using interface wlan0 with hwaddr 8c:f7:10:e2:df:de and ssid "Soft_AP"
random: Cannot read from /dev/random: Resource temporarily unavailable
random: Only 0/20 bytes of strong random data available frnetdev_ifidx(3), chan_type(1) target channel(6)
om /dev/random
random: Not enough entropy pool available for secure operations
WPA: Not enough entropy in random pool for secure operations - update keys later when the first station connects
wl_iw_event: Link UP with BSSID=8c:f7:00:00:df:de
CFG80211-ERROR) wl_notify_connect_status_ap : ** AP/GO Link up event **
wlan0: interface state UNINITIALIZED->ENABLED
wlan0: AP-ENABLED
aozima 发表于 2019-7-17 15:32
固件中的天线和PA配置不对吧? 或是硬件坏了。
phdwong 发表于 2019-7-18 09:28
这个是供应商提供的,天线也是按照模板来设计的
natertech 发表于 2019-7-24 14:39
在什么平台使用?kernel版本多少
这种平台驱动要对接好才行
页: [1]
查看完整版本: AP6212不能收发信号
