spfaaafps 发表于 2019-8-9 10:49
dsp28335无法读写NAT9914寄存器
最近准备用DSP28335与NAT9914制作GPIB接口,利用zone7与nat9914连接,但是一直无法正确读写NAT9914寄存器,怀疑是读写时序问题,求高手指点。
部分代码 InitPll(DSP28_PLLCR,DSP28_DIVSEL); //设置时钟频率150MHZ void InitPeripheralClocks(void){   EALLOW; // HISPCP/LOSPCP prescale register settings, normally it will be set to default values   SysCtrlRegs.HISPCP.all = 0x0001;   SysCtrlRegs.LOSPCP.all = 0x0002; // XCLKOUT to SYSCLKOUT ratio.By default XCLKOUT = 1/4 SYSCLKOUT   // XTIMCLK = SYSCLKOUT/2   XintfRegs.XINTCNF2.bit.XTIMCLK = 1;   // XCLKOUT = XTIMCLK/2   XintfRegs.XINTCNF2.bit.CLKMODE = 1;   // Enable XCLKOUT   XintfRegs.XINTCNF2.bit.CLKOFF = 0; // Peripheral clock enables set for the selected peripherals.// If you are not using a peripheral leave the clock off// to save on power.//// Note: not all peripherals are available on all 2833x derivates.// Refer to the datasheet for your particular device.//// This function is not written to be an example of efficient code.    SysCtrlRegs.PCLKCR0.bit.ADCENCLK = 1;    // ADC    // *IMPORTANT*   // The ADC_cal function, whichcopies the ADC calibration values from TI reserved   // OTP into the ADCREFSEL and ADCOFFTRIM registers, occurs automatically in the   // Boot ROM. If the boot ROM code is bypassed during the debug process, the   // following function MUST be called for the ADC to function according   // to specification. The clocks to the ADC MUST be enabled before calling this   // function.   // See the device data manual and/or the ADC Reference   // Manual for more information.    ADC_cal();    SysCtrlRegs.PCLKCR0.bit.I2CAENCLK = 1;   // I2C   SysCtrlRegs.PCLKCR0.bit.SCIAENCLK = 1;   // SCI-A   SysCtrlRegs.PCLKCR0.bit.SCIBENCLK = 1;   // SCI-B   SysCtrlRegs.PCLKCR0.bit.SCICENCLK = 1;   // SCI-C   SysCtrlRegs.PCLKCR0.bit.SPIAENCLK = 1;   // SPI-A   SysCtrlRegs.PCLKCR0.bit.MCBSPAENCLK = 1; // McBSP-A   SysCtrlRegs.PCLKCR0.bit.MCBSPBENCLK = 1; // McBSP-B   SysCtrlRegs.PCLKCR0.bit.ECANAENCLK=1;    // eCAN-A   SysCtrlRegs.PCLKCR0.bit.ECANBENCLK=1;    // eCAN-B    SysCtrlRegs.PCLKCR0.bit.TBCLKSYNC = 0;   // Disable TBCLK within the ePWM   SysCtrlRegs.PCLKCR1.bit.EPWM1ENCLK = 1;// ePWM1   SysCtrlRegs.PCLKCR1.bit.EPWM2ENCLK = 1;// ePWM2   SysCtrlRegs.PCLKCR1.bit.EPWM3ENCLK = 1;// ePWM3   SysCtrlRegs.PCLKCR1.bit.EPWM4ENCLK = 1;// ePWM4   SysCtrlRegs.PCLKCR1.bit.EPWM5ENCLK = 1;// ePWM5   SysCtrlRegs.PCLKCR1.bit.EPWM6ENCLK = 1;// ePWM6   SysCtrlRegs.PCLKCR0.bit.TBCLKSYNC = 1;   // Enable TBCLK within the ePWM    SysCtrlRegs.PCLKCR1.bit.ECAP3ENCLK = 1;// eCAP3   SysCtrlRegs.PCLKCR1.bit.ECAP4ENCLK = 1;// eCAP4   SysCtrlRegs.PCLKCR1.bit.ECAP5ENCLK = 1;// eCAP5   SysCtrlRegs.PCLKCR1.bit.ECAP6ENCLK = 1;// eCAP6   SysCtrlRegs.PCLKCR1.bit.ECAP1ENCLK = 1;// eCAP1   SysCtrlRegs.PCLKCR1.bit.ECAP2ENCLK = 1;// eCAP2   SysCtrlRegs.PCLKCR1.bit.EQEP1ENCLK = 1;// eQEP1   SysCtrlRegs.PCLKCR1.bit.EQEP2ENCLK = 1;// eQEP2    SysCtrlRegs.PCLKCR3.bit.CPUTIMER0ENCLK = 1; // CPU Timer 0   SysCtrlRegs.PCLKCR3.bit.CPUTIMER1ENCLK = 1; // CPU Timer 1   SysCtrlRegs.PCLKCR3.bit.CPUTIMER2ENCLK = 1; // CPU Timer 2    SysCtrlRegs.PCLKCR3.bit.DMAENCLK = 1;       // DMA Clock   SysCtrlRegs.PCLKCR3.bit.XINTFENCLK = 1;   // XTIMCLK   SysCtrlRegs.PCLKCR3.bit.GPIOINENCLK = 1;    // GPIO input clock    EDIS;} void InitGpio(void){        EALLOW;        //数据线        GpioCtrlRegs.GPCMUX1.bit.GPIO64=2;        GpioCtrlRegs.GPCMUX1.bit.GPIO65=2;        GpioCtrlRegs.GPCMUX1.bit.GPIO66=2;        GpioCtrlRegs.GPCMUX1.bit.GPIO67=2;        GpioCtrlRegs.GPCMUX1.bit.GPIO68=2;        GpioCtrlRegs.GPCMUX1.bit.GPIO69=2;        GpioCtrlRegs.GPCMUX1.bit.GPIO70=2;        GpioCtrlRegs.GPCMUX1.bit.GPIO71=2;        GpioCtrlRegs.GPCMUX1.bit.GPIO72=2;        GpioCtrlRegs.GPCMUX1.bit.GPIO73=2;        GpioCtrlRegs.GPCMUX1.bit.GPIO74=2;        GpioCtrlRegs.GPCMUX1.bit.GPIO75=2;        GpioCtrlRegs.GPCMUX1.bit.GPIO76=2;        GpioCtrlRegs.GPCMUX1.bit.GPIO77=2;        GpioCtrlRegs.GPCMUX1.bit.GPIO78=2;        GpioCtrlRegs.GPCMUX1.bit.GPIO79=2;                //地址线        GpioCtrlRegs.GPBMUX1.bit.GPIO40=2;        GpioCtrlRegs.GPBMUX1.bit.GPIO41=2;        GpioCtrlRegs.GPBMUX1.bit.GPIO42=2;        GpioCtrlRegs.GPBMUX1.bit.GPIO43=2;        GpioCtrlRegs.GPBMUX1.bit.GPIO44=2;        GpioCtrlRegs.GPBMUX1.bit.GPIO45=2;        GpioCtrlRegs.GPBMUX1.bit.GPIO46=2;        GpioCtrlRegs.GPBMUX1.bit.GPIO47=2;         GpioCtrlRegs.GPCMUX2.bit.GPIO80=2;        GpioCtrlRegs.GPCMUX2.bit.GPIO81=2;        GpioCtrlRegs.GPCMUX2.bit.GPIO82=2;        GpioCtrlRegs.GPCMUX2.bit.GPIO83=2;        GpioCtrlRegs.GPCMUX2.bit.GPIO84=2;        GpioCtrlRegs.GPCMUX2.bit.GPIO85=2;        GpioCtrlRegs.GPCMUX2.bit.GPIO86=2;        GpioCtrlRegs.GPCMUX2.bit.GPIO87=2;         GpioCtrlRegs.GPBMUX1.bit.GPIO39=2;         GpioCtrlRegs.GPAMUX2.bit.GPIO31=2;        GpioCtrlRegs.GPAMUX2.bit.GPIO30=2;        GpioCtrlRegs.GPAMUX2.bit.GPIO29=2;         //GPIO0:通用IO,输入,配置成中断XINT1,用于相应NAT9914的中断请求        GpioCtrlRegs.GPAMUX1.bit.GPIO0=0;        GpioCtrlRegs.GPADIR.bit.GPIO0=0;         //GPIO1:通用IO,输出,初始值设为0,高电平有效,用于RESET NAT9914        //GpioCtrlRegs.GPAMUX1.bit.GPIO1=0;        //GpioCtrlRegs.GPADIR.bit.GPIO1=1;        //GpioDataRegs.GPADAT.bit.GPIO1=0;                //GPIO2:通用IO,输出,初始值设为1,用于使能芯片xx 1OE        GpioCtrlRegs.GPAMUX1.bit.GPIO2=0;        GpioCtrlRegs.GPADIR.bit.GPIO2=1;        GpioDataRegs.GPADAT.bit.GPIO2=0;         //GPIO3:通用IO,输出,初始值设为1,用于使能芯片xx 2OE        GpioCtrlRegs.GPAMUX1.bit.GPIO3=0;        GpioCtrlRegs.GPADIR.bit.GPIO3=1;        GpioDataRegs.GPADAT.bit.GPIO3=0;         //GPIO4:通用IO,输出,用于控制芯片xx 组1传输方向高电平写入NAT9914 低电平从NAT9914读取,初始值设为0(低电平)        GpioCtrlRegs.GPAMUX1.bit.GPIO4=0;        GpioCtrlRegs.GPADIR.bit.GPIO4=1;        GpioDataRegs.GPADAT.bit.GPIO4=0;         //GPIO37:XZCS7        GpioCtrlRegs.GPBMUX1.bit.GPIO37=2;                //GPIO38:XWE0        GpioCtrlRegs.GPBMUX1.bit.GPIO38=2;         EDIS;} int inp(long io_address)   //从nat9914读取数据{    int value;    GpioDataRegs.GPADAT.bit.GPIO4 = 0;    value=*(int *)io_address;    return value;} void outp(long io_address,u_8 o_data)   //向nat9914写入数据{    GpioDataRegs.GPADAT.bit.GPIO4 = 1;    *(int *)io_address = o_data;}
zhangmangui 发表于 2019-8-11 00:11
我觉得只能对比两者的时序了   看是否有差异
airwill 发表于 2019-8-27 21:29
直接用示波器捕捉一下时序波形, 看看有没有满足手册要求再说
页: [1]
查看完整版本: dsp28335无法读写NAT9914寄存器
