can如何获取数据存放数组
现在遇到的问题是不明白怎么样把can获取出来的数据存到数组里。也不明白can中读数据的>>while(ECanbRegs.CANRMP.all & (1<< MBXnbr) == 0 ){} // Wait for mailbox receive panding flag to be set..ECanbRegs.CANRMP.all |= 1<< MBXnbr; // Clear receive panding flag<<这两句的作用。代码如下,求大神讲解,谢谢!#include "DSP2833x_Device.h" // DSP2833x Headerfile Include File
#include "DSP2833x_Examples.h" // DSP2833x Examples Include File
Uint32MessageReceivedCount;
Uint32PassCount = 0;
Uint32TestMbox1 = 0;
Uint32TestMbox2 = 0;
Uint32TestMbox3 = 0;
Uint32 buffer;
void mailboxb_read(int16);
void date_check(int32,int32);
void main(void)
//long tt;
struct ECAN_REGSECanbShadow;
// Step 1. Initialize System Control:
// PLL, WatchDog, enable Peripheral Clocks
// This example function is found in the DSP2833x_SysCtrl.c file.
InitSysCtrl();
// Step 2. Initalize GPIO:
// This example function is found in the DSP2833x_Gpio.c file and
// illustrates how to set the GPIO to it's default state.
// InitGpio();// Skipped for this example
InitXintf16Gpio(); //zq
// Just initalize eCAN pins for this example
// This function is in DSP2833x_ECan.c
InitECanGpio();
// Step 3. Clear all interrupts and initialize PIE vector table:
// Disable CPU interrupts
DINT;
// Initialize the PIE control registers to their default state.
// The default state is all PIE interrupts disabled and flags
// are cleared.
// This function is found in the DSP2833x_PieCtrl.c file.
InitPieCtrl();
// Disable CPU interrupts and clear all CPU interrupt flags:
IER = 0x0000;
IFR = 0x0000;
// Initialize the PIE vector table with pointers to the shell Interrupt
// Service Routines (ISR).
// This will populate the entire table, even if the interrupt
// is not used in this example.This is useful for debug purposes.
// The shell ISR routines are found in DSP2833x_DefaultIsr.c.
// This function is found in DSP2833x_PieVect.c.
InitPieVectTable();
// In this case just initalize eCAN-A and eCAN-B
InitECan();
// Interrupts that are used in this example are re-mapped to
// ISR functions found within this file.
EALLOW;// This is needed to write to EALLOW protected registers
PieVectTable.TINT0 = &ISRTimer0;
//PieVectTable.ECAN0INTB = &ISRCANB;
//PieVectTable.XINT13 = &cpu_timer1_isr;
//PieVectTable.TINT2 = &cpu_timer2_isr;
EDIS; // This is needed to disable write to EALLOW protected registers
// Step 4. Initialize the Device Peripheral. This function can be
// found in DSP2833x_CpuTimers.c
InitCpuTimers(); // For this example, only initialize the Cpu Timers
// Configure CPU-Timer 0, 1, and 2 to interrupt every second:
// 150MHz CPU Freq, 1 second Period (in uSeconds)
ConfigCpuTimer(&CpuTimer0, 150, 5);
//ConfigCpuTimer(&CpuTimer1, 150, 1000000);
//ConfigCpuTimer(&CpuTimer2, 150, 1000000);
StartCpuTimer0();
// Enable CPU int1 which is connected to CPU-Timer 0, CPU int13
// which is connected to CPU-Timer 1, and CPU int 14, which is connected
// to CPU-Timer 2:
IER |= M_INT1;
//IER |= M_INT9;
//IER |= M_INT13;
//IER |= M_INT14;
// Enable TINT0 in the PIE: Group 1 interrupt 7
PieCtrlRegs.PIEIER1.bit.INTx7 = 1;
//PieCtrlRegs.PIEIER9.bit.INTx5 = 1;
// Enable global Interrupts and higher priority real-time debug events:
EINT; // Enable Global interrupt INTM
ERTM; // Enable Global realtime interrupt DBGM
/* Write to the MSGID field*/
EALLOW;
/* Configure eCANB Mailbox_20 as a Receive mailbox */
ECanbMboxes.MBOX20.MSGID.all = 0x95555555; // Extended Identifier, same as the Transmitor
/* Configure Mailbox under test as a Receive mailbox */
ECanbShadow.CANMD.all = ECanbRegs.CANMD.all;
ECanbShadow.CANMD.bit.MD20 = 1;
ECanbRegs.CANMD.all = ECanbShadow.CANMD.all;
/* Enable Mailbox under test */
ECanbShadow.CANME.all = ECanbRegs.CANME.all;
ECanbShadow.CANME.bit.ME20 = 1;
ECanbRegs.CANME.all = ECanbShadow.CANME.all;
ECanbMboxes.MBOX20.MSGCTRL.bit.DLC = 8;
/* Write to DLC field in Master Control reg */
// ECanbMboxes.MBOX25.MSGCTRL.bit.DLC = 8;
EDIS;
while(1)
mailboxb_read(20); // read the received data
date_check(TestMbox1,TestMbox2);// Checks the received data
// This function reads out the contents of the indicated
// by the Mailbox number (MBXnbr).
void mailboxb_read(int16 MBXnbr)
volatile struct MBOX *Mailbox;
Mailbox = &ECanbMboxes.MBOX0 + MBXnbr;
TestMbox1 = Mailbox->MDL.all; // = 0x9555AAAn (n is the MBX number)
TestMbox2 = Mailbox->MDH.all; // = 0x89ABCDEF (a constant)
TestMbox3 = Mailbox->MSGID.all;// = 0x9555AAAn (n is the MBX number)
MessageReceivedCount++;
void date_check(int32 T1, int32 T2)
if((T1 == 48) && ( T2 == 0))
i=0;
if((T1 != 102) && ( T2 != 6))
buffer=T1;
buffer=T2;
i++;
} 如果你是初学者, 你可以参考例程代码先把要实现的功能做出来, 不要太纠结这些细节.
如果想搞明白为何这样写, 得查编程参考手册里寄存器的说明和编程规则 这个如果能把芯片的数据手册都看明白了,应该就解决了 如何操作寄存器,如何写入,各个位都代表什么含义 ECanbRegs.CANRMP.all |= 1<< MBXnbr; // Clear receive panding flag<<这句话应该就是对寄存器进行操作吧,位操作,往里边写数 ECanbRegs.这个就应该表示的是与ecan相关的寄存器吧,单词的缩写,我是这么认为的
页:
[1]
