golang的一个文件服务器
可以显示指定目录,进入子目录,下载文件,上传文件等等@sherwin @海中水 @gaoyang9992006
go run fileserver.go -p=1234
显示指定目录:
进入子目录:
上传文件:
fileserver.go
代码如下:
package main
import (
"flag"
"fmt"
"io"
"io/ioutil"
"log"
"net/http"
"os"
"path"
"strconv"
"strings"
"time"
var defaultPath string
var baseURL string
var upload_path string
func Logger(req *http.Request, statusCode int) {
const layout = "[ 2/Jan/2006 15:04:05 ]"
fmt.Println(baseURL + " --- " + time.Now().Format(layout) + " " + req.Method + "" + strconv.Itoa(statusCode) + "" + req.URL.Path)
func Handler(w http.ResponseWriter, req *http.Request) {
filename := defaultPath + req.URL.Path
fmt.Println("=+=== file name: ",filename)
if last := len(filename) - 1; last >= 0 && filename == '/' && len(filename) != 1 {
filename = filename[:last]
if req.Method == "POST" {
file, head, err := req.FormFile("file")
if err != nil {
fmt.Println(err)
return
defer file.Close()
//创建文件
fW, err := os.Create(upload_path + head.Filename)
if err != nil {
fmt.Println("文件创建失败")
return
defer fW.Close()
_, err = io.Copy(fW, file)
if err != nil {
fmt.Println("文件保存失败")
return
// Empty request (Root)
if filename == "" {
filename = "./"
file, err := os.Stat(filename)
// 404 if file doesn't exist
if os.IsNotExist(err) {
_, err = io.WriteString(w, "404 Not Found")
Logger(req, http.StatusNotFound)
return
// Serve directory
if file.IsDir() {
slashCheck := ""
files, err := ioutil.ReadDir(filename)
// Catch the Error in reading from directory
if err != nil {
http.Redirect(w, req, "", http.StatusInternalServerError)
Logger(req, http.StatusInternalServerError)
// Checking for Root Directory
if filename != "./" {
if filename != '/' {
slashCheck = "/"
fmt.Println("=+=== slashCheck: ",slashCheck)
fmt.Println("=+=== req.URL.Path: ",req.URL.Path)
responseString := "<html><body> <h3> Directory Listing for " + req.URL.Path + "/ </h3> <br/> <hr> <ul>"
for _, f := range files {
if f.Name() != '.' {
if f.IsDir() {
responseString += "<li><a href=\"" + req.URL.Path + slashCheck + f.Name() + "\">" + f.Name() + "/" + "</a></li>"
} else {
responseString += "<li><a href=\"" + req.URL.Path + slashCheck + f.Name() + "\">" + f.Name() + "</a></li>"
//Ending the list
responseString += "</ul><br/><hr/>"
p := req.URL.Path
// Display link to parent directory
if len(p) > 1 {
base := path.Base(p)
slice := len(p) - len(base) - 1
url := "/"
if slice > 1 {
url = req.URL.Path[:slice]
url = strings.TrimRight(url, "/") // Remove extra / at the end
responseString += "<br/><a href=\"" + url + "\">Parent directory</a>"
uploadStr := "<form action='#' method=\"post\" enctype=\"multipart/form-data\"> <label> </label><input type=\"file\" name='file'/><br/><br/> <label><input type=\"submit\" value=\"上传文件\"/></label> </form>"
responseString = responseString + uploadStr + "</body></html>"
//fmt.Println(" =+=== responseString: ",responseString)
_, err = io.WriteString(w, responseString)
if err != nil {
// panic(err)
} else {
Logger(req, http.StatusOK)
upload_path = "./" + req.URL.Path + "/"
return
// File exists and is no directory; Serve the file
b, err := ioutil.ReadFile(filename)
if err != nil {
return
str := string(b)
extension := path.Ext(filename)
if extension == ".css" {
w.Header().Set("Content-Type", "text/css; charset=utf-8")
} else if extension == ".js" {
w.Header().Set("Content-Type", "application/javascript; charset=utf-8")
_, err = io.WriteString(w, str)
if err != nil {
// panic(err)
} else {
func main() {
defaultPortPtr := flag.String("p", "", "Port Number")
defaultPathPtr := flag.String("d", "", "Root Directory")
flag.Parse()
portNum := "8080"
// Handling the command line flags
// Directory
if *defaultPathPtr != "" {
defaultPath = "./" + *defaultPathPtr + "/"
} else {
defaultPath = ""
// Port Number
if *defaultPortPtr != "" {
portNum = *defaultPortPtr
} else {
portNum = "8080"
baseURL = "http://localhost:" + portNum
fmt.Println("Serving on ", baseURL, " subdirectory ", defaultPath)
http.HandleFunc("/", Handler)
err := http.ListenAndServe(":"+portNum, nil)
if err != nil {
log.Fatal("ListenAndServe: ", err)
不错的东西。给你点个赞。 海中水 发表于 2019-9-20 09:14
不错的东西。给你点个赞。
可以交叉编译到嵌入式linux环境里:
env GOOS=linux GOARCH=arm go build -v fileserver.go
这样可以很方便为嵌入式环境增加远程查看,更新,下载功能
相当于一个NAS么? sherwin 发表于 2019-9-20 10:29
相当于一个NAS么?
可以的 keer_zu 发表于 2019-9-20 09:26
可以交叉编译到嵌入式linux环境里:
ok!有空研究一下。 为啥不用gin....可以少些不少代码... icecut 发表于 2019-9-23 16:27
关键还是文件和路径的问题 keer_zu 发表于 2019-9-24 11:42
关键还是文件和路径的问题
这个可以修改的. 你想啊. 很多网页服务器必须对上传的文件进行改名.否则会出现安全问题...改个路径还不简单... icecut 发表于 2019-9-25 09:45
这个可以修改的. 你想啊. 很多网页服务器必须对上传的文件进行改名.否则会出现安全问题...改个路径还不简 ...
也用过gin做了webserver,但是没有仔细了解过gin额外提供了那些东西,比如安全方面的。 keer_zu 发表于 2019-10-4 13:21
也用过gin做了webserver,但是没有仔细了解过gin额外提供了那些东西,比如安全方面的。 ...
小i,这是gin版本:
package main
import (
"flag"
"fmt"
"io"
"io/ioutil"
"log"
"net/http"
"os"
"path"
"strconv"
"strings"
"time"
"github.com/gin-gonic/gin"
var baseURL string
if err != nil {
fmt.Println(err)
return
defer file.Close()
//创建文件
if err != nil {
return
defer fW.Close()
if err != nil {
return
if filename == "" {
filename = "./"
return
// Serve directory
if file.IsDir() {
slashCheck := ""
if err != nil {
slashCheck = "/"
if f.IsDir() {
} else {
//Ending the list
p := req.URL.Path
if len(p) > 1 {
url := "/"
if slice > 1 {
if err != nil {
// panic(err)
} else {
return
if err != nil {
return
str := string(b)
if err != nil {
// panic(err)
} else {
func FileServerGet(c *gin.Context) {
filename := defaultPath + c.Request.URL.Path
if filename == "" {
filename = "./"
_, err = io.WriteString(c.Writer, "404 Not Found")
//Logger(c.Request, http.StatusNotFound)
return
// Serve directory
if file.IsDir() {
slashCheck := ""
if err != nil {
http.Redirect(c.Writer, c.Request, "", http.StatusInternalServerError)
//Logger(c.Request, http.StatusInternalServerError)
slashCheck = "/"
fmt.Println("=+=== c.Request.URL.Path: ",c.Request.URL.Path)
responseString := "<html><body> <h3> Directory Listing for " + c.Request.URL.Path + "/ </h3> <br/> <hr> <ul>"
if f.IsDir() {
responseString += "<li><a href=\"" + c.Request.URL.Path + slashCheck + f.Name() + "\">" + f.Name() + "/" + "</a></li>"
} else {
responseString += "<li><a href=\"" + c.Request.URL.Path + slashCheck + f.Name() + "\">" + f.Name() + "</a></li>"
//Ending the list
p := c.Request.URL.Path
if len(p) > 1 {
url := "/"
if slice > 1 {
url = c.Request.URL.Path[:slice]
_, err = io.WriteString(c.Writer, responseString)
if err != nil {
// panic(err)
} else {
//Logger(c.Request, http.StatusOK)
upload_path = "./" + c.Request.URL.Path + "/"
return
if err != nil {
return
str := string(b)
c.Writer.Header().Set("Content-Type", "text/css; charset=utf-8")
c.Writer.Header().Set("Content-Type", "application/javascript; charset=utf-8")
_, err = io.WriteString(c.Writer, str)
if err != nil {
// panic(err)
} else {
func FileServerPost(c *gin.Context) {
file, head, err := c.Request.FormFile ("file")
if err != nil {
fmt.Println(err)
return
defer file.Close()
//创建文件
if err != nil {
return
defer fW.Close()
if err != nil {
return
func main() {
router := gin.Default()
router.GET("/",FileServerGet)
router.POST("/",FileServerPost)
flag.Parse()
portNum := "8080"
// Directory
} else {
defaultPath = ""
// Port Number
} else {
portNum = "8080"
if err != nil {
err := http.ListenAndServe(":" + portNum, router)
if err != nil {
@海中水 @gaoyang9992006 @sherwin
// Static serves files from the given file system root.
// Internally a http.FileServer is used, therefore http.NotFound is used instead
// of the Router's NotFound handler.
// To use the operating system's file system implementation,
// use :
// router.Static("/static", "/var/www")
func (group *RouterGroup) Static(relativePath, root string) IRoutes {
return group.StaticFS(relativePath, Dir(root, false))
看上面的函数注释. func main() {
// 为 multipart forms 设置较低的内存限制 (默认是 32 MiB)
// router.MaxMultipartMemory = 8 << 20// 8 MiB
router.POST("/upload", func(c *gin.Context) {
// 单文件
file, _ := c.FormFile("file")
log.Println(file.Filename)
// 上传文件至指定目录
// c.SaveUploadedFile(file, dst)
c.String(http.StatusOK, fmt.Sprintf("'%s' uploaded!", file.Filename))
router.Run(":8080")
} func main() {
router.Static("/assets", "./assets")
router.StaticFS("/more_static", http.Dir("my_file_system"))
router.StaticFile("/favicon.ico", "./resources/favicon.ico")
// 监听并在 0.0.0.0:8080 上启动服务
router.Run(":8080")
下载.
文件浏览需要自己写.官方没有 icecut 发表于 2019-10-8 17:42
func main() {
上一个代码整合进来不就能上传了. 我只是把官方代码贴给你看看. 没用那么大代码量就能完成 icecut 发表于 2019-10-9 14:13
上一个代码整合进来不就能上传了. 我只是把官方代码贴给你看看. 没用那么大代码量就能完成 ...
是的,我整合过后不能上传,gin代码实现单纯的文件浏览功能是很简单,但是通过net/http实现的那个,主要功能都是在代码中的html中实现的。gin却很不方便让自己的文件浏览功能(StaticFS)扩展上传或者其他等等。 keer_zu 发表于 2019-10-9 14:29
是的,我整合过后不能上传,gin代码实现单纯的文件浏览功能是很简单,但是通过net/http实现的那个,主要 ...
还是尽量用gin, 原生http真的没人用. 前端的代码尽量js独立完成.
正规办法是用阿里oss等云平台来搞这种上传.太浪费流量
页:
[1]
